Question about Kenmore Refrigerators
Kenmore 106.9631680 keeps running all the time,all the gaskets are tight and the coils are clean
  • Kenmore Master
  • 3,051 Answers
Hello there:
The thermostat cycles the refrigerator on and off. The refrigerator normally runs as long as the temperature inside the refrigerator is higher than the set temperature. If the temperature inside the refrigerator is cold enough and the thermostat still does not cycle off, the thermostat may be defective. If so, you need to replace it, because it cannot be repaired. If the thermostat is not defective, you may have a problem with the sealed (refrigerant) system, in which case you should contact a qualified appliance repair technician.
Posted on Jul 14, 2010
How do i fix leaking water at thermostat housing?
If your thermostat housing is pitted and corroded it might be time to purchase a replacement housing. If your hose clamp is worn out, it might be time for a replacement. If the bolt holes are worn out, it might be time for new bolts and heli-coils in the intake. If none of these are the problem....I would think that a thorough cleaning of all surfaces and a thin bead of silicone on each side of a clean dry gasket would work.
Jun 23, 2015 | Cars & Trucks
Tip
Keep your refrigerator running longer
As refrigerators get older the door gakets dry out, to keep it from running all the time apply a thin coat of vasoline to the flat side of the door gasket. Do this on all sides and apply a little more to the side with the hinge (it gets the most damage with time) And dont forget to clean the cooling coils under it as well.
on Dec 01, 2009 | Refrigerators
Kenmore 253.64802400 this fridge keeps running all the time and at long periods of times. Food is kept cold but it keeps running. How long is the average run cycle in a fridge. I've seen times the fridge...
Hello James;
My name is Peter. I am a retired field service refrigeration technician.
Good for you. You purchased a simple unit that does not have all of the buzzers and fancy controls that can go wrong.
The normal cycle of your unit is the temperature will rise to 20 degrees above set temperature and then shut down, until you reach 20 degrees below set temperature.
Your problem is you have a bad door seal. Your compressor is running trying to maintain the set temperature.
Ok, lets fix this problem:
1.) There are two screws in the bottom front of your refrigerator.
You want to turn these screws clockwise to raise the front of the refrigerator so it is pitched slightly back. This will assist in maintaining a good seal.
2.) Wet the door gaskets. With a hair dryer and a kitchen spatula, heat the door gaskets up pulling them out with the spatula trying to expand the crushed gasket.
If you have a bad gasket. It is easily replaced , a grooved slot. Pull out the old gasket and insert the new one.
Heat the new gasket in hot water for 30 minutes. Form and expand it with your hair dryer and spatula.
25605805-3lxxwax0f0xbqftwrz0flikt-2-0.jpg 2.) Lets finish the job: After time the door gaskets become crushed and do not maintain a good seal, so you have to recondition them. Inspect the door gasket, are there cracks and worn sections? With a hair dryer and spatula, heat the gasket while using the spatula to expand
Mar 25, 2015 | Kenmore Refrigerators
What are most likely resons for a 15-20 year refrigerator most to keep cold enough temperature
Hello. One main issue with a warm running refrigerator is that the coils where the heat is disipated are clogged and are not able to do their job.
The first step is to find the coils (typically either on the back of the unit or under the unit) and carefully clean any accumulated dirt or blockages from the area. There will also likely have a fan and a motor that moves air over the coils. Be sure to clean off the fan blades and make sure this motor runs.
(The coil is typically metal and is made up of a tube with metal fins off of the tube. The coolant runs thru this and heat is released before the coolant is returned to the compressor.)
the fiThe
Sep 03, 2014 | Kenmore Refrigerators
Kenmore 253 9280413 freezer keeps running
The coils are embedded in the outer walls and will make the cabinet feel warm outside when the compressor is running. It needs about 4 inches of clear air space around all the outer case walls to properly get rid of its heat. If you have items stored too close to the outer walls they will act as insulation to keep heat from being dissipated. This can cause long run times.
A unit that has lost freon gas due to leakage, while unlikely, can also extend run times. Normal temperature should be about Zero when the dial is set to halfway.
Good Luck
Sep 15, 2009 | Freezers
Kenmore Refrigerator Ice Maker
ck condensor fan motor that cools compressor under unit. yoder loop runs through center divider and causes gaskets to get hot
Aug 26, 2009 | Kenmore Freezers
Freezer runs all the time
I don't have enough information. Use a freezer thermometer and check the temp. If below 0 probably a bad thermostat. Sides getting hot is normal. Thats how it gets rid of the heat from inside. In the summer a freezer can run over 80% of the time. Again this is normal. Another thing to check is the gasket around the door. See if it is worn or torn and is sealing properly. If there are condensor coils under neath clean them check to see if the fan under there is working when compressor is running. (Not all freezers have coils underneath. Some have them in back, Smaller units just use the side of the cabinet.)
Jun 26, 2008 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Evaporator fan
Check and make sure that you didn't knock a piece of insulation down onto the condenser fan when you were vacuuming off the coil. When the fan is blocked it can cause the compressor to what is called short cycle and the refer will never get up to temp. Also check your door seals. Insert a dollar bill between the gasket and frame and gently pull on it. It should be fairly tight as you check all the way around the gaskets if not you may have to replace the gaskets or adjust the door. As for the pan underneath. It should have a little moisture in it every 8 to 12 hours as it is the capture pan for the self-defrost. If not you could have a problem with your defrost heater check for ice build up on the back panel of the freezer. If there is a build up then your refer is not going into defrost and you may have a problem with the defrost heater, defrost timer, defrost thermo., etc. Be sure and check all these areas as you don't want to throw money away needlessly.
Dec 23, 2007 | Kenmore 53642 / 53644 Side by Side...
Coils Frost up and Bucket never fills
Poston192: You have a refrigerant leakeage in the unit, that's why it's frozen up. If you want to do it yourself, here's what to do: 1. Disconnect power from unit. 2. Remove covers from dehumidifier and locate coils and evaporator units inside. 3. Check for greasy or sticky signs on joints and weldings. 4. Once locate it, re-solder (in case of leakage on weldings) or adjust very tightly the joints. 5. Reassemble and test. SithPitt
Jul 04, 2007 | Kenmore 5245 Dehumidifier
Refrigerators Logo
201 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
jackdo2
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
