Question about Refrigerators
Frig. water wont go into ice maker . checked soylonid works when elec. is applied cleaned lines made sure they where free still no water gets to ice maker
  • 135 Answers
Make sure you check your water supply and filter if you have one. Check the ice maker. Make sure the motor and gears are turning in the ice maker itself. As the ice maker goes through the cyle it activates the water solenoid for about 5-10 seconds at a certain piont to fill it. If the ice maker isn't running the ice maker will not fill.
Posted on Apr 20, 2008
Ge side by side ice maker not filling up
most of the time when that happens first thing you do is make sure water is getting to the solenoid for the ice maker if you have a water despencer you have water the solenoid for the ice maker is normally found in the back of frig near bottom pull frig out till you can get behind it look where water line goes into the frig solenoids for water and ice maker should be there. leave frig plugged up have someone use the water despencer feel whitch one that is replace the other one
Aug 20, 2014 | GE Refrigerators
Gss23qgta bb
Check water cut off then check your water line it may have a kink in it the next thing would be the pump for the water on the back of the frig if you have water dispenser and ice you have two sided pump just because you are getting water does not mean the water is going to the ice compartment. Also unplug and plug your ice maker this may reset it wait 24 hours it can take that long to start working again. .
Apr 27, 2014 | GE Refrigerators
ICE MAKER NOT PRODUCING ICE. WATER IS GETTING TO LINE; WATER DISPENSER IS WORKING FINE, MOTOR ON ICE MAKER IS WORKING. THIS PROBLEM STARTED AFTER WATER LINE TO FRIG FROZE DURING COLD SPELL.
Remove the icemaker and check the incoming water line. It may be frozen.
This icemaker manual may be of some help to you.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/9e1ec3936ebd443e852572fa00675934/$FILE/4316835.pdf
Jan 17, 2010 | Refrigerators
Ice maker quit working on GE refrigerator
Sometimes on a ice maker what will happen is the water line that fills the ice maker will freeze. You can use a large syringe filled with hot water and from the rear of the frig remove the water line where the hose goes into the rear of the frig and force some hot water into the tube to see if it is clear.
If the line is clear fill the ice maker manually and see if it goes through a cycle.
If it goes through a cycle you have to check to see if the ice maker is calling for water by putting a multi meter across the contacts of the water inlet valve located behind the panel on the back of the frig. Advance the ice maker to run through a cycle and see if it is calling for water. If you have current going to the valve and no water momming in, replace the valve.
If you do not have current going to the valve after the ice maker has gone through a cycle. Replace the ice maker.
Dec 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water squirts out the back of my Kitchen Aid Superba where the water line enters the fridge. This happens when the ice maker tries to fill with water.
make sure that the water supply line is tight. the line that comes from the wall should be copper or stainless steel braided line. if it is the clear plastic line get rid of it as it is more prone to kink and leak especially at the points where the connections are made... another thing to check is where the supply line connects to the frig.. that is the solinoid valve and on the top is a blue or clear plastic cap and somtimes they will crack or have a small pin hole in them and will spray a very fine stream of water that is hard to see but can be felt on your finger tip.. pull out the frig and empty the ice tray and put it back in and close the freezer door or drawer and wait for the ice maker to call for water and have a bright flashlight ready, when it calles for water you will only have about 5-7 seconds to see where the leak is so make sure to feel around as well.; if your are replacing the ice maker supply line from the wall to the frig make sure to not over tighten the connection to the frig because it may cause that plastic cap to crack....I hope this helps....
Nov 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
GE Frig has water at door but no ice is made
Pour about 1/2 cup of water into the icemaker . If it dumps , replace the water valve . If not , replace the icemaker . Make sure the coils are clean of dust , etc... at bottom of fridge .
Aug 09, 2009 | GE CleanSteel GSL25JFTBS
Kenmore frig ice machine doesn't make cube ice
Normally, the ice "cubes" are crescent shaped. The most likely cause for "crushed" ice is that the ice maker isn't getting enough water on its refill cycle after ejecting the tray. Becuase there isn't enough water, the ice looks crushed...it's actually shattered.
Check the water inlet and chute to the ice maker. Sometimes they freeze and have to be manually defrosted. A hair dryer will do the trick. Also check the water chute and be sure it isn't partially frozen.
Start there...if no luck you could also have a failing water filter or sticky water solenoid valve.
Apr 08, 2009 | Kenmore 23.1 cu. ft. Side-By-Side...
Ice maker and water dispenser not working
well there is two things it could be low water pressure or ur ice maker is defective try replaceing the ice maker this should work if not u need to get a frig repair man out to help u because if the problem is in the frezzer door it is not easy to fix on ur own
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Whirlpool ED5LHAXMB11 Refrigerator side by side
check your module itself on the ice maker make sure the plactic piece that turn the motor is not broke off if you can move the injector blades up and down without force that could be your issue to check you ice make sensor open the freezer and push the light switch 3 times you should get a solid red light where you can turn your ice maker on or off if that is not solid it is the computer chips that are in the freezer liner if all that checks then replace the water valve
Mar 11, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
130 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
