Question about Whirlpool AD25BBR 25 Pint Per Day Dehumidifier w/ AccuDry Sensing System & EZ-Empty Bucket Humidifier
How to use it was left in my new house - Whirlpool AD25BBR 25 Pint Per Day Dehumidifier w/ AccuDry Sensing System & EZ-Empty Bucket Humidifier
  • 15,935 Answers
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 04, 2010
Aprillaire 760 leaks from the bottom left of the case. panel is new, drain is clear, all vents open in the house, the panel cage is free from excessive scale. Any ideas?
Here is a link to your humidifier http://www.iaqsource.com/article.php/my-aprilaire-humidifier-is-leaking-what-to-do-about-it./?id=35
Oct 19, 2011 | Aprilaire 700 Humidifier
Left bottle will not empty before the F button comes on what should i do
If the unit is on carpet, use the caster feet supplied with the unit. The weight of the bottles causes the front of the unit to be lower than the back. This prevents the sensor from switching bottles, causing the left bottle not to empty. The caster feet keep the water sufficiently level for the sensor to work.
Here is another thread on the matter.
http://www.fixya.com/support/t135482-left_tank_empty
Dec 20, 2010 | Essick Air 447 302 Console Whole House...
HE365 new pad installed by tech. He checked drain tube outside and said it was pouring out water so he tappered back the hot water supply. Set the humidifier to 40% and left. During the evening I set it...
The saddle valve that controls the water is only to be used as an "on" or "off" control. It is not recommended as a throttle valve since it can leak if it is not placed in the full open or fully closed setting
Dec 05, 2010 | Honeywell HE365 Humidifier
How do I change the filter on Sunbeam Model SCM 2412 humidifier?
Turn the unit off and disconnect from the electrical
outlet.
2. Remove the tank from the housing.
3. Unlock the housing from the base by turning the lock
knob to the unlocked position.
4. Lift the housing straight up and place to the side.
5. Unlock the wick holder from the base by turning the lock
6. Remove the wicks from the wick holder.
7. Follow the weekly cleaning instructions.
8. Insert new filters into the wick holder and lock the wick
holder back onto the base.
9. Replace the housing onto the base and lock it into place.
10. Fill the tank and place back into housing.
11. Repeat Operating Instructions.
It will take about 30 minutes for the humidifier to reach
Nov 03, 2010 | Sunbeam (0013871361) Humidifier
Have a large new house with lots of vinyl clad wood double hung windows on a lake temp today this am is 0 F we have a HRV system house temp is 66 downstairs and 58 upstairs heating with a heat pump and...
Really not efficent to run a heat pump at those temperatures. Below freezing is not good for the compressor in the outside unit. The humidity in the house with the low temp. is causing the condensation on the windows to freeze. Kinda like an air conditoner does in the summer without the freezing humid air from the house goes over the cold a/c coil and the moisture condensates on the coil running down to drain pan. raising the temp. in the house and lowering the humidity should help. I would also recommend running the electric heat in low outside teperatures.
Dec 17, 2009 | Aprilaire 600 Humidifier
I have ice or water at the edge of my windows. I
you may need new windows, you should keep your house between 35 and 45% humidity but if your windows are condisating on the inside and that condinsation is freezing then either turn off the humidifier or get new windows
Dec 10, 2009 | Aprilaire 600 Humidifier
My whole house unit mdl #3500 leaks watter at the seam on the left tank when the tanks are toward you. the warrenty says 5 years and mine is about four, it has been leaking for the past three years but now...
Hey Tony, Thanks for the Question,
Does it specifically state that that replacement is 5 years or just parts? you have to read the fine print sorry to say, but if it is the whole unit then yes, they will replace the whole thing,
If its parts only then maybe they would send you out a new tank which more than likely would solve your problem too! hope that was helpful, let us know and please leave some feed back on how we did, thanks again,
mr.grzz
Jan 22, 2009 | Holmes Products Cool Mist HM3500...
Bonaire BCM-645
To replace the filter, follow the steps below
1. Turn the unit off and disconnect from the electrical outlet.
2. Remove the reservoir from the housing.
lock knob to the unlocked position
place.
10.Fill the reservoir and place back into housing.
11.Repeat Operating Instructions It will take about 30 minutes
for the humidifier to reach maximum output. You
can purchase replacement filters (model BWF100 filters)
at your local retailer, by calling 1-800-253-2764, filling
out the accessory card, or by visiting
www.bionaire.com. It is recommended that a
replacement filter is purchased for uninterrupted use.
Here is a link for the manual for your humidifier:
http://www.appliancefactoryparts.com/content/pdfs/117223.pdf
Good Luck.
Apr 24, 2008 | Crane Frog EE-3191 1 Gallon Humidifier
Humidifiers Logo
42 people viewed this question
Top Whirlpool Humidifiers Experts
Mack Baxter
Dennis
Are you a Whirlpool Humidifier Expert? Answer questions, earn points and help others
