Question about Cycling
How do i set up my velomann v1 07 cycle speedo i need the operational instructions to set up my speedo for bycycle thankyou
Heighten seat on alollo bycycle how do I do this
Contact local bike shop for assistance
Jul 11, 2014 | Cycling
Speedometer not working
Is the speedo electronic or cable operated? If cable operated there are a number of things to check. Firstly remove speedo cable from back off guage. Remove speedo cable from speedo drive generally front wheel. Check that the inner is still one piece, by spinning. If that is good you need to check if your speedo drive is functional. Screw cable back to drive, lift front wheel and check if cable inner is turning, if it is you may need a new speedo. (spring worn like my old Triumph.
May 30, 2012 | 2007 Bajaj Discover DTS-I
I want step by step instructions to build a leading link suspension for a bycycle
I suggest you hit the search engines. "leading link suspension for a bicycle" (spelled right)
Aug 09, 2011 | Cycling
I have a ce electronic system safe for which I have two keys. I dont remember how to use the combination battery operated code any more as I have lost the instructions. Can I download these instructions...
I have a ce electronic system safe for which I have two keys. I dont remember how to use the combination battery operated code any more as I have lost the instructions. Can I download these instructions from the internet anywhere? The keys have 128 written on them but I cannot find any further I.D numbers anywhere. Thankyou very much for your assistance
May 21, 2011 | Safe International Digital Electronic Safe...
How do I convert a two brake rollator to a one brake usage Its like a bycycle handle but i need a connection to maketwo cables into one,
I have an old tandem bicycle that has two sets of brakes, with a total of 3 brake cables. One lever operates one cable and the other lever operates two. The brand is MAFAC. I found one on-line at the following site. Scroll down to "Mafac tandem brake lever".
http://www.bikeville.com/brakes.html Good luck, Al K
Sep 01, 2010 | Cycling
Garmin GPS 276c appears to download at random time intervals while driving my vehicle such as 19 seconds, 8 seconds, 8 seconds, 9 seconds,19 seconds. Is this normal for the default setting for this...
Sounds like you have the unit set on non road use and or sonar. Please go here and see what you need to do. This does require a lot of reading but without knowing exactly what the unit is set on this is the best I can do.
CLICK HERE'
May 07, 2010 | Garmin GPSMAP 276C GPS Receiver
Speedometer froze at 65mph. now it goes from 65 to above 120
The speedo head is electronically controlled and is fed it's information from the vehicle speed sensor, or VSS sensor, depending on engine and transmission the VSS directs information to the speedo head threw the computer so it has to be tested to see if it is OK. If there is no check engine light then it may mean it's the speedo head itself that is defective. You can try and remove it out of the dash and replace the speedo head but normally this has to be done by a certified mechanic He has to write on the work order the mileage on the truck and when installing the new speedo he has to put a stamp on your door with his company name and when he did the replacement head. There are no mechanical connections like o the older cars, it is fed threw the transmission computer vehicle sensor or how ever the power train management system it is not a mechanical problem except for the speedo head it self. The needle windings may have stuck or a piece of plastic could have broke off and wedged itself inside the head itself. If you want instructions on how to remove your speedo head I can give you the instructions to do so, The speedo head will come out and you can buy them at a junk yard and maybe the dealer if they still have them available, otherwise they sell it as a full instrument cluster set. There are after market parts you can by at Schucks, Nappa or Auto zone, they run about $150.00 dollers and normally have a white face with black letters. Hope this helps and if you need more help don't be bashful about asking.
Nov 29, 2009 | 2004 GMC Sierra
Beep while wash cycle on
The beeping is indicating that something is wrong, it is usually followed with an error code or flashing lights.depending on the model
I would advise you to refer to your user instructions.
Hope this helps with your problem.
Thankyou.
Nov 26, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Cycling Logo
453 people viewed this question
Top Cycling Experts
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
