Notebook is not set-up to automatically connect to wireless internet
  • 871 Answers
Go to network connections and follow the network connection wizard... this will help you configure your wifi internet.
Posted on Apr 20, 2008
Breaker box went out where wireless router is plugged in and when we turned it back on, the HP notebook pavilion g7 won't connect to wireless. Message says the computer settings don't match t
Power on the laptop computer and wait for the operating system to boot. Right-click the wireless Internet icon in the lower right corner of the desktop. This brings up a new pull-down menu. Select "View Available Wireless Networks." This brings up a selection of different possible Internet connections that are in range of the computer. Select the wireless Internet connection you want to use. If a password is required, you need to type it in now. Wait for the laptop to connect to the Internet. In a moment the computer is going to state it has successfully connected to the Internet. click Start, Run type in cmd and click Ok to bring up a command prompt. Type ipconfig /all and press enter and see if it gives you an IP address similar to 192.168.1.100. Check your wireless connection properties under My Network Places. Right click the wireless connection icon and choose properties. From there make sure Internet Protocol {TCP/IP} is listed, highlight it and click properties. Make sure Obtain an IP address automatically is checked and Obtain DNS server address automatically is checked. Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled if still no joy Let's first try to start the wireless service i.e. WLAN AutoConfig service manually. To do this, login to the computer as an administrator.
1. Click Start, type services.msc and hit enter.
2. Locate WLAN AutoConfig service, double click on it to open its properties window.
3. Under General tab, change the Startup type to Automatic and click Start button.
4. Click Apply and then ok. For more information about the wireless settings, check this link: http://technet.microsoft.com/en-us/library/bb878035.aspx Hope this helps.
Dec 29, 2012 | HP Pavilion G7-1227nr Notebook 4gb Ddr3...
Can't connect to internet wirelessly or thru ethernet
Check to make sure settings to obtain settings automatically are correct
Control panel / internet options / connections / lan settings / tick automatically obtain settings
Jul 17, 2010 | Acer Aspire One Netbook 8.9" Notebook
I formatted my system and reinstalled Win XP on it, but now I could not use wireless to connect with internet
Make sure you have Wireless network adapter driver installed.
Manually assigned IP address and DNS address as earlier (if your IP setting is not automatically assigned by DHCP server).
If you are using router set your Router IP address as your Default Gateway Address.
If you are using Internet through a Proxy Server then Open "Internet Explorer ",
Click "Tools",
Click "Internet options",
click on tab called "Connection",
Click "Lan settings" Button.
Remove "Automatically detect settings".
Tick "use a proxy server for your LAN....."
Type the IP address of your Proxy Server and the port no.
It will work.
Dec 26, 2009 | ASUS A8HE-X1 Notebook
How do i set up internet connection for my acer laptop after resetting to factory settings
Hi.
Check your Device Manager if your internet driver is installed. If it appears yellow (?) in the internet folder, your CD that goes with your unit can install that. If you try intalling that, open an internet explorer if it doesn't try Mozilla.
Second try to open start menu and click all connections. Click wireless portion and set to IP properties that will automatically detect IP address.
Set to enable... Then browse... Enjoy...
Dec 10, 2009 | Acer Aspire 5735-6694 Notebook
Cannot connect to the internet
how are you trying to connect it? if you have wired internet, just plug the LAN cable at the RJ-45 LAN port of your laptop and you will be connected. You must have set your LAN Adapter to get IP Address automatically. Also, if you have a wireless network adapter, if you set it up to get IP address automatically, you can connect to available wifi zone.
Sep 15, 2009 | Apple Powerbook G4 15" Screen Mac...
LAN internet connection problem in COMPAQ V 3000 notebook
Just connect the lan cable from the modem port saying "DataIn" to your laptop, select Automaticaly detect IP setting and let it assign via DHCP. Once it gains the ip (usually 3-4 minutes) use any java enabled browser (like ie,mozilla firefox) and go to any site it will automatically redirect you to Tata Indicom login terminal and fill in the required blanks and you are connected to the internet.
Jan 19, 2009 | Compaq Network adapter
Laptop wireless connection
assuming you have set up the router to enable DHCP which automatically detects pc's and assigns an automatic ip address, and assuming you are using XP and not Vista, although the workthrough is similair; go to open internet explorer>tools>internet options>connections tab and ensure that never dial a connection is ticked, then apply and exit IE
Next go to control panel>network connections, double click your wireless connection icon, select the TCP/IP line and click properties, then make sure obtain an ip address automatically is ticked, apply it ok, then open IE again and click the refresh button a few times.
Sep 01, 2008 | Toshiba Satellite A100-S8111TD Notebook
Wireless
It depends on your lap top model weitheer you can turn it off. You could alwasy go innto internet explorer under connection settings and setup a fake dial up connection and make it the default connection. This will make it ask for permission before attaching to a wireless conection. I have windows XP pro on a laptop that I cannot turn off internet but it aslway ask before anyway because i have it set to connect to preferred networks only.
May 15, 2008 | Acer Aspire 5520-5908 Notebook
CONNECTING TO WIRELESS INTERNET
hi check u install your wireless lan driver are correct.
check your dns and ip setting if they needed to connect internet.
othyerwise set it to automatically.
check your router and wlan configure properly.
Mar 25, 2008 | Compaq Evo Notebook N115
Computers & Internet Logo
20 people viewed this question
David Payne
David Payne
