Question about Blanco Classic Single Handle Faucet with Pull-Out Spray ....
Blanco 2.2 GPM Faucet/Side Spray#157-013ST Via Google NO PRESSUR
When we bought the house the Faucet Flow was a stream about size of TIP of automatic pencil. NO PRESSURE. After daily use for 4 months, the size of water is about the size of an eraser on a wood pencil. NO PRESSURE. The separate side Sprayer unit has NO WATER at all. Cleaned tip of Faucet. Had water presure to the house checked by plumber-Good. Suggestions are that we need a new Faucet. Since there seems to be an improvement in the water supply I feel there could be a way of fixing these units. I have been told there is a limited warrantee on the faucets.
IS THERE ANYTHING WE CAN DO TO SAVE THESE UNIT?
D. Tice
  • 299 Answers
Try unscrewing the aerator and cleaning the screen that you'll find there. If that doesn't work then you should check the pressure under the sink by removing the cold water hose from the cutoff valve (turn it off 1st!). If the pressure there is good then try removing and cleaning the cartridge by soaking it overnight in white vinegar or consider replacing the whole faucet if it's old. You can also call Blanco and see what they'll do for you as it has a "Limited Lifetime Warranty." If the pressure at the cutoff is low it's time to call a plumber!
Posted on Jul 15, 2010
My new Blanco sink faucet does not provide much water pressure; is there a restricion part inside the faucet head that can be removed to allow for more pressure?
No you can not remove them, if you try to dill out the water saver you might do damage to the faucet.
Sorry next time you buy check the G P M flow rating.
Best of luck Rich
Sep 05, 2011 | Blanco Classic Single Handle Faucet with...
Have a Blanco single-handle pull-out faucet with single-stream and spray option. Spray option can be turned on and off with a twist switch on top of the faucet. Our faucet is now stuck on spray option and...
Unscrew the part where the water comes out and remove the enterior parts paying close attention to how and the order in witch the come out so you can clean everything good and put it back together and pay close attention to the twist switch and how it operates. This shought fix the problem your having.
Jun 30, 2011 | Blanco Classic Single Handle Faucet with...
Have a blanco torino pull out faucet and the flow has been reduced to almost nothing. before I pull it apart, any idea what the cause might be? I have undersink shut off valves and they are both open so...
I have found through experience that most of the time when water flow is reduced out of the spicket that the spicket screen is plugged up. Try to unscrew the spicket nozel tip and the screen should be inside of it. Look and see if there is something plugging it. If not vissible, clean the screen by running fluid through it backwards.
Nov 13, 2010 | Blanco Classic Single Handle Faucet with...
Just installed a new Blanco Torino, model 157183, and inadvertantly got saw dust in the waterline during installation. It is restricting the pressure on the faucet. What is best way to clean it out?
I would try to unscrew the spray head from the hose and turn the water on to see if you get good flow from the hose. If so you need to clean the head, if not you will have to start taking the faucet apart and cleaning or possibly replacing the cartridge
Jun 26, 2010 | Blanco Classic Single Handle Faucet with...
Remove water saver device from Blanco Grace kitchen faucet
Remove the aerator at the end of the spout. It will unscrew and once off it will have a dime sized restricter in it that can be removed this restrict's the water down to about 1.6 gpm to save water.
It will either be plastic or metal and about the size of a dime with a small holw in it to let water pass by maybe 1/8" hole just remove it and put aerator back together.
Clean aerator screen out before you put it back together.
http://www.plumbersurplus.com/pdf/07163.pdf This link has a breakdown of parts. Look at parts 8b-10 for aerator breakdown.
Jun 12, 2010 | Blanco 157-052-ST Grace Single Handle...
Our Blanco faucet has a side spray that doesn't work. There is no water when you squeeze the handle. How do you take it apart and what parts need to be replaced?
http://www.faucetdepot.com/pdfs/157-013-CR.pdf This link has a view of internal parts breakdown of this faucet. And it has a list of parts with their names.
I hope this will be of some help for you to disassemble.
Jun 12, 2010 | Blanco Harvest Single Handle Faucet with...
Blanco harvest kitchen faucet with pullout spray low flow rate
Check fine filter at tip, probably blocked, got caught with same thing myself recently!!!
Jan 26, 2010 | Blanco Harvest Single Handle Faucet with...
My Moen kitchen faucet stopped working suddenly in that only a thin stream of water would flow at most when I turned on the hot water handle or the cold water handle to the maximum positions. I replaced...
wow... I wish you hadn't gone thru the expense of replacing the faucet... it's perfectly good... your problem was the aerator, it unscrews at the tip of the water spout and had collected too much sediment which eventually blocked water flow. Often happens quickly after your water is shut off at the main valve. Aerators cost about 50 cents...
Aug 30, 2009 | Moen Chateau Loop-Handle Kitchen Faucet...
Low water pressure/slow flow Blanco Elan faucet 2.2 gpm
pull the sprayer out, get some plyers or a wrench and losen up the connection. between the hose and the sprayer there is usually a screen take it out and walla it should take care of you, it also helps to leave the sprayer in some lime away or vinegar for a few hrs to get the hard water losened up in it
Jun 27, 2009 | Blanco ELAN II 1 Handle Pull-out Spray...
Blanco Classic Single Handle Faucet with Pull-Out Spray .... Logo
430 people viewed this question
Top Blanco Plumbing Experts
Mack Baxter
Andrew Bugbee
Are you a Blanco Plumbing Expert? Answer questions, earn points and help others
