Question about Samsung MW5580 Microwave Oven
I have a MW5582 Microwave Oven and about a week ago our apartment had a power-outage that lasted for a few days. After the power came back on, the Microwave still turns on, and runs, however, it does not produce heat. Is there a setting that got switched off or is it hopelessly broken?
  • 600 Answers
Most likely the surge blew one of the 2 diodes inside, if you know basic electronics it it an easy fix
Posted on Jul 15, 2010
Testimonial: "Thank you, is Diodes another word for Fuse?"
My GE Profile Jvm1870sk03 microwave built oven does not work. There is power, the clock, timer works. If I press the button to heat the clock shows it's going on but there is no heating process go
Most likely door switches. Companies these days use switches with small 3/16 terminals and they tend to get hot and make the switch go bad. When I replace them I put in a 20 amp rated switch with 1/4 inch terminals, and a short section of better wire to the switch. If you make better connections it stops the wires from getting hot and the switch will last a long time.
Aug 24, 2017 | GE Microwave Ovens
After a short power outage, I have clock issues.
this a problem with the clock , but the microcontroller can be defective by the power outage, see the diagram . how the microncontroller has the control for any equipment.
IN SHTE M.CONTROL BOARD CAN BE DEFECTIVE. go to the repair shop Tv FOR FIX IT. God bless you
Jul 19, 2012 | Microwave Ovens
Wont start monitor say press start look like a battery symbol
There is an battery inside to keep time and settings in case of a power outage.. Check your maual for the battery location.. Unplug the oven,, replace battery and plug it back in..
Have a great day !
Apr 09, 2010 | GE JVM1540SMSS Microwave Oven
We had an power outage and lost power for a few hours everything came back on but the microwave. I checked the outlet and checked the fuse still nothing. Is there anything that can be fixed?
Hello if you have no power at the outlet, you may have saved your microwave. If the outlet is dead go to your house electrical panel and reset the breaker or replace the fuse. if the outlet is live and the microwave still won't power on you will have to choose between repair and replacement. Definitely get an estimate before agreeing to a repair as microwaves are very inexpensive today compared to even a couple of years ago.
Nov 23, 2009 | Emerson MW8108P Microwave Oven
GE Microwave/Convection Oven - Door Glass Just Exploded!!!
This happened to us 3 weeks ago with our 3 year old Kitchenaid microwave. Several hours after its last use it just shattered. In doing research I discovered that this has also happend with GE microwaves, all 3 years old. The cause seems to have been a batch of defective glass supplied by a third party. Whirlpool was very quick to cover the cost of the replacement, even though our microwave was out of warrantee.
Aug 27, 2009 | GE JEB1095 Convection/Microwave Oven
Microwave doesn't heat anything
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food.
The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing.
There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however.
Benjamin
Apr 19, 2009 | Frigidaire GLMV169D Microwave Oven
Microwave runs but does not heat.
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose conneciton on the control unit circuit board
- bad magnetron or other high voltage part
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
For more help from Emerson http://www.emersonradio.com ; Get help using your appliance 1-800-898-9020 ; Get help locating a servicer or parts 1-800-695-0098.
Aug 12, 2007 | Emerson MW8107WA Microwave Oven
Reset Microwave after a Power Outage
If its part of the house your renting, call the landlord as its most likly a control panel went bad, and in this unit, thats probably going to exceed the cost of the microwave oven. If its a rental oven, take it back.
Sep 11, 2006 | Goldstar MV-1526 Microwave Oven
Microwave Ovens Logo
93 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
