Question about Yamaha Electrical Supplies
My EF3000 has a dead battery & I don't know how to charge it. The Generator will no start using the "pully"
  • Yamaha Master
  • 5,603 Answers
Use a standard battery charger set to a low setting like two amps for a few hours.
Posted on Jul 25, 2010
Why poulan pro riding mower wont charge
First check your battery, make sure the cells are good and no bad cells. If that is good then the issue is under the flywheel. There is a coil under your flywheel that serves as a generator. You can just purchase a 2 am charger with a breaker, that will kick out when battery is charged and hook that up after each use. If you jump a unit or charge a unit with more than 2 amps, you can burn the generator coil out under the flywheel. Also check the magnet under the flywheel. I have seen them come out.
Aug 24, 2014 | Poulan Garden
I have a homelite 720 generator but cant fingd the instruction manual and i need to know if the charger leads only charge a battery or can be used as jump leads i know this might sound stupid but i wo
I can't find any reference to a Homelite model 720 generator but most battery charging systems do not supply enough amps to run a car starter. Battery chargers usually work in the two (trickle) to ten amp range. Car starters need way more amps to have enough power to turn an engine over, depending on the size and number of cylinders in the motor. Some chargers have a switch with a 60 amp 'start' position to help the battery turn the motor over, but without that there is little chance the charger side of your generator will supply enough amps to help your battery.
Feb 21, 2012 | Cars & Trucks
I pack my car this morning and when i came back to stat it it couldn,t.so it was jump started. i drove for less than one mile and and it went off again. i recharged the battery again, i drove...
3 possibilities are:
  • Dead cell in battery; a battery with a dead cell won't accept a charge from the alternator
  • Bad alternator; if the car will run on it's own without stalling, the alternator is probably still good; if the car stalls you may have alternator problems
  • Bad starter; (assuming you've ruled out alternator problems) a bad starter will start when the car is cold; once warm, it requires more power to engage than the battery has therefore, it needs a jump start
I'd advise bringing the car to a shop (most autoparts chains will do a free electrical system check) and have the electrical system checked.
Jul 20, 2011 | Isuzu Rodeo Cars & Trucks
I have a 96 blade,starts & runs well...but run with lights on & when i go to start her again its if the battery is dead.
It must not be charging, probably need to check the generator and the battery. It might be time to replace them both.
May 29, 2011 | 1993 Honda CBR 900 RR Fireblade
1982 Yamaha XJ 550, the battery will not take a charge. New battery, checked all connections, ran all the tests (stator, brushes, and alternator). Replaced the voltage regulator/recifier. Not sure what is...
It is corrected properly, right? + to the wiring harness and - to ground ... right? Are you certain about the rectifier? Is the battery charged at this time?
You know a alternator cannot make power unless you first put power into it ... right? Alternators (unlike most generators) are not self exciting. If your battery is weak or "dead", the alternator cannot make electricity to charge the battery. I don't know what the rating of your alternator is. Your battery should be fully charged before you do any more tests. If you have a 1 amp charger, allow at least 10 hours for a full charge. Don't cook your battery with a big, powerful, fast charging automotive battery charger.
Good luck with your repair ... I hope you find this response helpful.
Thanks for your question @ FixYa.com
May 02, 2011 | Yamaha XJ 650 Motorcycles
I have a 5000 w maxa ER generator that has a battery assist added ( PM 0525312.17 ) Question...Is the battery a regular 12v car battery, or maybe a lawn tractor battery?? Once the generator is started...
Replace battery with your choice of 12v products considering physical size, amp range and warranty. Lawn tractor batteries seem to have the least life/duty cycle. There are two methods of charging the battery used by Coleman. One is to charge the battery with charger/alternator coils installed under flywheel of the engine and second is to charge with built-in circuit in generator itself. Examine your wiring diagram to discover which you have. Simple test with volt meter will show if system is charging. Test voltage at battery with engine off, then start engine and retest looking for slightly higher voltage indicating charge. The charging system is like a trickle charger and not like your auto with initially high amp charge then taper to minimum. If your run your generator for long periods of time and you feel that the battery is being overcharged, then rig a switch to stop charging after one hour or longer. Good holiday
Nov 27, 2010 | Coleman Powermate Powermate 5000W...
Generator light on 1996 jeep cherokee. what does
First clean the battery terminals & their connection to the battery. Check to see if the alternator belt is tight. Once started, connect an amp. meter to thebattery terminals. Black to black, red to red. If the reading is over 13.2, alternator is charging. If it is not, change the alternator. If it is over 13.2, you may need a new battery. Have a load test done at any reputable automotive store. Hope this helps & if it does please do the right thing & recommend this advice. Thanks
Nov 14, 2009 | 1996 Jeep Grand Cherokee
I have a troy bilt riding mower, 6 years old, 26
many of these units use the starter motor as the generator to re-charge battery. check voltage regulator & wiring.
Sep 28, 2009 | Garden
Husquavarna tractor battery won"t start engine
YOU NEED TO REPLACE THE SOLENOID IT IS SHORTING OUT AS TO THE GAUGE THEY WILL NEVER MOVE AS THE GENERATOR CHARGES ONLY WHEN THE BATTERY HITS 9 VOLTS THEN IT ACTIVATES TO CHARGE BACK TO 12 VOLTS BUT IN SMALL INCREMENTS
Jun 25, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Electrical Supplies Logo
106 people viewed this question
Top Yamaha Electrical Supplies Experts
John Trevino
jmt
Level 1 Expert
Craig Butler
Craig Butler
Are you a Yamaha Electrical Supply Expert? Answer questions, earn points and help others
