Question about kawasaki Full Suspension Mountain Bike Men
I have a 14 HP Kawasaki engine on my John Deere lawn mower (LX176). I have no spark.I'm guessing coil but unsure of how to test it. I get readings through the windings with an OHM meter but I don't know what it should read. I wish I had a wiring diagram for the lawn mower to better analize the trouble. Suggestions?
    Problem Solver:
  • 11 Answers
All the "safety" engine-kill "features" on this mower will ground the ignition system, stopping the engine and causing a no-spark condition. Check the seat switch, the brake switch. Also, the circuit board will cause the problem you have if it gets rained on, (the mower hood does not protect it); point is do not let the mower get rained on (or washed) unless you protect the PC board, which is right behind the ignition switch. Mine dried out and worked again but only after liberal spraying with (plastic-safe) electronic parts cleaner. You are right the manual would help, it's like $76 but it's in depth. Good luck, and PLEASE tell us what the solution was! -Tom
Helpful Deere lx176, lx178, hood hinge tip: If the hood hinge is broken on yours like on most, Deere has a GREAT repair kit that's only $10. They really priced it at cost or less to correct a defect they are aware of.
Posted on Sep 20, 2010
Can someone guide me through troubleshooting this ie which safety switches to check etc.
try a new spark plug. they breakdown over time. if still no spark unplug the wire under the coil. if it does not have spark now replace the coil. if it does have spark you have a bad switch somewhere.
Oct 30, 2016 | John Deere Garden
Tip
Mower belt diagrams 2
john-deere-54in
John-Deere-CA130
John-Deere-Gt235-54
John-Deere-LX176
on May 20, 2015 | Garden
I have a 214 kohler engine john deere lawn tractor, what point wires go to hot and the ground
if that is the Kohler 14 hp motor it may have the spark control untit on the motor cover. I recently ran into one like that and switched the coil out from a blown 20 hp kohler engine. I just taped up the excess wires and made sure they were not near any moving parts. The mower ran fine after that. Kohler wants about $160.00 for a spark control unit. There have been no repercussions since making the switch.
Apr 21, 2014 | John Deere Garden
John deere gx345 has no spark at plug what is the cause?
need new coil pack or have short in harness grounding engine from running. check fuel line to carburator. 1. take float bowel off bottom of carb. do not touch float or pin holding float. crank engine over until fuel comes out of carb. If fuel comes out, you don't have fuel problem. put float bowel back on carb. 2. check for spark. take spark plug out of mower. put wire back on plug and place the threads on head [or metal of engine to ground the plug]. crank engine over for a few seconds to see if plug gets spark . [always double check with another spark plug that is good]. [[ Remember!!! you have to have someone sitting on the lawnmower to start. unless you by-pass safety switch [only do this if you understand how the safety switch works. NOT EXPLAINED HERE!!!]] If spark is present, there is no grounding problem. when engine is cool. 3. CHECK COIL PACK. for continuity. When the coil pack gets hot it will stop any juice to the plug. A>Check temp sensor B> Check Safety switches grounding out. C> Check for cut wiring harnes. [loose wires rubbing against pulleys, wires cut by rodents]. Hope this helps.........................GAS
Jun 13, 2012 | John Deere 420,1020,2010,2020,2510,2520...
Need carburator ajustment / john deere lx176/14hp kawasaki
i have 14hp kawasaki that backfire throw the carb and exhaust what could it be
Jun 05, 2012 | Garden
I have a John Deere riding mower Model RX75 which will not start, I replaced the spark plug and it ran just fine for one day except that it Back-fired when I shut it off it never did this in all the years...
Weak spark can be caused by a bad ignition coil. The ignition coil is located under the engine fan/shroud, next to the flywheel. Check to make sure the coil lead and plug cap are not grounding against the engine robbing your spark as well.
Aug 03, 2011 | John Deere Garden
Have a john deere lawn tractor. Blade will not
Check both belts on deck. Check if the clutch is clicking in. If not it will most likely need a new pto switch.
Sam
Aug 10, 2009 | John Deere Mower Blade 5 each
kawasaki Full Suspension Mountain Bike Men Logo
1,949 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
michael
michael
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
