Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas
We have a rinnai 1001 ft it goes on green light red light all is ok then after a few second all goes off. What do we do to make it work do we have the landlord look at it are there operational brochures still available? thanks
    New Friend:
Try removing the Main Switch (1001f-1604 #22 on part manual)
clean it with Mufti-purpose anti-static cleaner...I used several tooth pick which removed black stuff off the slide slot. Once clean let dry and reinstall. This fix might save you $2000. Good Luck.
Posted on Dec 01, 2013
  • Bill Bernsen
    Bill Bernsen Dec 08, 2013
    It shut down again after a few days. This time I removed the main switch and disassembled it completely There are two contact strips which were dirty, black stuff again. I cleaned them with q-tips reassembled it. Seems to be working fine.
    Novelist:
  • 120 Answers
Tda9380ps/n3/3/1664 using sharp set power ok after 5 second on set goes to stand by mode automatically and front led in red.please help me about the problem send circuit diagram through email thanks.
tda9380ps /n3/3/1664 using in sharp tv power supply ok ,but no EHT ,the power LED are glowing red light press program key to change green light to return in few miniutes to standby in red light. Ple help me
Jan 13, 2018 | Sharp Televison & Video
Hi I have an old Rinnai RCE 417H natual gas unit
needs a service a clean and check of the ignition secquence. should only have green light for power and red light for Lighting. large screen can be bought from Rinnai part supplies
Jun 14, 2011 | Heating & Cooling
I have an older Rinnai RHFE-1001. I can turn the unit on and it seems to work great - both the red and green lights come on. Problem is that during the night it shuts itself off and neither light comes...
Yep! you should first change out the three gas solenoids. If it continues, change the variable resistor (slide temp indicator). You can order the parts direct from Rinnai at 800-621-9419 using a major credit card. Make sure you have the exact model number. You want to ask for the SV1, SV2 and SV3 solenoids.
Apr 13, 2011 | Rinnai Heating & Cooling
Replaced bulb yesterday worked fine. Today light will not turn on. projector turns on both lights green for 10 seconds, then power goes red and status blinks green for about 5 seconds, then status light...
green green is power on, normal
then it tries to light the lamp, but it can't so the protection circuit comes activated.
you get red and green blinking
Then it goes to standby, red and off.
so something has happened to the lamp, or lamp ballast power supply.
Take the lamp out and check if all is OK with the 2 terminals in the connector, and the leads to the lamp are intact.
Failing that, I would suspect the ballast lamp power unit
Mar 25, 2011 | Mitsubishi HC1600 Projector
Have inherited a Rinnai energysaver 1001 FT gas heater - need an exhaust manifold
Found a link to the service manual for starters
http://www.rinnaisales.co.nz/tradesmart/rinnai2/pdfs/service_info/225.pdf
The flue system looks very similar to some current models. I'd go to Rinnai direct and try and get a list of local service agents who can order the bits in. The flues are very tricky to order because there are so many different bits depending on where you need it to run so order carefully.
Jul 30, 2010 | Rinnai Heating & Cooling
We have a rinnai 1001 ft it goes on green light red light all is ok then after a few second all goes off. have found that if we turn on the gas stove during attempts at turning on the heater it fires up...
Hate to lead someone to some random solution without nowing more details but I had the exact same fault and symptons to sort out last year. On that particular one it was the gas regulator on an LPG supply. I found that a fault on the regulator caused it to lock out when the high demand from the heater kicked in, especially in the colder weather. If the customer started the gas demand gradually, using the gas cook top, all worked ok. I never really understood the how on this one but I just changed the regulator, making sure the new one was well oversized for the demand. New regulators just don't seem to be reliable anymore!
Hope this helps, at least if your at the stage where you just want to try something it gives you an option.
May 25, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
When heater first turned on light is green then turns red
Yes this is OK. The green light is showing you that you have power. When the light goes red it means that the burner is alight.
Cheers
May 03, 2010 | Rinnai EnergySaver 556 Air Conditioner
Rinnai Energysaver 1004F on indicator light is red (usally green)
If its not producing heat, yep! If it is, it indicates that there is an error code stored in memory.
Feb 18, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Have an old Rinnai Gas Heater (approximately 30 years old) still working well, but we had to turn off the gas, and now cannot turn it on again. We have two buttons, one below the other, one is red and...
You are half-way right, to light the pilot, light it and push down the red button and hold it for at ----least2-minutes-- till the flame heats up the pin (thermocouple- which fire-thermocouple metal makes electricity which sends it to the gas valve and says ,OK GAS VALVE,I'VE GOT A PILOT FLAME SO OPEN UP THE MAIN GAS VALVE! See where I'm going with this?
Sep 03, 2008 | Rinnai Heating & Cooling
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - LP Gas Logo
778 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
