Question about Siemens SpeedStream Modem (4100) (SS4100)
I can't get my Siemens SpeedStream 4100 to work with my new AT&T DSL service. I used to have DSL through a local company, Humboldt Internet, but they stopped offering DSL and sold off their DSL customers to a larger, not-so-local company, Everything went smoothly through the transition and afterward (except for some billing issues). Then increased the price to $55.00 per month for a basic 1.5Mbps connection package, which is just bloody ridiculous, so we decided to switch to AT&T. AT&T said that the SpeedStream 4100 should work fine and we did not need to get a new modem, so we didn't. On Monday Morning, 2:40am, turned off our service. On Monday night, AT&T turned on our service through them, but we couldn't connect. AT&T tech support had us reset the modem with the reset button and try a couple of other things, but we could not get our computers to connect to the modem or access the configuration page for it. They had us trying to access the configuration page at We borrowed a motorola 2210-02 modem to get our AT&T account registered and get internet access to do some research into how to get the SpeedStream modem to work. I have downloaded a user manual for the SpeedStream that says that I should be getting an IP Address and Default Gateway of and a subnet mask of If I force those settings I still cannot access a configuration page at If I use "Obtain An IP Address Automatically" then ipconfig reports my IP address and Default Gateway as, with a Subnet Mask of, but I still cannot access the configuration page at or I have also tried accessing the configuration page at and just in case the modem's IP Address was one less than the computer's IP Address (like is the case when I'm connected to my wireless router... when trying to get the SpeedStream 4100 to work I have NOT been connected to my wireless router by the way, but am directly connected to the modem), but that also did not work. Does anyone have any other suggestions, or could anyone at least explain why the automatic IP configuration is coming up with such uncommon settings? Please help. Thanks.
  • Siemens Master
  • 16,841 Answers
When you are connecting to it, are you using the lan connection straight into the device? When you do that is it showing as at least connected to the device on the computer? You did not post the operating system but can you check the router address by using the command prompt and using tracert commands to see what it is listed as? If you are using windows 10 have you use the powershell command to reset the winsock? Did you use the 30 30 30 reset method on the device?
Posted on Feb 27, 2017
3 Suggested Answers
SOURCE: connecting to xbox live with a speedstream 4100
force the gateway on the xbox configuration... retrieve gate from command prompt of your pc depending on the os.
Posted on May 18, 2008
SOURCE: connecting to xbox live with speedstream 4100
TUrn on the computer with the speedstream 4100 connection, like you always would, then when on and fully booted, unplug ethernet from modem, plug in ethernet cord from xbox. Turn on X-box, then restore factory settings. Should work
Posted on Dec 04, 2008
Is the siemens speedstream 4100 a 56k modem
A 56K modem is used for dial-up internet.
A dinosuar.
56,000 Kilobits per second
The Siemens Speedstream 4100 modem is an Ethernet modem.
Jun 10, 2012 | Compaq Computers & Internet
Speedstream 4100 started flashing red or green
The problem is probably not your modem. The dsl or cable service is possibly out. DId you call your service rep for help? I would start there.
Feb 06, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
Will there be a problem adding Siemens speedstream 4100 to DSL?
u need to setup ur router to program it so ocnsequently u can connect ur pc to the router instead to the modem
1) so u need to prgram ur router by configure the required settings
2) u need to write down ur username and password inside router program
3) then u can be connected to the internet via router
good luck
Jul 27, 2009 | Computers & Internet
Siemens Speedstreem 4100 Modem Not Working
Try restarting the modem by either turning off the power button, or plugging out the modem power.
If the internet still frequently disconnects, it is most likely your ISP's (internet service provider) problem. Call them up with this issue, and they should either re-activate your internet for you, or give you a replacement modem for free.
Hope this helps, please rate and leave a comment ^_^
Jun 18, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Buying a use modem
Siemens SpeedStream Modem (4100) (SS4100) is better
May 30, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Problems connecting Siemens Speedstream 4100 to a non-AT&T ISP
The answer is Yes,speedstream 4100 cannot be used in bridged conditions for any other isp
Jan 29, 2009 | Siemens SpeedStream Modem (4100) (SS4100)
Siemens speedstream 4100 eternet ASDL modem
the password and the user name would be given to u by the company from where u have the taken the internet connection ....
Oct 30, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Speedstream 4100 does not work with router
you can't.
when the item name as modem/router. it means the main function is modem with added router function.
you can't connect 2 router/modem together. both need access to the internet and IPS for it function correctly.
however, you can connect 1 modem and one router.
Oct 19, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Wireless adapter ......need something compatible with a siemens router
you probably need another router such as linksys, netgear, belkin.. etc.
Nov 10, 2007 | Siemens SpeedStream Modem (4100) (SS4100)
Siemens SpeedStream Modem (4100) (SS4100) Logo
291 people viewed this question
Top Siemens Computers & Internet Experts
Prashant M
Prashant M
john smith
Are you a Siemens Computer and Internet Expert? Answer questions, earn points and help others
