Question about Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator
27 cu. ft. samsung refrigerator, side by side with french doors not making ice
    President:
  • 1,099 Answers
Troubleshooting an Ice Maker that won't Make Ice
Troubleshooting an ice maker is very important if you have problems with it. If you are having problems making ice with your ice maker then this is a very serious issue which will need to correct. If you are suffering from problems with your ice maker then there are a few simple things that you can do to diagnose and correct the problem yourself.
Checking the LinesThe first thing that you should do is check the water supply lines to ensure that they are not blocked. Sometimes ice can block the lines which may mean that they need to be cleaned out.
If the fill tube is frozen then this might need to be defrosted so that you can use it again. If the tube is too badly damaged then it might need to be replaced.
Broken LinesIf the lines break or become damaged then they can prevent water from getting to the ice maker. In this case the lines will need to be replaced so that you can restore the functioning of your ice maker.
Not Connected to WaterIt's also worthwhile checking the connections between your freezer and the water lines. If your freezer is not connected to the water lines, or if the tap is turned off then this will cause the same problems. There will not be any water available to make into ice. This is a very easy problem to correct and shouldn't take long to identify.
If you are not able to get any water from your freezer either then this suggests it could be a problem with the water supply. You will probably hear a buzzing noise when you're trying to make ice, this means that the freezer is trying to pump water which isn't available.
ValvesThe valve which is connected to the tap could also be damaged or broken. Check the valve opens and closes correctly and consider replacing it if it is damaged.
Too WarmIf the freezer is set to a too warm temperature then this will also create problems with producing ice. You will also notice that this isn't keeping your food as long as it should do. To correct this problem you will need to change the thermostat on your freezer so that it is lower.
Checking the Bail WireThere is a bail wire inside the ice maker which will lift when the ice maker is full of ice. This is designed to prevent too much ice being produced. If the bail wire is stuck in the up position then this will be preventing ice production.
Check the position of the bail wire by locating it inside your freezer. The instruction manual should help you to locate this wire.
SolenoidUnplug the freezer and pull it out from the wall. The water will travel to a solenoid located at the back of your freezer before being sent to the ice maker. If the solenoid is not working or is not getting power then this could be a reason for concern. If you're not skilled at home electronics then you might want to hire a specialist to help compete this task for you
Good luck
Posted on Jul 14, 2010
Manual available?
SAMSUNG RS261MDRS/XAA USER MANUAL Pdf Download.
www.manualslib.com > ... > Refrigerator > RS261MDRS/XAA
Samsung side-by-side refrigerator service manual (33 pages). Refrigerator ... 26 cu.ft. french door refrigerator rf267aebp user manual (ver.0.4) (44 pages).
Samsung - RS261MDRS - 26.0 cu. ft. Side-by-Side ...
www.searsoutlet.com > Refrigerators & Freezers
Rating: 4 - ‎228 reviews
Side-by-Side Refrigerator - Stainless Steel (RS261MDRS) at Sears Outlet today! ...Overview; Specifications; Manual & Warranty; Reviews ... 26 cu. ft. for greater space, convenience and access - Spacious enough to fit about 19 bags of ...
Jan 12, 2016 | Samsung Rs261mdrs 26 Cu. Ft. Sxs...
Samsung french door freezer will not open
Aha!
The Samsung wants the password.... in French! No!
Sorry.... couldn't resist....
If it's iced up then that would hold it shut until it melts.
Icing up is usually caused by a bad seal!
Sep 18, 2015 | Samsung RF217ACPN - 20 cu. ft. French Door...
Ice maker stopped making ice after filter change
these seem to air lock when filters are changed try loosening the fitting on the filter( out put side ) just enough to let water start flowing then tighten it back up
May 05, 2015 | Samsung RF26XAERS 26 Cu. ft. French Door...
Rfg298aars ice maker
My Samsung French door fridge #RF267abbp makes a knocking sound coming from the ice maker. The knocking lasts for about45 minutes and continues throughout the day and night, It is very annoying especially at 3 am.
Oct 02, 2012 | Samsung RFG297AARS (285 cu ft) Bottom...
Whirlpool 27 cu ft french door refrigertor: touch
they might come fix it if notified by you of problem ,under warranty but probablywill not accept it being returned .
Nov 20, 2017 | Whirlpool GI7FVCXWB (27 cu ft) Bottom...
Ice mker not work good,
I return the Refrigerator to the store I got it from
Nov 18, 2008 | Samsung 25.5 Cu. Ft. Side-by-Side...
I have NEW sumsung ref. 25.5 french door with freezer at bottom
Had the same problem, your ice maker is a known defect, insist they replace it. Don't expect heavy ice output -- our biggest complaint.
Aug 30, 2008 | Samsung 25.5 Cu. Ft. Side-by-Side...
Samsung 24.8 Cu. Ft. Side-by-Side Refrigerator with Thru-the-Door Ice and Water - Stainless-Platinum... Side by Side Refrigerator Logo
322 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
