Question about Lowrance GPS
I have a lowrance globalmap 5150c chart plotter on a boat , i cannot get the nmea 0183 to work with the dsc vhf which is an m-tec mt500 the vhf says no gps signal when connected , i have changed the vhf for a new one but still the same , i have double checked all the wiring connections all ok , i am getting 2.5v pulse at vhf with wires disconnected from vhf but when connected this drops to 0.5v can you suggest what the problem might be .
SOURCE: Lowrance Globalmap 2000
The screen is the weak point of the 2000's.  I have one myself, and without warning a number of "lines" appeared on the screen, getting progressively worse over time.
Perusing other forums, it seems we're not alone.  Unfortunately the only "solution" I've found thus far is to purchase a new head unit (eBay is a terrific source!).
Posted on Jun 01, 2008
SOURCE: Communication to Offshore Navigator light
The internal memory battery is dieing. It will eventually stop completely unless you get a new battery installed.
Posted on Aug 11, 2008
aloha27
  • 695 Answers
SOURCE: Connecting Garmin GPS 152 to VHF Radio Silva S15
Hi!
From the S15 owners manual (Page 46):
http://www.bluemoment.com/manuals/silva_s15.pdf
The RED wire is GPS data,
The green wire is GPS ground.
Hope this helps and good luck!
Posted on May 08, 2010
emissionwiz
  • 77202 Answers
SOURCE: I have a Simrad CP33
Here is a link to the operation manual of the GPS plotter in PDF, it is a large file (3.25MB) so allow time for it to download.
http://www.busse-yachtshop.de/pdf/simrad-cp33.pdf
Posted on Sep 27, 2010
bbl242003
  • 1637 Answers
SOURCE: Lowrance Globalmap 100... Problem: When you turn
1. PLEASE do not forget to award your ACCEPTED answer
2. here is a quick reference for your GPS http://www.lowrance.com/upload/Lowrance/Documents/Manuals/GM100.pdf
3. Be sure to completely charge your unit before turning it back on
4. If you still have problems with AUTOMATIC shutdown after turning on, the problem is most likely related to the batteries.
5. If the unit has been dropped, you may very well have additional problems aside from the battery.
PLEASE respond to me for more help if need be, username bbl242003
Posted on Jan 09, 2011
Why don't I see fish on my lowrance elite5 hdi fish locator
Sounds like you do not have your transducer connected.
You will know it is working if you have a bottom sounding. If you have a bottom sounding (depth reading) and it is correct then you may have to fine tune the finder to see the fish.
I have the same finder on my boat. http://njsaltfish.com/index.php/captainsfocus?sid=61
Sep 17, 2015 | Lowrance HDS 5 Fishfinder GPS Chart...
What is nmea
As Anreas said, The new standard for NAMEA is 2000 used to communicate between multiple devicsess wth multiple talkers. 0183 can only have one talker
Jul 17, 2014 | Lowrance Elite 7x Hdi Fishfinder 50/200...
What are the data cable 5 wire used for and where do they get hooked up
The additional wires are for NMEA data transfer to and from other devices and sensors like distance, speed, depth, temperature and NMEA 0183 sentences the unit will use when connected to a VHF radio or other NMEA 0183 device.
The manual link below.
http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5_HDI_OM_EN_988-10518-001_w.pdf
Jun 11, 2014 | Lowrance Boating
How to hook a uniden vhf radio to a garmin 4208 for nmea operation?
Hi
I realize this question is old, but for the benefit of someone else who might have the same query, the NMEA 0183 outputs from the 4208 are the gray (+) and black (-) which go to the data in of your DSC VHF. The data OUT from your VHF connect to the white (+) and black (-) of the 4208.
If using NMEA 2000, using the second link below, start on page 10.
The installation instructions are about halfway down on the link page and can be accessed directly from the install link below if you prefer. -Steve
http://support.garmin.com/support/manuals/manuals.htm?partNo=010-00591-01&language=en&country=US
http://static.garmincdn.com/pumac/GPSMAP_4000-5000_Install_EN.pdf
Apr 28, 2014 | Uniden Boating
NMEA Output from Furuno 6" LCD Radar, Model 1623
No it does not output any type of radar video data.
Apr 27, 2010 | Furuno 1623 Radar 16nm Range
Why cant I download my waypoint data to a 2 GB SD card. My Global map 5000c does not recognise the 2GB SD card. Do I need MMC/SD. Can I place the sd card in the slot beside the chart card ?. Thanks
You can place the SD card into the slot beside the chart card.
With the SD card in the GlobalMap unit by itself (take the chart card out), press MENU twice and choose BROWSE FILES. Does the unit indicate that an SD card is present? If yes, the card is working fine in that slot. Try the same thing in the other slot. If it only recognizes the SD card in one of the slots, the other slot is bad and probably won't work with any card. If the card is recognized in the BROWSE FILES menu, but the data that is on the card is not working, there could be compatibility issues with the data and the GlobalMap 5000.
Make sure the GlobalMap 5000 has the latest software update from http://www.lowrance.com/en/Products/Legacy-Products/GlobalMap-5000C/Downloads/GlobalMap-5000C-Software-Update-180/. You might need to get a different, smaller capacity card since your 2GB is not working.
If the 2GB SD card still isn't recognized in the BROWSE FILES menu after the update, the GlobalMap 5000 is not going to work with that 2GB card. You will want to get a different card. I suggest 1GB and smaller.
If this doesn't help, please let me know some more details. Is the 2GB SD card recognized in the BROWSE FILES menu. What are you seeing that makes you determine it does not recognize this card? What files are currently on this card? What kind of card is it (brand, model).
Jul 11, 2009 | Lowrance GPS
My plotter seems not to output NMEA to my DSC radio and auto helm
Your plotter can talk to you Radio and your pilot. It sounds like one of two things.You must go into the system setup menu and turn on the nmea sentances. You will need to turn on RMB, RMC, GGl at least. You can turn on all the sentances if you like it does not matter. If this does not fix, check color of wiring is correct. Remember you have to go from NMEA + out (on plotter) to NMEA + IN on Radio.Then you need NMEA - out(on Plotter) to NMEA - IN on Radio.
You can look at the sentances wirth a multi meter coming out of your plotter. You put meter in DCV and connect across the NMEA out lines. You will see the meter move every second or so as it send a sentance.
Jun 09, 2009 | Raymarine Raychart 435 GPS Receiver
Lowrance not reading navionic
Make sure that the 5200c is set to read the Navionic card. You can set that under Map Data.
Mar 08, 2009 | Lowrance GlobalMap 3500C GPS Receiver
I have a lowrance 3600c igps linked to a navman vhf 7100 but for some reason it has stoped giving information on my position to the radio. I have cheked all the wires are ok it was fine last week when i...
If your GPS was sending NMEA data and now is not, your NMEA configuration may have been inadvertently changed, either due to a user error, or possibly a software glitch.
You can configure the unit to use specific NMEA sentences.
1. Press MENU|MENU| then scroll down to SYSTEM SETUP and press |ENT.
2. Scroll down to COMMUNICATIONS PORT, then press ENT then scroll down to CONFIGURE NMEA and press ENT.
3. A menu appears showing the prefixes of the available NMEA sentences.
A check mark next to a prefix means the prefix is in use. Use the arrow keys (on the track pad) like a mouse to select a prefix, then press ENT to turn off the prefix. (Press
ENT again to check the box and turn a prefix on.)
I'm not exactly sure how the data is labeled on that model but you looking for a sentence that looks like an abbreviation for GPS Lat Lon (it may be something like GPLL). If you're not sure, turn them all on, the VHF will only use the sentences it recognizes.
4. When the desired prefixes are checked or unchecked, press
EXIT|EXIT|EXIT|EXIT to return to the previous page.
let me know if this worked for you, or if I may be of further assistance.
Aug 18, 2008 | Lowrance GPS
GPS Logo
57 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
