Question about EdgeStar AP14000HS Portable Air Conditioner
I'm sure you hear this a lot. My edgestar 14000 used to cool great but now it's just not blowing cold air. I have noticed a slight change in sound that the compressor is making and the exhuast hose used to be really hot to the touch and now not so much? I have cleaned the filters, drained any water in the resovoir and checked for any obstructions in the vent hoses. I even carefully vacuumed the coils. It's just not cold enough, is there anything that I can do?
2 Suggested Answers
SOURCE: the bottom plastic panel of my EdgeStar AP 14000
I just replaced this pan on my unit. I have to admit it was more of an issue than I predicted. You need to remove the screws from the back cover of the unit. Then you can swing the back cover up like a hinge until it is sitting upside down on top of the front cover. Be careful not to damage the wires connecting to the circuit board. You can then remove the circuit board. After the circuit board is removed, you can remove the screws and the front cover. (note, you will have to spread the front cover to get the tabs on the center mounting locations to pop over the frame. After the front cover is removed you will see several things mounted to the base. I removed all of the fastners including the large nuts holding the compressor down. Then with some help,from a second person I lifted the unit and pulled the base away. I had to remove the yellow ground wires from the compressor in order to remove main unit. you will notice now that there are a few pieces attached to the base. I removed each piece and reinstalled it on the new base. then I assembled the entire unit in reverse.
Posted on Feb 09, 2011
Amana Wall unit blows cold air before heating
the unit works by chilling air and the byproduct is heat in the compressor, this is used for heating in the winter and then reversed in summer to blow cold air. It has to blow cold and warm up before it can blow heat.
Mar 17, 2017 | Amana Heating & Cooling
In AC mode the cooler fan doesn't turn on and after a little while the warm air starts to blow instead of cold air. Any ideas
Sounds like a bad or stuck reversing valve. Typically r.vs. are energized in cooling, verify 24 volts to valve, if yes , bad valve
Sep 30, 2016 | Whynter ARC-14SH ECO-FRIENDLY 14000 BTU...
Excess water prodution in portable 14000 BTU unit. See below
all a/c units remove moisture from air with cooling coil being cold and room air blowing across coil - depends how humid it is - i have used several different portable units and this seems to be a common problem if it is humid
Jul 03, 2014 | Commercial-Cool 8,000 BTU Portable Air...
'96 Lexus ES300 - a/c not blowing cold air. Took to car place and had freon added. Shortly after leaving, I noticed that it was not blowing cool air. I hear the compressor running, but not blowing cool...
There has to be a leak in the system. Look at the sight glass coming up from the condenser- is the refrigerant low (many bubble). If there is a leak there is a sniffer they use in the shop the detect where it is.
Apr 13, 2010 | 1996 Lexus ES 300
Fan blows room temp air, I can hear the AC kick in but it only runs for about 30sec to 1min before cutting out and making a sputtering sound that shakes the whole unit. Then it just goes back to blowing...
check you condenser fan motor make sure it turns on, if ok you must clean the fins on the outside unit,with a water hose , make sure you turn power off first before taking a water hose to unit
Aug 30, 2009 | EdgeStar AP420HS Portable Air Conditioner
AC doesn't blow cold air, but refrigerant levels
The low side pressure seems ok the high side would help,Is your compressor cycling and is the air coming out even slightly cool?slight over charge cold effect cooling ability.I wish I could be more help. I will have to think about this one.maybe you could make sure your temp.door is actually in the commanded cold position.
Aug 25, 2009 | 2003 Pontiac Vibe
AC Fan doesn't blow cold air, frozen coil noticed outside, resetting power resolves temporarily
You need to call a reputable service technician.  The freezing up usually is associated with a low refrigerant charge or low air flow.  Check your return air filter and replace as needed.
May 30, 2009 | Heating & Cooling
Heater keeps cutting off as if it reached the set temp.
sounds like its in defrost mode and the electric aux heat is not working
Feb 20, 2009 | EdgeStar Portable Air Conditioner Heater
Edgestar AP550Z won't heat, goes into some sort of alert mode
http://edgestar.com/ownersmanuals/AP550Z_wire-fix.pdf
This could apply to at least one of your units. Apparently these models have had some trouble with the compressor capacitor wires coming loose. If they're barely touching they could cause the compressor to run intermittently and possibly overheat. The compressor runs in heating and cooling mode.
Dec 04, 2007 | EdgeStar Portable Air Conditioner Heater
EdgeStar AP14000HS Portable Air Conditioner Logo
60 people viewed this question
Top EdgeStar Heating & Cooling Experts
Donni Steen
John Tripp
John Tripp
James Coghill
Are you an EdgeStar Heating and Cooling Expert? Answer questions, earn points and help others
