Question about Kyocera Office Equipment & Supplies
Could you tell me how can i enter the simulation mode for the kyocera 1815 copier.
  • 1 more comment
  • Everett Lin Jul 14, 2010
    Hello Sir. I got an error code " c6000" on the kyocera 1815, could you tell me how can I reset it.
  • Everett Lin Jul 15, 2010
    I have error code "C6000" on kyocera mita cs1815 could you tell me how can I reset it ?
    could you tell me how can i enter the simulation mode for the kyocera 1815 copier. don't tell me punch in "10871087" because it doesn't work on this machine.
    President:
  • 2,185 Answers
Hi there Swan,
To go to simulation mode you just need to press 10871087.
Please let me know how this goes. Thank you for using FixYa.
Posted on Jul 15, 2010
  • 8,197 Answers
Simulation mode
at the machine punch in 10871087
  • Kyocera Master
  • 12,061 Answers
Http://www.retrevo.com/support/Kyocera-KM-1815-Printers-manual/id/529dj897/t/2/
Above is your service manual. To enter the service simulation mode press "10871087" on the keypad. Enter 906 Press start than press "execute" See if this works. Else repeat the steps with 163 replaced for 906 in step-2.
While in simulation mode, to make a test copy, there is no “interrupt” on the screen when in simulation. Press the “System menu” key and then press “Start” to make a test copy.
Posted on Jul 14, 2010
    President:
  • 1,561 Answers
I would suggest you check the manual of the kyocera 1815 copier. this should be stated clearly on the user manual. so check the user manual for the information as regards this.
Take care.
What do I do with the error code of C6050 on a Kyocera KM-3035 machine
You need to go into simulation mode and enter U163.
This simulation number needs to be reset.
Nov 09, 2017 | Kyocera Office Equipment & Supplies
Sharp mx-m264n how to enter simulation mode
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 14, 2015 | Sharp Office Equipment & Supplies
How to set a too light copy?
enter service mode and adjust simulation 100 down to approx 165
Aug 07, 2014 | Kyocera 2av82010 Genuine Mita Km2030 Opc...
Kyocera 1815 la y sale error c6020
The error means - Abnormally high fixing unit thermistor temperature.
Can be caused by Shorted thermistor or Broken heater control circuit on the power supply board.
Jan 19, 2011 | Kyocera Mita KM-1815 All-In-One Laser...
Unable to copy with my Kyocera KM-1815. Error code is C3200.
Typicaly the scanner optics would need to be cleaned. Or it could be a scan lamp failure. A Kyocera dealer could help you with this.
May 27, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
C6000 on Kyocera KM-3050
you can try to reset the error code by going into
simulation mode
once in simulation mode.. go to sim 163
that's a fuser reset
execute that..
if problem persists you need to replace fuser
Mar 10, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
How to get a print history on Kyocera Mita
You need to print a status page for that information. It you can't find it in the Advanced Operaters guide go to www.gfbm.net and do a search for how to get meter reading and it will tell you.
Jan 18, 2010 | Kyocera Mita KM-1815 All-In-One Laser...
Sharp AR-M550 with a paper tray error F3-12
1. Start and end of simulations Note: The "PAUSE" key in the descriptions means the "INTERRUPT" key. Simulation IN The Simulation IN mode becomes only available from the Copy mode screen. In the simulation mode, printer operation is inhibited. Printer operation is also inhibited in either of the Aging mode or the Adjustment Copy mode. The printer selection key is disabled, too. By operating the keys [C] – [PAUSE] – 0/g – [PAUSE], the simulation main code input screen appears. * If the interval between any two key operations is more than 5 seconds, the entry into the simulation mode is canceled. (Ref.) 1 ~ 9: Loading/ sensor checks 10 ~ 19: Resetting troubles 20 ~ 29: Counter/mode setting 30 ~ 39: Sensor activation checks 40 ~ 59: Adjustments 60 ~ 69: Digital readout and printer Simulation OUT The simulation can be terminated by pressing the [CA] key. 2. Simulation main code input screen SIMULATION NO. _ INPUT MAIN NO. AND PRESS PRINT SWITCH 1 If any trouble has occurred when the trouble code is requested, the 7-segment readout displays the trouble code (main only). [Note] The trouble code is canceled when the copier enters the simulation IN mode. [Note] The 7-segment readout becomes blank when the copier enters the simulation IN mode. 2 Only the [PRINT] key LED comes on. [Note] The [PRINT] key LED is usually OFF. It comes on when the copier waits for the [PRINT] key to be turned ON in the simulation mode. 3 The main code input area (2 digits) waits for the input of a main code. [Numeric Key]: Main code input [Note] Codes are entered in the ring format. [PRINT]: Sets entered data. [C]: Clears entered data. [CA]: Terminates simulation. [Others]: Cancels (ignores) entered data. 4 If a simulation has a sub code, it should be executed on the sub code input screen; a simulation does not have a sub code, it should be executed on the simulation execution screen. 3. Simulation sub code input screen
Dec 08, 2009 | Sharp AR-5320 Black and White Copier
Error c710
it means that toner cannot enter the developing section of the copier, all you have to do is remove the developing unit, then pour it with enough toner, the problem will be solve.
May 17, 2009 | Kyocera Mita KM-1815 All-In-One Laser...
Service Manual for KM-1815 Kyocera Copier
all km manuals are available from New Jersey Copy
contact tony@newjerseycopy for all mita service and op mans
Nov 01, 2007 | Office Equipment & Supplies
857 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
