Question about Bosch Washing Machines
Bosch WFF2001 - various problems
Doesn't clean clothes properly, towels when dried (even when using fabric conditioner) are like sandpaper, clothes and towels come out ripped (even though on reduced ironing) and now, the plumber tells me my kitchen sink was blocked because he found all ripped clothes in the pipe. Does this machine have a design fault, as a previous plumber has told me he had the same machine and experienced the same problems?
Thanks.
Mandy
    Top Expert:
  • Bosch Master
  • 83,624 Answers
Replace the washer is my suggestion.
Posted on Jun 25, 2017
jsrock516
  • 5911 Answers
SOURCE: smells of mildew and so do clothes
If the odor does not go away, it is probably time to change the rubber door boot, or you have something stuck in the drain. Take a good look at the rubber around the door. If it has mildew spots and/or mold, it generally won't go away. Pull the rubber back a bit and look BEHIND the boot as well. You may have some lost items stuck in the boot causing the odor. Last of all, UNPLUG the washer and remove the lower kick panel under the door by removing the three 7mm screws and check the drain pump for foreign objects. There's only one pump inside the washer so it won't be too hard to find. It is usually white in color and has a screw off access cover. There is a bit of residual water that remains in the wash tub all the time. You will need to drain this first or you will have a mess to clean up. You can use some towels or use a shop vac. If you use towels, lay them down around the drain pump and remove the access cover. If you use a shop vac, pull all the residual water from the wash tub through the drain line. Sometimes this pump will build up with all kinds of scunge from soap residue and/or foreign object getting caught. Clean it out real well and run the washer on a bleach cycle with the hottest water setting you have. Let me know if any of this helps you. If you decide to change to door boot, post a response to this solution and I will give you step-by-step procedures.
Posted on Aug 26, 2007
SOURCE: kenmore elite he5t washer
I too have a HE4t washer. When I bought it, the Sears sales man said that after doing the wash for the day, you have to always wipe out the insides of the rubber gasket. If you do not do this, you will get mold build up. I an anal about doing this and for 6 months now have had no mildew smell. However, I went on a trip for 2 weeks and when I got back, there was an awful mold smell. I checked the gasket and sure enough, there was gunk build up. Needless to say hubby and kids did not do the maintenance. I had to wipe it up several times with bleach to remove the mold spores. Then I ran a sanitary cycle with pure bleach. Smell is gone thankfully.
But don't you think it's ironic to have a $1500.00 machine that needs to be babied after the end of the day?
Posted on Feb 11, 2008
barkencoa
  • 3463 Answers
SOURCE: fabric conditioner drawer does not empty
The inlet to the conditioner compartment is probably blocked.
Get a thin piece of flexible wire and make a right angled bend on the end about 1" long, and poke it into all the holes u can see in the top of the dispenser compartment, particularly the ones at the front right side.
This should solve the prob.
Plz rate this solution .
Thanks
Posted on Jan 02, 2009
SOURCE: Hard scratchy towels. Have used all wash cycles, and use fabric softener
have you tried just white vinegar as your rinse aid. Do a full cycle of your washing machine using white vinegar instead of detergent, to clean any residue from pipes, and then in the next wash try white vinegar as your rinse aid.
Posted on Apr 18, 2009
  • 51 Answers
SOURCE: My washing machine isnt accepting fabric conditioner
have you lifted up the conditioner flap on the drawer, you would of seen a long plastic tube sticking up, this tube gets blocked from time to time resulting in the softner not going into the machine. if you have cleaned this tube when you took the drawer out, then the only other cause is the solonoid vavle is the fault. this is easily replaced.
if you have any difficulties, you may if you wish, email me at appliancesdav@hotmail.com
pallesappliancerepairs.com
Posted on Feb 03, 2010
How to clean suede chair cover?
  • 1 Remove dust from suede by rubbing with a terry cloth towel in a circular motion.
  • 2 Rub smudges, dirt and dried stains with a pencil eraser. Good Housekeeping recommends using a kneadable eraser (available at art supply stores).
  • 3 Sand matted areas by briskly rubbing them with sandpaper or an emery board. This will restore some of the original texture.
  • 4 Dip the towel in white vinegar and gently dab any remaining stains. The suede should appear a slightly darker tan while damp, but not muddy or gray.
  • 5 Allow suede to air dry.
  • 6 Massage the entire surface of the fabric in a circular motion with a suede brush or toothbrush to reestablish a velvety grain.
  • Mar 05, 2013 | Health & Beauty
    I have a Bosch washer. My clothes are not soft when washed. What kind of soap powder shoul I use ???
    A couple of things-
    It really shouldn't matter which you use, not unless the garments are , for instance, wool and really need doing by hand.
    Are you using fabric conditioner/softener at all? If not I would start using it. The only time my wife does not use softener is with towels; they dry you better without it!
    Also if your water supply is 'hard' i.e. has lots of calcium in it, definitely ALWAYS use a suitable anticalc powder/tablet in EVERY wash. Regularly clean the machine with the contents of a sachet of proprietary anticalc powder which goes in on its own- without any garments.
    Good luck,
    John C
    Retired Englishman in SW France @ 17:47 Thursday afternoon.
    Feb 10, 2011 | Washing Machines
    How do I clean my stormbuck boots from Timberland? The store did not know
    Considering everything that we might step in during the day, it's a wonder that we bring our shoes into our homes at all. Cleaning our shoes not only gets all that grime back out the door, but it makes the shoes look better and last longe
    Instructions Things You'll Need:
    • Shoe brushes
    • White vinegar
    • Soft cloths
    • Nylon bristle brush
    • Pencil erasers or fine sandpaper
    • Leather cleaner or saddle soap
    • Leather conditioner
    • Waterproofer
    • Shoe polish
    • Shoe polishing cloths
    • Baking soda
    1. Clean smooth leather shoes by first removing the laces and giving them a vigorous brushing with a shoe brush.
    2. Clean salt stains from shoes by mixing equal parts white vinegar and water and dampening a small cloth. Use the cloth to scrub the stained area. For suede or nubuck, use a nylon bristle brush.
    3. Use leather cleaner or saddle soap to clean the leather with a soft cloth. Pay particular attention to the seams.
    4. Clean suede or nubuck with a pencil eraser or fine sandpaper, then rub with a bath towel to bring up the nap again.
    5. Apply leather conditioner to all leather shoes, taking care to use the correct kind for smooth leather or suede. Conditioner keeps your shoe leather soft.
    6. Waterproof your shoes.
    7. Polish your shoes to help protect them and to give them a clean-looking gloss.
    8. Deodorize your shoes by sprinkling a generous amount of baking soda into them and shaking the shoes to distribute it inside. Let stand overnight, and then shake the baking soda out
    Dec 28, 2010 | Timberland City Adventure Stormbuck...
    How do you get the mildew smell out of a clothes dryer?
    Very unusual problem with a dryer as it gets hot and would normally evaporate moisture causing mildew!
    Try the following:
    • Unplug the power point of the dryer.
    • Gently clean the interior (and exterior) with a super absorbent cloth/non-scracth sponge lighty soaked in a mild bleach soapy mixture to kill off and remove the (blackish) mildew (Nappy wash is not a bad mixture). Weat rubber gloves for protection.
    • Let the unit wet for a few minutes and then using clean warm water and sponge, remove all trace of the bleachy soap on the unit as it is corrosive. Additional drying off with disposable paper towel will help remove any trace of bleach.
    • Put a wet clean bathroom towel lightly soaking with material conditioner mixture at double the normal recommended ratio, power the dryer and dry off the towel as per normal: the fabric conditioner is also a freshner.
    • Musty milldew odour should be gone!
    Hope it helps! Please let me know how you go!
    Aug 05, 2010 | Hotpoint Dryers
    Moldy smelling clothes
    First, clean your washer with one of the front load washer cleaners on the market. (Affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, or Tide front load washer cleaner) Use the longest, hottest cycle your washer has, with no clothes.
    Second, rewash the smelly clothes with the heavy wash cycle and a second rinse option, using no soap or fabric softener. This will remove the soap and/or fabric softener build up in the clothes which is causing the smell. Third, begin using one to no more than two tablespoons of HE soap per load, and not more than 1 teaspoon full of fabric softener if you use it. This is because top load washers used up to 45 gallons of water per load, and your front load machine is only using about 12 gallons total. If you are washing a load of bath towels (which were only used to dry off your clean body, not wipe up the floor or something like that) they are not really dirty,...... for washing "clean" towels, don't use any soap, and of course never use fabric softener on towels.
    Jul 01, 2009 | LG WM-0532HW Front Load Washer
    Cleaning agent placement
    From left to right as you see.
    1 This is for your frontloader soap powder or other detergent.
    2 Fabric conditioner or softener. If this is too thick, mix with water to prevent clogging.
    3 Detergent for soaking agent. I dont see 'bleach' anywhere
    There is an panel, front bottom right which holds your pump filter, unscrew to clean out. But wait. Plug off the mains.
    You will see a hose on the left, this is if your water in the tub cannot drain, you can drain it here. Your tub can hold upto 20 litres/4.4 gals.so have a suitable container to collect; carefully remove cap to drain out. Reason why it doesn't drain is because there is a block in your pump (right side) which you must clear.
    To keep your pump from probs (a tip which you seldom see) empty all pockets of clothes before putting into machine. I have a non electronic Philco which i dont remember cleaning with hotwash or anything, 10years +
    For exteriors do not use solvents or steel wool. Only hot soapy water with a mild non-abrasive cleaning agent, dry with soft towel.
    Above should be useful. Pl rate.............
    Mar 21, 2009 | Bosch Axxis WFL 2060 Front Load Washer
    Mildew smell on cloths
    The brand of your front loader is not that material on this issue. What is happening is that your old top load washer may have used as much as 45 gallons of water per cycle, while some front loaders use as little as 12. Because of the low water use, you must cut back on the additives you are using. Use only 1 tablespoon of HE detergent (even less if 2x or 3x detergent) per load. If you use fabric softener, use only 1 teaspoon per load. Odor on clothes after wash is indicating that the detergent and or softener has not been fully rinsed out. If you throw a load of washed towels into your machine and start a cycle without any soap, then stop the cycle, you should not see any suds. If you do, there is obviously soap left in the clothes. With bath towels, the towels are used to absorb clean water off a clean body. They do not need soap when you wash them, and never use fabric softener on towels.
    If your washer is a LG WM-1832 it has a assessable filter behind the access door on the lower left front of the machine. Clean that out first, and if it has a tub clean or sanitary cycle use that cycle (if not, use hottest longest cycle available) with 3 Affresh tablets or use whirlaway to clean out the washer outer tub (the not visible tub that holds the water). You might want to use another cycle like that with bleach to head off mold or mildew growth. Use of proper amount of detergent and fabric softener should really help the clothes odor issue from then on. Also check the tub seal at the bottom of the door area to clean out any lint from drain hole areas to help prevent water from remaining in the tub seal area.
    Oct 28, 2008 | LG WM-1832C Front Load Washer
    Washing Machines Logo
    55 people viewed this question
    Top Bosch Washing Machines Experts
    Marvin
    Marvin
    Craig Butler
    Craig Butler
    Carmen Mikulic
    Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
