Stcuk on multiple cycle - Balay TW 5512
Hi I have a Balay TW5512 washing machine and for some reason it isn't stopping at the end of a cycle, it is frozen on a 3 cycle wash and I don't know how to fix it back to 1. Also, in cycle number 1, it isnt emptying or spinning, I am manually having to put it on empty and spin.
R u able to help please?
Thanks
  • 209 Answers
SOURCE: HOTPOINT AQUARIUS WF250 1500 SPIN
check the cold water supply, either from the mains pipe, there is no water getting into the machine, if water is there up to the machine check the solenoid for circuit, to do this unplug from electric, remove lid, and test the two wires on relevant solenoid, no circuit means faulty solenoid, (test with the 2 wires removed from solenoid) take care note position of wires to put back properly answer above based on info given
Posted on Sep 27, 2007
  • 1073 Answers
SOURCE: Maytag Washing Machine Stops after wash cycle...
sounds as if you have abad contact in the timer
advance the timer to a different spin cycle and see if it spins
then bo back to where it stops
if it will spin in the other spin cycles but not where it stops the the timer will need to be changed
Posted on Apr 21, 2008
SOURCE: bosch classixx6 1200 express
Turn Program switch to 6 o clock,hold RPM button turn switch to spin, release RPM button.Turn back to 12 o Clock .It should reset it ,Mine is a classicxx7 but should be the same...Marius
Posted on Jun 27, 2008
  • 135 Answers
SOURCE: our hoover ultra care 1300 large load washing machine spin fault
The most common cause of machines stopping mid cycle is not draining. Your machine should have a filter behind the kick plate at the bottom.
If this is not the case please post back for further assistance.
Posted on Jan 22, 2009
  • 9 Answers
SOURCE: Beko washing machine will not complete wash cycle. it will not rinse anf then spin. You have to manually select spin and drain after wash is done. can the maching be reset in anyway.
your timer is most likely bad
Posted on Apr 20, 2009
Machine will not finish any wash cycle, It stops, illuminates END light and beeps? Is there a reset or is this at the end of it's life?
Hi, quite often cycles are not finished because the drain pump has an intermittent fault. It may pump ok at the start of the cycle but towards the end it's had enough and stops. Leaving water in the bottom of the drum. If this is similar to your machine's symptom then I would be checking the pump. They are cheap to buy and easy to fit.
Hope this helps you.
Oct 04, 2015 | Washing Machines
Balay washing machine door wont open
We were staying in a holiday apartment and couldn't get the Balay washer/dryer door open on dryer cycle. Tried all the previous solutions and none worke. my husband turned the power off to apartment at fuse box and the door clicked open after a couple of minutes.
Feb 18, 2014 | Washing Machines
Error E5 on Balay ts7210 washing machine
This is a door lock problem can be door lock or main PCB
Dec 20, 2013 | Washing Machines
I have a centrex CTW45270A washing machine and the water doesnt cut off
Before you call anyone I would check the drain hose and make sure that it isn't pushed too far down. Reason being is that if the end of the drain line is lower than the pump of the machine then you'll have a siphon effect and the machine will constantly drain and fill.
Jun 15, 2012 | Washing Machines
Balay TW5512 cycle problem
is the heater working? Re: Jeff
Apr 12, 2012 | Washing Machines
I am just trying to figure out how many cubic feet my whirlpool calypso washer (model gvw9959kq2) is? Thank you.
The 3.5 cu ft Whirlpool GVW9959K is a unique washing machine that is Energy Star Qualified. It features the Calypso technology which helps prevent piling, shrinking and provides excellent stain removal. Save money and energy (up to $100 in utility bill savings) with this Energy Star Quiet Wash washer. The multiple cycles which include the hand washables cycle, the wool cycle, the bulky items cycle, give you the many options you need in determining the right cycle for your laundry. Automatic water level settings, multiple wash/spin speed combinations, 5 wash/rinse temperature combinations, and stainless steel wash basket with limited lifetime warranty are just some of the many reasons why this washer is the best choice for you. However the washer has a quirkiness also. They tend eat garments from time to time and take a dump when overdosed on detergent. The basket is suspended on four rods and is easily removed for servicing the motor and pump. The pump has a motor mounted on it. The whole time the washer is in motion water is continually poured over the clothes. It has a heck of a spin cycle at the end. Theory of operation, how to operate, repair and diagnose them fault does is HERE in the service manual.
Apr 06, 2011 | Washing Machines
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
My machine stops at "delay start", yet the cycle is not complete.
PROBABLY NOT USING ((((H E DETERGENT) REASON FOR ERROR CODES,, POUR A SMALL AMOUNT OF COOKING OIL ON A SPOON AND POUR INSIDE SHOULD SOLVE PROBLEM
Nov 29, 2008 | Hoover AAA160 Front Load Washer
Washing Machines Logo
217 people viewed this question
Top Washing Machines Experts
