Question about Endless Summer 62900 Open Flame Patio Heater
Endless summer 62900
Can you hook heater to a propane tank?
  • Endless Summer Master
  • 3,253 Answers
If it is converted to lpg if not no
Posted on Jul 14, 2010
Do you place the propane tank in the heater base
The gas tank should sit inside the housing on top of the base. There is usually a cut out section to allow access to switch on/off the tank. Always best to switch the tank off when not in use. If you need some more info found this site very useful patio heater gas.
Nov 28, 2011 | Endless Summer 1501 Patio Heater
I have a full tank of propane - my pilot light is sparking but it will not light? Any ideas on what to check? Thank you, Korby
Korby, I think you meant, your ignitor is sparking and you're not getting gas to the pilot. Since you have a full tank of propane, I can rule out that the tank is empty. However, I believe the tank or at least the tank valve is playing a role in this.
Turn the tank valve completely OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY, VERY SLOWLY (Slow Motion, slow) until the valve is fully open. Then light the pilot as you normally would. If the pilot lights, you solved the problem. If it didn't, either the pilot light is clogged and needs to be cleaned or the heater's hose/regulator assembly needs to be replaced.
Endless Summer Patio Heaters are made by Blue Rhino. So, if you need parts, that's where you can get them. Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
May 09, 2011 | Endless Summer 153100 Open Flame Patio...
I have an endless summer 92000 table top propane heater. Lights fine, but the flame does not burn at the edge of the burner. Instead, it only burns in the very center of the burner... much like a Bunsen...
Actually, it's a gas pressure issue. But, it's fairly easy to solve. First, you need to be sure that your LP Tank has a sufficient amount of gas. If it does, turn the propane tank valve OFF. Disconnect the hose from the tank and wait 5 minutes. Then reconnect the hose to the tank and turn the valve ON VERY, VERY SLOWLY (Slow motion, slow). Once the valve is fully open, light the burner as you normally do and turn the burner flames to HIGH. Has the burner flame returned to normal? If so, you solved the problem. Just remember to always turn the tank valve ON very, very slowly.
If it didn't solve the problem, you will need to replace the heater's hose/regulator assembly. Generally, i's the same type that a gas grill uses. So, it won't be hard to find one.
Hope this helped to troubleshoot and solve your problem. Please let me know.
Apr 30, 2011 | Endless Summer 92000 Table Top Patio...
I need to convert a Endless Summer Blue Rhino patio heater Mod. No. 233010 from naturalm gas to propane , what do i need
You would need new pilot and main burner orifices. You would also have to ask the dealer/manufacturer if the valve on the propane heater will work with propane. It may not because the propane tank will have to be connected to the heater using an LP hose and regulator. You would then need to take apart the heater to install the new orifices. Considering the cost of a new heater that is set up for LP, I do not believe the conversion to be practical.
Feb 24, 2011 | Blue Rhino Uniflame - 233010 - Endless...
The heater works properly for about 30 seconds and then the gas just shuts off. we have tried multiple propane tanks.
There should be a flame sensor somewhere near the burner it will be a single wire going to a steel rod. Try cleaning this.
Dec 13, 2010 | Endless Summer 200209 Open Flame Patio...
Endlessly pushing the ignitor button
In reading about ventless propane heaters a month ago or so, most require a 100 pound or larger propane tank so there will be enough pressure. Could that be the problem?
Nov 03, 2008 | Heating & Cooling
Endless Summer Patio Heaters won't stay lit
Hi ColdinSF,
You need to remove the covers from the unit and blow out the gas lines with compressed air. If you can remove the gas lines blow out the lines and what they connect to like the pilot light and main feed line to the burner. Usually they gunk up with use and just need to be blown out with compressed air to clear the lines again. Maybe you have some dirt or foreign object from your gas tank which has clogged the line. Also check the igniter electric lines as well and make sure everything is connected properly. Especially make sure you tighten the gas lines you remove. Hope this helps.
Regards
Bryan
Oct 19, 2007 | Endless Summer gwt501a Open Flame Patio...
Endless Summer 62900 Open Flame Patio Heater Logo
43 people viewed this question
Top Endless Summer Heating & Cooling Experts
Paul Carew
Craig Butler
Craig Butler
Are you an Endless Summer Heating and Cooling Expert? Answer questions, earn points and help others
