Question about Microsoft Xbox 360 Console
Xbox 360 1 red light on ring of light e74 on screen what can i do
    Problem Solver:
  • 9 Answers
This behavior occurs when the Xbox 360 console experiences a hardware failure.
Solutions..
Turn off your xbox 360 and remove all memory units and hard drive, power up your xbox again. if the problem appears to be resolved it could be a currupt or bad hard drive or memory unit. follow the above steps again but adding 1 memory unit / hard drive at a time to single out the bad memory device.
Depending on the devices warrenty or where you bought it, you should be able to get it replaced.
If the problem still occurs afetr all memory units are removed try removing all other external devices such as wireless adapter.
if it still occurs it could be something more serious such as the DVD Drive or graphics processor. in which case you will need to call the xbox repair center. they should fix it free of charge for you despite your warrenty under there current "good will gesture" due to the numerous amounts of xbox 360 problems.
hope this helps
Anthony Kinson
Posted on Apr 22, 2008
The forth player icon on the xbox 360 is flashing red
Xbox 360 Red Ring of Death Fix Kit
The e74 is an overheat issue. It's also know as the red ring of death (rrod). It is very, very common. The link above covers the entire disassemble and re-assemble of an xbox.. That is if you chose to go that route to repair.
If you have a local Gamestop, they may be able to repair it for a fee.
Jan 06, 2014 | Microsoft Xbox 360 Console
How do i fix an error 74 on an xbox360
The E74/E6x/E4x/E8x are famous error codes that have plagued many Xbox 360 gamers. This error codes will be displayed on your screen, each indicating different problem with your Xbox 360. It's usually defined by the single red light or 1 Red Light Error lit up at lower right quadrant on the Red Ring of Light on your Xbox 360 console.
E74: There is high chance it's a scaler chip problem (the "ANA" or "HANA" chip near the AV cable connection) it can also be caused by a faulty AV cable so check that first. In some cases it is a problem with the GPU and may be repairable by using the Xbox 360 Repair Guide. Xbox 360 E74 error has reported to increasing a lot for the newer Xbox 360 version.
Hope this was helpful?
Feb 26, 2011 | Microsoft Xbox 360 Console
Has 3 red blinking lights
Red Ring of Death: Red Flashing XBOX 360 Lights Explained Common Xbox 360 Red Ring Errors The XBOX has a reported 54.2% failure rate which makes the XBOX 360 gaming consoles' worst "lemon" to date. If you find yourself with the red flashing lights error, --> lg.php?category_id=15&content_type=article&content_type_id=2663399&key_page=682482001924178892&site_id=1&bannerid=11791&campaignid=3153&zoneid=23&loc=1&referer=http%3a%2f%2fwww.associatedcontent.com%2farticle%2f2663399%2fred_ring_of_death_red_flashing_xbox.html%3fcontent_type%3darticle%26content_type_id%3d2663399&cb=8da55f49a0 follow this guide to try and pinpoint the problem with your XBOX 360.
1 Red Ring = Serious Hardware Failure
I f your XBOX 360 has a 1 red flashing light error, you're more than likely in big trouble. The 1 flashing red ring of light can be due to GPU or CPU failure, RAM overheating, a DVD drive error, or some serious problem with your Xbox 360's internal components. The most common 1 flashing red ring lights error is the E74 error. The E74 error is no easy fix for the Xbox 360 and usually has to be repaired by the manufacturer [though some have managed to repair it with the heat gun trick - but be careful]
2 Red Rings = Overheating
Mostly all red flashing lights on the Xbox 360 rings are due to overheating in some way or other, but the 2 red rings singles out overheating as the main issue. When doing the X-Clamp fix the 2 red rings are required to fix the Xbox 360 by overheating the CPU. If you get this Xbox 360 error without doing the X-Clamp fix, you probably just need to let your Xbox 360 cool down for a few hours. Make sure that all vents aren't blocked off and that your Xbox fans are working properly in order to repair this problem.
3 Red Rings = Basic Hardware Failure
The most common error on the Xbox 360 is the 3 red rings - also known as the Red Rings of Death (RRoD). This flashing lights problem is the main cause of Xbox 360's 54.2% failure rate. The 3 red flashing lights can be due to lots of different errors but is mainly due to the X-Clamps in your Xbox 360 and overheating. Fortunately, lots of people were able to fix this issue using the X-Clamp and heat gun fix. Follow this list of error codes to find out the real issue with the 3 red rings because there are quite a few of them.
Jan 07, 2011 | Microsoft Xbox 360 Console
Switchs on comes up with e74.has 1 red light flashing on front f unit
XBOX 360 Red Light error, or Red ring of Death RORD is a very common issue, and can happen anytime. There are different Error numbers related to RoRD, and appears on screen starting with "E".
Red light problem can be fixed! there is a XBOX 360 repair guide available that covers this problem and also all other common XBOX problems. You can get your copy XBOX 360 Repair Guide, you can download it and get help to fix your console. Please feel free to message me if you need further assistance
click here to download.....................
Oct 14, 2010 | Microsoft Xbox 360 Console
Xbox 360 Elite - Ring is flashing red (1/4) of the circle- E74 error coming up
I recently had the E74 system error which started with as ‘black snow’ on the screen. There is an extended 3 year warranty that covers E74 and 3 Red Lights errors only.
I looked in to fixing it myself but thought might as well let someone else graze their hands getting the case off!
Despite the horror stories of it taking forever MS seemed to have pulled their finger out and made this a very efficient process, I got mine back within a week (I live in the UK and repairs get shipped to Germany).
Here's a quick breakdown of the process:
1. Go to www.xbox.com/support and click on the relevant link relating to your problem.
2. Go through the walkthrough. If you've still no joy you can click a link to pick whether you are a US resident or not.
3. Type in serial number of the console (you don't need any receipts, I bought mine off eBay).
4. They send you a shipping label and a link to arrange UPS to come and pick up your console.
5. Bite your nails and rock manically in a corner until your console comes back (you can track the whole process at xbox.com).
I've sent back a first generation 360 and an Elite. Certainly worth considering as they will repair or replace your console!
http://support.microsoft.com/kb/907534 3 Red Light (Red Ring Of Death/RROD)
http://support.microsoft.com/kb/941377 E74 Error
Nov 26, 2009 | Microsoft Xbox 360 Elite Console
How do i fix the x box 360 3 red rings of death
The Xbox 360 e74 error is a rather common problem on Xbox consoles, with similar roots to the now infamous red ring of death problem.
The e74 issue is actually caused by a problem with the scaler (ANA or HANA) chips located next to the graphics processor inside your Xbox 360.
It is believed that the error with the scaler video chip which causes the e74 error on your Xbox 360 is caused by overheating. This is also the cause of other errors such as the no video problem, as well as red lights in the power ring of an Xbox console.
To fix the Xbox 360 e74 code, there are a few steps you need to take-
1. Firstly, leave this article open, go to your Xbox 360 console and then remove the AV cable. Blow any dust out of it, then re-insert it snugly back into the console until a clicking is heard. Power on your console again and see if the problem has been fixed.
2. If that does not work, borrow another AV cable (get one off a friend or family member, or from your local video game rental shop) Try using this one in your Xbox 360.
3. If replacing the AV cable does not work, then you will have to repair the scaler chip and graphics processor inside your Xbox in order to fix the e74 problem. To do this, you will need an Xbox 360 repair guide, which will contain the video instruction files you need to be able to fix your console properly. You cannot fix the e74 yourself without one.
It is important to note that most Xbox repair guides focus on fixing the "red ring of death". However, the process for repairing the e74 will also be covered in the same guide as well, as it is extremely similar.
Aug 30, 2009 | Video Game Consoles & Games
Screen reads,system error and has a trouble code of E 74 What could be the problem?
Aug 28, 2009 | Microsoft Xbox 360 Console
1flashing red light
one red light is also the E71 error as well.
Aug 04, 2008 | Microsoft Xbox 360 Console
Xbox 360
What is the error code at the bottom of the screen & check for flashing red lights on the power button if 3 illuminate it the infamous RROD(Red Ring of Death-google it) which you will get a free repair for if its the bottom right quadrant flashing red then its most probably E74 or E61. E61 is a hard drive related problem so try playing without it, & E74 is the AV cable snapped inside or the GPU/CPU inside the xbox 360 has weak solders on it, I suggest MS support ASAP.
Jul 22, 2008 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
