Question about Jenn-Air Grilling
Had a fire interior of Jenn-Air Model No. 720-0062-LP. All the hoses were destroyed, I have purchaced replacement parts but no instruction on where the different hoses go. Perhaps a schematic or instruction would be very helpful. Thanks in advance-J. Carroll
    Problem Solver:
  • 16 Answers
The parts supplier should have a parts diagram. Some online parts dealers have them on their site. I have one for a Jenn-Air 720-0061-lp that may be of some use. I will be glad to email it to you, let me know caycebugs@sc.rr.com
Posted on Aug 25, 2010
Jenn air model 720 0061 manuel
Jenn Air model 720 0061 LP outdoor grill manufactured 12/ 2004 serial DG-002
I have bought this second hand. Would like operating , maintenance, and parts info.
Mar 31, 2014 | Jenn-Air Outdoor Liquid Propane Lp...
I am trying to convert a Jenn-air model # PRD3630NP from LP to NG I assume this model is convertable becouse it has a convertable reg on it. Do thay make a kit to do this or is it just a matter of ins
Jenn Air use to make a kit that had the proper orifices for the burners and the valves. The regulator is adjustable for the conversion by simply reversing the main screw. It was intended to be convertible. However, since the model is discontinued, you can no longer purchase the kit (or the backsplash). Apparently Jenn Air believe that when they stop making a product, no one will ever need a part for it again (cough, cough).
Good luck trying to track down a kit. I've tried everywhere in the country and a few shops in Canada. I have a gas appliance expert who thinks he can accomplish the conversion by getting a few of the parts from the LP model and then modifying the rest. The orifices are basically the same, only the LP diameters are different. Theoretically, the ports could be filled and redrilled, but the hardware store was fresh out of 1.07mm bits, so I'll pass on trying this on my own.
If anyone has a LP model they want to convert to natural gas, I'll gladly swap parts.
Jul 25, 2012 | Jenn-Air Kitchen Ranges
I have a Jenn-Air M170 & parts of the inner door have cracked and broken, exposing the interior metal. Can the door be repaired or do I need to replace the unit? Does Jenn-Air still make this model?
Yes you will have to replace it, and yes, i am fairly sure they still have that part in stock. please use the direct link below to ask and obtain the part you need.
Also please ask them for the service manual too, this will make the task ever so much easier.. However the replacement parts used to come with fitting instructions..
http://www.jennair.com/flash.cmd?/#/page/customerservice
Aug 19, 2010 | Jenn-Air M170 Microwave Oven
Need help re: replacing igniter of Gas Grill
If it is like mine, you have to remove the front control panel on the side burner and the front of the side shelf. Remove four screws behind the fronts below the shelf/burner and then you will have access to the screws to remove the main control panel. Be careful with all the hoses and gas piping. If the electronic ignitor is melted like mine(i am on #3), you have more problems than the igniter. I had to replace the burners and the gas valves to stop the flame from "backing up" into this area. Hope this helps.
Jul 10, 2010 | Jenn-Air Grilling
Parts for converting Jenn-air svd48600w frin LP back to NG
try google jenn air have a wed site or a shop that sells that make
Jan 19, 2010 | Jenn-Air JGR8850 Gas Kitchen Range
I need metal replacement stove knobs.
I was able to find online some metal knobs that MIGHT work, but the prices ranged from $30 to 60 EACH, and I needed 5 - too costly for me!
The following 3 plastic knobs will work on your Jenn Air range, model JGR8875QDS. By "work" I mean they will fit your burner controls, operate the burners just like the factory knobs, and the markings on the knobs for "Off" "Lite" and "Hi" will be in the correct positions, similar to the factory knobs. (Exception: The last knob listed has markings somewhat different than the Jenn Air knobs.)
The following knobs do NOT look like your factory knobs - all three are made from black plastic rather than the (fake) silver metal look of the (plastic) OEM knobs. What I cannot tell you is if the following knobs will be more durable than the factory knobs - but then it's hard to imagine how they could be much worse.
-------- Burner control knobs known to work on the Jenn Air JGR8875QDS gas range --------
1. Whirlpool part number 74008850, made for some Amana gas ranges, will fit the Jenn Air. RepairClinic.com calls it part #1035119, and PartsSelect.com calls Item #PS2086316; it sells for $6-7 (USD). You can see a photo by entering the appropriate part number in the search box of either of the two websites mentioned above. The Amana knob is about a quarter-inch larger in diameter than the OEM knobs, but that does not cause any problems. Of the several knobs I tried this is the only one that tells me what it's made from - "PBT" - or polybutylene terephtalate, a thermoplastic which has a melting point of 430 degrees F and a maximum utilization temperature of 330 F.
2. Whirlpool part number 74009094, made for some Maytag gas ranges will also fit the Jenn Air. RepairClinic.com calls it #1035342, and PartsSelect.com calls it #PS2086544. It sells for about $9 on both sites. You can see it here:
www.repairclinic.com/Appliance-Parts?s=t-74009094-%3d%3d
Like the Amana knob, the Maytag knob is about a quarter-inch larger than the OEM Jenn Air knob.
3. A third knob worth considering is available from AmericanStoveParts.com for $7 each. The front of the knob looks much like their OEM Replica Burner Knob 1104-B (but don't order #1104-B - it won't fit). The knob that will fit the Jenn Air is AmericanStoveParts #1214-025-B. You will have to order it by phone or email because it is not shown on their website. (As of October 2009, none of the knobs shown on AmericanStoveParts.com will fit the Jenn Air.)
Notice the markings on the 1214-025-B are not quite like the Jenn Air markings, with the "HI" and the "LITE" positions being reversed. Also, the 1214-025-B knob I received did not have the white dot at the "OFF" position nor the white ring around the periphery as shown in the photo of the 1104B knob. The total diameter of the the 1214-025-B is 2" - the same as the factory Jenn Air knobs.
While I don't think the front of 1214-025-B looks quite as nice as the Amana or Maytag knobs, the back of the knob appears to be much more robust than on the others. The extra plastic MAY make this one more durable.
I have installed the Amana knobs (#1), and I will report back if it proves unsatisfactory.
Dec 20, 2008 | Jenn-Air JGR8875QDS Gas Kitchen Range
Converting a range from LP to Natural gas
Yes, it is possible.
You have to get the right orifice's for Natural gas. LP gas orifice has twice the size hole as compared to Natural Gas. Using it without the right orifice will put out way too much gas, and you will burn everything, as well as it will be a fire hazard.
Your local gas company or propane company should be able to get you the right orifice
Please rate this solution.
Jul 31, 2008 | Jenn-Air ® 48" Professional Over The...
Jenn air propane grill conversion
It is inconceivable to me that large manufacturers like Jenn-Air and Nexgrill can jointly make and sell an expensive grill and then completely abandon the consumer. I purchased an Jenn-Air 740-0142 LPG and like so many wanted to convert to nautural gas which requires a larger gas orifice. I spent a month on the internet and phone calling Jenn-Air and finally Nexgrill who actually manufactured the unit in China. The Jenn-Air and Nexgrill serial numbers are the same. the 740 prefix is LPG and the 750 prefix is natural gas. After three calls to Nexgrill I found a manager who actually acknowledged making Jenn-Air but declined selling me parts for it as I believe they have product liability concerns. I call back as a Nexgrill owner and finally ordered natural gas orifices at $10.00 each. The shipment never showed up. Calling back again I was told that they really didnt really have any orifices in stock but could sell me the entire replacement gas valve for $28.00 which I purchased. The valves actually arrived on the shipping receipt was from The Grill Services in City of Industry 909-718-6128 www.grillservices.com . Part number 750-0141/142/593/594.
Forget about pirates in Somalia... we have them right here. Shame on you Jenn-Air and Nextgrill.
Mar 12, 2008 | Grilling
LP Conversion for Jenn Air CVG316 (about 10 years old)
I have the same stove and I got the LP Conversion Kit at Sears Part Direct.:
http://www.searspartsdirect.com
Thisis the Part Number for the LP conversion for the Jenn-Air CVG316B: Part# Y04100687
Hope that can help you
Eddie Rentas
Tupper Lake NY
Nov 21, 2007 | Jenn-Air Cooktops
JENN AIR LP CONVERSION PROBLEM
I'm not aware of any "choke". I would put the orifices in and see what you get. Make sure you put each orifice in the correct burner or it won't work. They are different sizes. Smallest hole goes to the smallest burner and so on. Let me know how it turns out.
Oct 10, 2007 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Grilling Logo
160 people viewed this question
Top Jenn-Air Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Jenn-Air Grilling Expert? Answer questions, earn points and help others
