Question about Kryptonite Kryptolok Std U Lock
Went to open my kryptolok combo today and it is jammed and will not open. The combination is set correctly but it will not open. How can I remove it?
How do I get it back open when it won't open to the combination I gave it?
Make sure you push the shackle down firmly to clear the lock and try the combo again. It is possible to open it by trial and error, but not easy. I have removed the security screws and repaired one, but it was tricky to reassemble. The problem with mine was a spring that slipped out of position and the lock wouldn't reset correctly. There are a lot of parts inside, so chances of getting it to work correctly are not good unless you're really good with complex mechanisms and puzzles.
Aug 05, 2014 | Master 1500ID Combination Padlock
How to set the combination on a Blackburn ANGOLA COMBO CABLE LOCK
Open the lock using the original combination, which was 0000 for mine. Once open, you will find two tabs on the lock side--on top and bottom of the lock portal. Push in both tabs, and hold them down while you set the new combination. Once it is set, put the post back in to make sure it is still open. Twist the dials to lock it, and then you should be able to unlock using your new combination.
Feb 23, 2014 | Bell Blackburn Angola Combo Cable Lock
Bell 4 digit bicycle cable lock won't open
Same thing happened to me today. (Bell kevlar combo lock 12 mm) I sprayed WD4 0 on my lock (probably wasn't necessary) and let it soak in. I looked up videos online which weren't very helpful. I kept trying to open my lock and I happened to move one of the four digits and it opened. I'm not sure how the lock pins work but it seems like if you lock your bike and move the lock into ackward positions you can cause one or more of the pins to move. My combo was 2194 and I opened it with the combo of 2294. Go ahead and try your combos +/- one number at all four positions. Hope this helps.
Mar 10, 2013 | Cycling
Misplaced instructions on how to reset combo on Vaultz cash box with 3 digit combo & latch
Directions for setting combination locks
1. With the lock open, push button (to the left, yes opposite of the arrow) and hold until the second operation has been performed.
2. Set number wheels to the desired combination (numbers roll down)
Do not forget the combination you have set!
3. Now release button. Press the button again as a check.
Apr 15, 2011 | Office Equipment & Supplies
I forgot my combination i tried putting a couple different numbers in after three trys the key pad locked and now when i type any numbers in it doesnt work. how do i unlock my safe?
after 3 trys the keypad does go into lockout mode but it should only last for about 15 minutes and then let you retry 3 more codes to try and open. if you still do not know what the combo is you can usually call the maker of the safe and with the serial number you might be able to get the original combo that the safe was set to when it was purchased ( this is a factory set combo ) --- now if that does not work, your next step will be to call a safe tech ( locksmith ) to set up a auto dialer,, this takes about a full 24 hours to get the combo right. the safe tech can also drill a small hole behind the dial and manually remove the locking bolt. after the safe is opened the locksmith will fill the hole and reset the combo for you ( also replace the battery at this time too ).
c...
Jan 15, 2011 | Stack-On Stack On 16 Gun Safe with...
I forgot my combination on my kryptonite bike lock
Thanks Chris Wheeler, I tried unlocking my kryptonite kryptolok and with your suggestions i did unlock it in a minute...its 0005
Aug 15, 2010 | Kryptonite Kryptoflex 1218 Combo Cable...
Power light on but nobody's home?
The power supplies in most all the smaller combo units are prone to failure. They feed both the TV and the VCR and are underdesigned as they try to keep the cost of a combo affordable.
I've never had much success solving them - sorry
They always break that last time!
Jan 08, 2008 | Recoton Advent Advent DV1418A 14 in....
Resetting the combination
The reset works when the current correct combination is set on the front. If you forgot the combination, you can go to the www.masterlock.com and download a PDF to request a combination from the factory to open it. It requires a notarized form & takes 6+ weeks. In the end, it is probably easier to buy a new one. When resetting the combo, I accidently scrambled it as I flipped it over. And did not know the combo. The reset button would not work. I did some guess work around the setting and got it to release again.
Jan 08, 2008 | Master Lock 5400d: Portable Select Access...
Kryptonite Kryptolok Std U Lock Logo
327 people viewed this question
Top Kryptonite Cycling Experts
luminos8
Level 1 Expert
ray gallant
Tom Chichester
Are you a Kryptonite Cycling Expert? Answer questions, earn points and help others
