Question about Neff B1432 Single circotherm plus Electric Oven
Hot air escaping from top of oven.
My under hob single oven is 5 years old. When it is on at fan setting hot air escapes out of the top of oven. Is this normal? Thanks
  • 249 Answers
SOURCE: neff single oven
fan heating heating element gone replace it ;Ire close bye
Posted on Nov 28, 2007
SOURCE: neff oven door (U1661)
The door is v heavy and the hinges being right at the bottom take a lot of strain, especially when the door is in 'half open' position. Once the springs start to wear the hinges are no longer strong enough to hold the top of the door firmly closed. Our U1661 is 8 years old and we've had the hinges replaced twice under extended warranty. The second time the hinges they supplied don't hold the door in this position and it will just drop straight down if you don't support it while you open it.
Posted on Oct 20, 2008
barkencoa
  • 3463 Answers
SOURCE: hotpoint ew83p oven has no heat
The oven fan element has failed, you need to fit a new one.
Remove inner rear panel of oven and you will see the round element at rear.Unscew screw(s) that secure element, disconnect leads, and fit new element.
Refit element cover.
Job done..
Make sure you have power off to oven before you start.
Plz rate my solution.
Thanks.
Posted on Jan 12, 2009
  • 13 Answers
SOURCE: Neff U1721 bottom oven not heating fan & light are ok
Yes it will need a new element, if the fan runs and temperature light comes on then the element is gone.
Posted on Jul 29, 2009
  • 4946 Answers
SOURCE: The fan and oven light in bottom oven works but not heat.
The heating element is the likely culprit as they burn out and go open
circuit..(ie ...disconnected and will not heat up )
If you can use a multi-meter , then the element can be tested using the resistance range (with the oven SWITCHED OFF )
Posted on Sep 01, 2009
Knobs on hob above the oven getting very hot. Guess heat must be escaping from the oven. Any suggestions?
Try putting a layer of insulating materials between the Knob and the oven. That should help.
Aug 10, 2015 | Ovens
Thermal protection fuse has started burning out when oven self-cleans. Ran fine for years, now this has started happening. Not every time it self-cleans, but have now replaced second fuse in 2 years. Is...
The most common reason for this is the door not sealing properly, if hot air escapes out the seal during the clean cycle it will be pulled across the thermal fuse.
The second most common cause is reduced air flow. If the blower wheel is dirty it cannot move as much air across the fuse to keep that area cool, if the vents just above and below the door are dirty and dusty they can block air flow too.
Aug 01, 2010 | KitchenAid KEBC101 Electric Single Oven
My stoves oven is burning my kitchen cupboards
If you could provide some more information, then I may be able to help. What part of the oven is causing the problem, i.e. top or bottom door. If the doors don't shut properly then this may cause the hot air to escape. If it is one of the doors, is it sitting square in the frame?
Feb 20, 2010 | Stoves 720EF Electric Double Oven
Have no signage on knob for top oven/grill..how do I know f it's grill or oven on when I turn it on?
If you turn the grill on, then only the top element will get hot in the oven.
if you select oven and it is fan assisted, then you will hear the fan working, and feel it blowing hot air.
Hope this helps.
Dec 24, 2009 | Belling XOU252 Electric Single Oven
Samsung PKG001 Stainless steel Single Oven and Ceramic Hob : Hob working ok oven light comes on and fans work ok no display on oven and no heat any suggestions
Had exactly the same problem and just had the samsung engineer out (as it was only 3 months old ) who replaced the thermostat. all is now working ok
Jul 15, 2009 | Ovens
Hotpoint ew83p oven has no heat
Job done..
Thanks.
Jan 12, 2009 | Neff B1641 Single circotherm super...
My oven is a kenmore gas single, self cleaning oven about 8 years old. the oven will not light. the top of the stove is fine.
Open the oven door and take the bottom panel off. you will be able to see it the hot surface ignitor starts to glow or not. Now turn the oven on and see if the hot surface gets red hot it not that is the problem. Should be able to get the part at a heating and air parts house or a appliance parts house. let me know what you find out. ken
Dec 13, 2008 | Kenmore 30172 / 30174 / 30179 Gas Single...
Keep having to replace element
Not neccesscarily a problem with oven, as it is quite a common fault with fan ovens.
You could make sure that the fan is running properly, and is free to turn, and that the fan blades are not covered in grease etc',
Make sure that oven door seal is o/k, as hot air escaping here will lead to longer running times.
Plz rate this solution.
Thanks.
Dec 10, 2008 | Zanussi ZHQ575 Electric Double Oven
Neff B1432 Single circotherm plus Electric Oven Logo
134 people viewed this question
Top Neff Ovens Experts
ashburton
Hjalmer Lamminen
Hjalmer Lamminen
Samyfam
Samyfam
Are you a Neff Oven Expert? Answer questions, earn points and help others
