Question about Linksys Wireless-G WRT54GS Router (e125894)
Cant find wap code for linksys wireless route trying to connect to my sony tv
    Problem Solver:
  • 12 Answers
The code can be reset to the factory default by pressing the and holding the reset button for five seconds.
Posted on Oct 24, 2010
I want to connect my HD TV to the internet, wirelessly thro my home network. I have purchased an access point (Linksys WAP610N) but that doesn't appear to support my application. Should I be using a...
An access point is used to extend the signal.
Have you set it up by putting the MAC address of the WAP into the router and vsetting it up as a repeater?
Watvh this video:
http://www.youtube.com/watch?v=0I6vKp_XuSQ
After you setup the WAP correctly, the TV should pick up the signal.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jul 02, 2011 | Linksys by Cisco WAP610N Wireless-N Access...
Hi Support team, I use Modem Motorola SB100 with Linksys WAP54G, and DLink Wireless G DWA USB Adapter to connect to Linksys WAP from my PCDesktop. Connection from the PC to Linksys is ok but can't...
peter_picasa:
You cannot use a Wireless Access Point (WAP) to connect directly to your IPS's modem. A WAP does not provide the ability to share a single IP address on the internet like a router does.
Either return the WAP for a refund and buy a wireless router or buy an Ethernet wired-only router and plug the WAP into the LAN side of that router. You would then plug the WAN side of the Ethernet wired router into your modem.
Thanks for using FixYa.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
My computer will not connect to the internet when I hook up to the Linksys wrt150n I don,t understand It because it use to work this is about to drive up the wall I have tried resetting the router but it...
If you can connect to the Internet using the LAN cable then your Internet connection is OK.
If you are trying to connect to the Internet using the wireless connection, then your problem is the wireless settings in either the Linksys or the wireless card in your computer.
First check the wireless settings in the Linksys, ie. the SSID and encryption key.
Second check the wireless settings in the computer's wireless card, this must match the route's wireless settings. If it matched then do a Repair connection. this will get the Linksys to issue a new IP address to the wireless card.computer.
If the Linksys wireless settings were changed then configure the wireless card in the computer with these new settings.
Please click on this link for further diagnostic procedures on network problems :-
http://www.fixya.com/support/r4229966-network_diagnostic_procedures
Nov 03, 2010 | Linksys Wireless-N WRT150N Router
I have trouble adding a WAP to my switch
configure that port for wap need mac off back of wap
Feb 20, 2010 | Computers & Internet
Why link led of WAP54G Linksys is not blink if i install cable on LAN Notebook? i try reset this WAP but still not change. I can't login with IP 192.168.1.245. Thanks.
First RESET your router to defaults settings.Press RESET button for 10 seconds it is in back side of router.
Then connect your router to computer with ethernet cable then you can access it with default link http://192.168.1.1
or
http://192.168.0.1
Type user as "admin" and password as "admin" or blank or "password"
Then you can see configuration page of router.
Then configure your router again set WAN settings as your interent service provider.
Enable DHCP if you want iip automatic from router.
CLcik on wireless and enable it .Configure your router as WEP or WAP then add code it is your password to connect internet.
Then save and restart router and computer.
Then connect internet.
Let me know if you need further assistance.
Dec 20, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
Cant connect to wireless network on my ps3
First off you have a wireless router hooked up to your ISP correct.
anually set a static IP for your wireless connection (When going through the network setup in Network Settings --> Internet Connection Settings (wireless), choose Custom instead of Easy when the page asking for either appears).
Set the IP address to something outside your DHCP range. e.g. 192.168.0.5 (for dlink router) or 192.168.1.5 (Linksys router)Default gateway should be the IP of your router. For dlink, this should be 192.168.0.1 and Linksys should be 192.168.1.1DNS Server can be the same as your default gateway, mentioned above.
Subnet Mask should be 255.255.255.0.If you're using some sort of encryption (WEP, WAP, etc), set it in there as well when it asks to do so.
And that should get you going. I actually haven't done this on the ps3, but its my info from experience with regular pc to pc networking.
Also If you haven't tried this already, change the wireless channel from 6, to 1 or 11 in your router and wireless consoles.
If all else fails, try this http://www.clanbluntforce.com/forum/index.php?topic=864.0
Nov 21, 2009 | Video Game Consoles & Games
Ps3 wirelesss conectin poblem
This is fairly easy.
1. Open network settings
2. Selected wireless and scan
3. When you see your router name click on that.
4. If you have a WEP security code you will need to enter that.
5. You should be finished!!
If you have any more questions, please comment here and I will come back and respond.
I hope this helps! Good luck to you!!
Jul 21, 2008 | Sony Playstation 3 (PS3) Console
Static routing "Advanced Routing" on Linksys WRT55AG
Any reason why they're not both on the same subnet?
Jun 15, 2008 | Linksys WRT55AG Router
Connection to WAP
disconnect .
open internet browser
type the gateway and press enter
Nov 13, 2007 | Linksys Wireless-G WAP54G 802.11g/b...
Linksys Wireless-G WRT54GS Router (e125894) Logo
70 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
