Question about Iomega ULTRAMAX 1TB TRIPLE INTERFACE FireWire 400 (1394a) Hard Drive
Connected to mac Book usb port not getting recognised in the system knocking sound comes sometimes from iomega hdd. pls advise how to solve this issue. thanks rajesh Lodha
PauldLucky
  • 268 Answers
SOURCE: external drive wont mount
Try doing flea power & the power cycle.
1. Disconnect all the peripherals like keyboard,mouse,printer, scanner & monitor and power supply from the CPU.
And press & hold the power button for 2 min, it will release the flea power from the mother board.
Restart the system & check.
2. Disconnect everything.wait for 5-10 minutes and then connect every thing.
Restart the system.
If it does not resolve the issue then you can try this :
Check this before you try to edit the registry values.
http://developer.apple.com/documentation/Darwin/Reference/ManPages/man1/profiles.1.html
Just remove the registry key it happen when this key is corrupted.
HLKM\System\CurrentControlSet\Enum\USBSTOR
And delete all references to the external hard drive.
And also HLKM\System\CurrentControlSet\Enum\USB
and found the keys associated with the USB to IDE value.
After restarting the system, the drive shold be detected & configured automatically by the computer.
Disclaimer : I will not be held responsible for anything that happens to your computer as a result of following my guide. Use this guide at your own discretion and risk.
You can use the Disk utility in MAC to run the diags on your drive.
Good Luck.
Live, Love, Laugh.
Posted on May 14, 2008
masterraphie
  • 41 Answers
SOURCE: Mac driver for Iomega 160 USB
http://www.opendrivers.com/driver/217203/iomega-hard-drive-driver-v3.0.4-mac-os-8.6-9.1-free-download.html
Posted on Mar 19, 2009
Damilare
  • 358 Answers
SOURCE: dropped an Iomega 500gig external hard drive...
From what I can deduce here, it seems that you the hard drive probably has a bad sector on it.
That clicking sound that you are hearing from the Hard Drive is coming from the read/write head inside the hard drive.
In this case, what I would advise you to do is, unscrew the hard drive case and remove the Hard disk from the case, connect it directly to a system, not externally or through USB this time around, then get a software called NTFS DOS Professional. It is a software that works like magic when it comes to hard drive repairs.
If you know any other hard drive utility, apart from this, you can also use it. I just recommend this personally because that is what I use.
Insert it into your PC, start up your CD-ROM and let your system boot from CD-ROM.
It works through DOS, and it should be able to help you with it.
If this does not solve the problem, then I'm afraid you might need to replace the hard drive.
And if it repairs it, I would suggest that you just retrieve all your valuable files from it and don't fully rely on the hard drive again because of the hardware error it has developed. Just keep using it as a second.
If you cannot do this by yourself, just get a very good technician to do it for you instead.
Kindly keep me posted about the problem.
Hope it helps.
Goodluck.
Posted on Nov 23, 2009
  • 81 Answers
SOURCE: Western Digital HDD Recognise as 0.0Gb
does this HD have an operating system installed on it ?, check the IDE
connection sometimes the IDE cable degenerates or is simply not fast enough for the drive , get back to me I'll help if I can
Posted on Jan 11, 2010
  • 10406 Answers
SOURCE: Iomega hard drives seem to give my MAc finder brain freeze
It's possible that ONE (or maybe BOTH) of the drives are defective. Disconnect one of them, and continue to use your computer. If the "freeze" never appears, then the non-connected drive is defective, and, since it is a "new" drive, you can get it replaced, for free, under warranty. If the "freeze" appears, then the currently-connected drive is defective, and needs to be replaced.
Posted on Apr 02, 2010
I want to use in my mac osx mac book pro
Hi Carmen; just plug it in to your system's USB port and format it for use with a mac os according to the provided instructions.
According to the manufacturer: Mac:
  • Built-in USB
  • Mac OS X 10.4 - 10.6
  • 128MB RAM
  • Drive must be reformatted for use with Mac (instructions included)
Mar 19, 2015 | Iomega 500GB Prestige USB 3.0 Portable...
My iomega is not showing up on my laptop?
The best USB ports to use are usually the rear ones.sometimes the bios keeps account of the number of connections and then refuses to recognise.if this is the case then you could try going into bios and switching off USB restart and switch it back on to clear the count. Or yes a different USB cable as these can sometimes create read errors.
Dec 08, 2014 | Iomega Computers & Internet
I have a DVD player with a USB port. When I connected the iomega drive , the dvd player can not read the hard drive. However if an USB 4GB onnects to the player , It will read?
The most likely cause is the 1Tb hdd has an NTFSfile system and the 4gb usb is a FAT32. To check, right-click on the drive in "My Computer" and look for "File System". it's right above the storage information.
Mar 22, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
Two rear USB ports are working fine and have the keyboard and mouse attached to them. Two to ports are mostly working though they give a "Not recognized" error message when I connect an Iomega 320 GB...
Hello there!
there could be problem with your HDD aswell, somethimes usb dont want to recognise some external devices and it shows that error also known as "yellow message".
On your place i would backup all files there and do one format of that for cleaning, who knows what might be in it aswell, some viruses, trojans, ...
If that havent solved your problem, then open up your pc and check look of your motheboard (if you have some eltronic experience you could check joins on it as well with voltmeter) . Thats it.
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Gigabyte GA-8I915P Duo Pro Motherboard
Apr 02, 2010 | Iomega 33089 250 GB Hard Drive
My iomega external hard drive beeps when connected computer
I just bought an Iomega external Hard Drive model number SPDHDU and I couldn't get it to stop beeping when I connected it to my Mac... Then I changed the usb connection from one I had laying around for other devices, to the one it came with and now it works fine!
Jan 11, 2010 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Can't transfer items to hard drive
Go to the Iomega Web sight and find tech support or Manuals/Guides and go from There??
May 30, 2009 | Iomega 1TB Desktop USB 2.0 Hard Drive
I have got a 500gb iomega hdd. I have got it plugged in to my laptop but my laptop will not reconise it. It has a blue power light flashing on the front. I have also tried it on the home desk top and its...
I had the same problem with my external hdd. I had installed Paragon disk management suite 2009. I ran the program with my hdd plugged in and after sometime(15 minutes) i found my hdd was recognised and working fine. Try it. How it worked for me have no idea but it somehow worked.
Dec 30, 2008 | Iomega (33654) Limited Edition 500 GB USB...
About Sigmatel S3
once u have connected USB from mobile to system... u get a message option of mass storage and com port.... better select mass storage for easy process... wen u select mass storage automatically the memory card will be displayed on my computer ( same a pen drive)..... NOTE: this process does not shoe phone memory..... only u can access memory card.... thank you... VINAY
Aug 26, 2008 | Handmark Software MobileLists (950142) for...
Iomega ULTRAMAX 1TB TRIPLE INTERFACE FireWire 400 (1394a) Hard Drive Logo
80 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Marvin
Marvin
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
