Question about LG L1915S 19" LCD Monitor
Where do I plug power cord into monitor?
Just got LG E2050. Where do I plug power cord nto monitor?
  • 857 Answers
On the monitor there will be two ports at the bottom
in which you have the plug the cable.
Posted on Jul 14, 2010
Lg monitor power problem
Here's some tricks I would try. Something here, might help...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 06, 2014 | LG Studioworks 563N 15" CRT Monitor
Where can I purchase a power cord for a LG Flat Screen TV Model #32lh40-ua
Check to see if the power cord input on the TV has the same plug shape as the one that fits into your computer tower or monitor. Many modern TVs use the same standard power cord as a desktop PC or monitor.
If it does use the same cord, then you should easily be able to find a replacement cord for a couple dollars at most since that is such a common item. You or someone you know may even have a spare one lying around leftover from an old computer system.
Good luck.
Jul 28, 2011 | LG Televison & Video
Yahwhere do i plug the sound cable into my LG flatron E2050 screen?
look around your screen,,,you will find two or three ports to put your audio device,,,but it may also possible that you screen dont have any ports ...
Oct 25, 2010 | LG 20" Widescreen Flat-Panel LCD Monitor...
Hello, today i unluged my computer and monitor from the power socket in the wall, and cleaned out the dust from inside my computer, and when i plugged all back in, my computer will comeup with the "LG"...
That's probably a message from the monitor because it's not getting a signal from the computer. Look at the VGA cord where it plugs into the computer, or the monitor to see if you bent pins when reinserting the plug.
Feb 18, 2018 | LG Flatron L1951S-SN 19" LCD Flat Panel...
Unable to power on LG W1942T monitor.
It's looking more and more like your monitor has given up normal operation --- to go inside the monitor is something that is very unwise for your typical user, and it is probably best to just replace the monitor --- sorry.
Nov 01, 2009 | LG W1942T-SF Monitor
L1932TQ LCD Monitor won't turn on.
I'm affraid you did about everything you can to find the issue. Trying to isolate the problem is the best way to come close to a solution eventually. But after all the tests you did, it seems that the monitor itself got a problem. I dont suggest you to try to fix it yourself, some electrical parts may need to be electrically discharged before being removed from the monitor. If your monitor is still in waranty, contact LG for support. Otherwise, you could bring it to a local tv/monitor store to see if they can repair it. LG support rep could also give you some advice, maybe they got a certified partner in your area that could take a look at it. P.S. If your computer is on windows XP it should shut down the usual way just by pressing the power button once. The shutdown will be the same as if you go Start->Shutdown->Shutdown the computer.
Jun 03, 2009 | LG L1932TQ LCD Monitor
LG Flatron L1710S Monitor stuck in Power Save Mode
Try wiggling the Cord on the backside of the monitor.. Not the Power Plug Cord, The Other Cord that attaches to the PC. Do this once the monitor turns off , grab ahold of the cord about 2 inches from the back of the monitor, then bend the cord to the right, keep bending from the right to the left a couple times to see if your screen comes back, if it does, than you have a Loose connection and this sometimes causes the Symptoms you are receiving.. Hope it helps.
Jun 02, 2008 | LG Flatron L1710S 17" LCD Monitor
LG L1915S 19" LCD Monitor Logo
193 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
