Hi, i have a pioneer SA-6500II intergrated amp, need a sort out, in general a new volume swith as it is running on basically mono sound ( only one channel) cheerz joe
  • 121 Answers
Hi Joe, Pioneers have a relay which need to be cleaned fairly often. It is usually near the center of the main board. You will need to remove the plastic cover, and I use contact cleaner on paper wiped between the contacts.
Posted on Apr 21, 2008
I have 2 pioneer 6x9 400w, pioneer GM 6500f 760w amp and a kenwood KFC W1012 sub, how d i get the best sound from these?
pioneer gm 6500 is a 4 ch amp rated at 60w-4 way to small of an amp to run your sub. UNDER-POWERING your sub is more likely to damage spkr than over-powering. my advice,get mono-block to run sub
Jan 04, 2013 | Pioneer 6X9 5WAY 400W SPKR Car Speaker
Haveing trouble wireing a Pioneer A-400X INTERGRATED AMP, Need the user manual really.Where can i download tthis manual can you help. .
I can't find the manual but there's no real mystery to any generic stereo amp.
http://hifi4sale.fullboards.com/t5345-pioneer-a-400xusedsold
OUTs go to INs.
Just about any standard output of an audio device will connect to any Input on theamp EXCEPT PHONO, which is for a turntable.
Tape loops are for tape decks or sound processors like equalizers. When a tape loop is selected the program goes out, gets processed and comes back - all before any volume or tone controls.
May 21, 2011 | Pioneer Audio Players & Recorders
Hi can I hook up my marantz mm500u amp to my pioneer 305 vsx audio reciever
I presume you just want to slave the Marantz to play whatever the Pioneer is playing.
Run a pair of RCA cables from either the Pioneer Tape Monitor REC or the VCR/Tape 1 Out jacks to the desired Marantz Input jacks. DON'T activate the corresponding switch on the Pioneer.
Only the basic Leftand Right channel programming that the Pioneer plays will be available at the Marantz. You will NOT have centralized volume control at the Pioneer.
Mar 17, 2011 | Audio Players & Recorders
Subs just rumble at higher levels...??? help!
there is a loose piece inside my 10" cozmik series. how do i get it out?
Mar 12, 2010 | Quantum Audio Cozmik QCA2300 Car Amp
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
Pioneer car audio amp GM 6300F (new)
Does your amplifier have a Channel swith which says 2/3/4 channel mode. If so and you are running the amplifier in Bridged mode, try changing the setting to 2 channel or Bridged mode.
Aug 20, 2009 | Pioneer GM-6300F Car Audio Amplifier
Pioneer 800w mono issue
It can be many things it possible the amp cannot handle the 4 ohm load and simply goes into power protection mode. Also make sure your using the correct gage wire to run power from your battery to the amp to thin and it wont have enough power to perform.
May 09, 2009 | Pioneer 800W Class-D Mono Amplifier With...
Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Oct 30, 2007 | Audio Players & Recorders
PANASONIC SA HE9 RECIEVER 5.1
If the sub has a volume control, turn it down then turn up the volume on the amp to the very high volume you mentioned. If it still has very low muffled sound, then we know the problem is about the amp.
Apr 24, 2007 | Panasonic SA-HE90 Receiver
62 people viewed this question
 Grubhead
Grubhead
