Question about E-Machines eMachines Monitor E15T4
My monitor is distorted. It is an E181H It is
My monitor is distorted. It is an E181H It is less than 6 months old. I can not set the resolutions more than 800 pixels.
    Brigadier General:
  • 4,044 Answers
Well, it has a maximum of 1024 × 768 @ 60Hz resolution. Double check that you have the correct Hz selected on your computer and that your computer video card supports the higher resolution. If the video card maxs out at 800 then the highest you can get is 800. If all your setting are correct and the video card is capable of using the settings you want then you may need to trade the monitor in or have it repaired. It should be under warranty being only 6 months old.
Posted on Jul 14, 2010
Wide screen stretches all my photos
Wide screen monitor distortionDepending upon the screen resolution that has been set inDisplay, the image will be distorted on these large wide screen monitors.
Create a large circle image using a draw program such as Paint (hold down theShift key as you create the circle as it will draw a perfect circle).
Open Control Panel - Display - Settings tab and adjust the Screen resolutionslider, increase or decrease the screen resolution then bring the circle imageto the front and check the image, if the circle is still distorted then changethe screen resolution and check the circle again until you are satisfied withthe image of the circle. When you are satisfied then click apply.
Dec 09, 2011 | Samsung Computers & Internet
Tip
Wide screen monitor distortion Depending upon the screen resolution that has...
Depending upon the screen resolution that has been set in Display, the image will be distorted on these large wide screen monitors.
To correct this distortion.
1. Create a large circle image using a draw program such as Paint (hold down the Shift key as you create the circle as it will draw a perfect circle).
2. Open Control Panel - Display - Settings tab and adjust the Screen resolution slider, increase or decrease the screen resolution then bring the circle image to the front and check the image, if the circle is still distorted then change the screen resolution and check the circle again until you are satisfied with the image of the circle.
3. When you are satisfied then click apply.
on Feb 24, 2011 | Computers & Internet
A few months ago my screen started distorting the picture now and then, and then would revert back to being fine. Now it stays mostly like that. I have it set up as an extended display from my laptop. I...
The resolution for the extended display could be wrong or on a setting the monitor cannot display. When you tell the computer to extend the display their should be a resolution drop down. Change it for the extended display monitor ( Click Advanced Display Settings or you may have to click the second monitor to see the resolution for it)
Jun 01, 2017 | Acer AL1912 19" LCD Monitor
Distorted images
try to change resolution settings.
right click on your desktop and click properties.. >> go to settings tab and change the resolution and colour quality and see if it works.
Good Luck!
Feb 26, 2010 | Dell E228WFP LCD Monitor
Heat from monitor
The monitor,screen,adapter or display of a computer is the primary user interface. Monitor problems are some of the most common computer problems since the voltages inside a monitor can be as high as 10 KV. Many of the problems can be fixed yourself by simply changing the settings but in a few cases you may have to either replace or repair the monitor.
google_protectAndRun("ads_core.google_render_ad", google_handleError, google_render_ad); How to troubleshoot and fix computer monitor/display problems
1. The monitor/display flickers
Check the refresh rate. If the refresh rate is 50 Hz/ 60Hz (depending on which country you stay), it can be affected by interference from electrical power signals like those from fluorescent lamps . Increasing the refresh rate to 72Hz is recommended , since higher refresh rates reduce eyestrain and headaches
2. The display works fine initially, then after some time there are black lines on the screen and then the display disappears
There is a problem with the copper windings in the CRT monitor which are getting heated. It is better to replace the monitor
3. For a new monitor, you get a blank screen or distorted image.
Many monitors, especially LCD monitors, can only handle resolutions which are less than the native resolution, so set the resolution at the native resolution only. The native resolution of a LCD display is lower for smaller LCD screen sizes, typically 1024 X 768 for 15" LCD. CRT monitors have a better resolution than LCD displays
4. The display on the monitor is not steady
This is a result of power system interference from users of the power grid, particularly UPS, power tools and heavy machinery. Try changing the position of the monitor.
5. There is a shadow on the images on the display
Try reducing the contrast setting on your monitor.
6. Monitor becomes blank occasionally
Could be a problem with the display card, check with another monitor. The monitor display cord and power cable should be fixed properly and there should be no loose connection.
7. Dark Spots on the Screen.
Move speakers,USB modem and other magnetic devices away from the monitor.
8. Incorrect Colors - red may become dark brown, blue becomes purple.
Check your video cables and connectors for bent or broken pins and wires. Sometimes there may be a problem with your display card, which can be retuned using a software available with monitor technicians.
9. Run Antivirus to scan corrupt software files.Virus cause distorted characters and images.
10. Set your monitor/display pixels to the software requirements. some softwares require higher pixels to run or to be displayed. some media players, web applications, video games applications and photo editors/view softwares have option to view photos on low or high quality
Jan 29, 2010 | Computers & Internet
I have an HP 2009m monitor. When I try to have
The problem is that your picture is not of high enough resolution. You need to get a higher resolution picture. There is nothing wrong with the monitor. The picture is distorted because the picture does not contain enough photographic data to scale to the size you are stretching it to. Higher resolution = larger picture without distortion.
Jan 03, 2010 | HP 2009M Monitor
I use Microsoft XP and I use a 24" Samsung widescreen monitor. Is there any way I can get my programs to fill the screen without stretching and distorting. I have a friend who has a Dell widescreen...
Its probably your screen resolution, you probably want it set to something with a 16:9 or 16:10 ratio so 1280x768 or 1280x960 or if you are like me and like lots of real estate 1920x1200
Sep 09, 2009 | Computers & Internet
I bought a 1600x900 monitor and now pictures are distorted
Your screen's ratio is oriented to playing wide screen formatted movies. Set your screen resolution to a ratio that's more or less 2 to 1 and you'll have a more realistic depiction of people on photos.
Aug 16, 2009 | Samsung SyncMaster 204B (Silver, Black)...
Distorted digital photos
Most likely the resolution of your desktop has and aspect ratio that in incorrect for your monitor. The native resolution of that monitor if 1440x900. Use the Windows (if using windows) desktop properties to set the desktop resolution to 1440x900.
Jun 09, 2008 | Acer AL1916W 19" LCD Monitor
E-Machines eMachines Monitor E15T4 Logo
154 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
