Re: My 1998 jeep grand cherokee is haveing a problem with...
Hello
Open the hood,,, disconect both battery cables,, let it sit for 10 minn ,,,,,,conect the battery cables,,,,,,,,,,,,,,,,,, then,,,,,,,,,
Lets try unlocking the lift gate with the key ,,,, move key back and forth 3 times. this should reset the system
pull the battery terminals off the battery and hold the pos and neg cables together for 3-5 min. this should reset the cars computer and alarm
provided it is factory alarm...
Question edited for clarity.
Question moved to model category.
The security alarm and engine immobilizer are functions of the Body Control Module (BCM) and the ECM. You can't just pull fuses. When the battery goes completely flat, or is disconnected, you just need to reset the Security System which is done via the Remote Fob.
which engine? we cant guess here. not ever.
please edit your post.
say car cranks ok but will not start
or
my car will not crank.
(to different systems, there)
Cranking symptoms. or EFI running issues.
Try resetting the asd "auto shut down fuse had a similar problem the jeep would crank but did not get spark or gas also check your fuel pump? and the asd relay may be bad it will prevent the jeep from getting no spark and will not fire some jeeps have security problems
I have a 5.2L V8 Jeep Grand Cherokee and i know to reset my security system i actually have to go around to the passenger side door and lock and then unlock it again. Seems fairly odd but that's how i was told it was reset. Give it a go and lemme know!
have you tried manually unlocking the hatch to reset the security
system?? My 94 grand cherokee limited did not have a key pad to turn system on/off...i have reset it by turning the key in the rear hatch lock to the left twice...see if this works. - SmokeWrench
