Question about Philips Electronics - Others
Philips gogear vibe will not open music folder
Phillips gogear vibe - It will not open music folder when pressing play/pause button
  • Philips Master
  • 17,130 Answers
HAve you tried resetting the go gear when the fault came in, if not try to reset the go gear. There is a tiny hole on the go gear, use an office pin to push and hold for few seconds to reset,Now the set must work fine. If not connect your gogear to the PC and do a scan for virus or corrupt programmes installed. If so delete, save the listed programmes to the PC and reinstall them back. Use the media convertor software provided when you are converting media files on the go gear or else it will not read or access. Hope the advice helps you. Good day
Posted on Jul 26, 2010
How do you store podcasts best on a phillips mp4 vibe?
If the device offers the ability to create folders (like rock, folk, classical) that are selectable, create one called podcasts. If not, retitle all the podcasts so that the file names all start with a Z, and then at least they will be at the bottom of a master list when played in sequence. Doesn't help in shuffle mode though, as the podcasts will still play randomly if you can't isolate them to a separate folder.
Nov 16, 2017 | Philips GoGear ViBE Digital Media Player
How do I download songs onto my phillips gogear cam
  • Charge your Philips GoGear ViBE for at least three hours before turning it on.
  • 2 Insert the small end of your mini USB cable into your GoGear ViBE. Insert the other end of this cable into one of your computer's USB ports. Turn your GoGear ViBE on by pressing and holding the "Power" button for two seconds.
  • 3 Insert the Philips GoGear ViBE software disc into your computer's CD-ROM drive. Follow the onscreen prompts to install it.
  • 4 Open "Computer" from the "Start" menu and locate the GoViBE icon to make sure it has been successfully connected to your computer.
  • 5 Navigate to your music files. If you're unsure about their location, start by looking in the "Music" folder under the "Start" menu.
  • 6 Drag and drop your music files from their folder onto the GoViBE icon in your "Computer" window.
  • 7 Right-click the USB icon with the green arrow, located in your taskbar, to disconnect your device. Click "Safely Remove hardware," then wait until your computer confirms that it's safe to remove the device. Disconnect the USB cable from both your computer and your GoGear ViBE.
  • 8 Select the musical note icon from the main menu of your GoGear ViBE to open your music files. Navigate to the sub-folders section, and select a song from either the artist, album, track list or genre. Press the "Play/Pause" button to begin playing a song
Oct 07, 2011 | Philips GOGEAR SA6045 MP3 Player
How do i remove music files off off my gogear vibe 4gb and only if it is certain songs i want to take off to make more room for new music files...
Hi t lq,
There are several ways to delete music files from your GoGear Vibe, depending on which model you have (model numbers typically begin with "SA" and are located on the unit), and whether you want to delete off of the player or off of your PC. Either way, you can delete specific music files by following the below directions.
If you have additional questions or need further support, Consumer Care can be reached at 1-888-744-5477 or visit www.philips.com/support and enter your model number to be directed to the product specific page (which includes FAQ's, manuals, chat, software, etc.).
Hope this helps! If so, let me know by rating this solution!
Delete directly from the player:
REMINDER: This method is only for player with OPTIONS / 100318094423_31296.gif button only.
1. Highlight the file or folder you want to delete.
2. Press OPTIONS / 100318094423_31296.gif button your player.
3. Select DELETE.
4. Repeat Step 1-3 when you want to delete more than one file or folder.
Delete from your PC:
1. Connect your player to your PC. You player will load automatically just like the picture shown in step 2.
2. Select Open device to view file.
(If it does not load automatically, you can double click "My Computer" and then double click the icon of your player.)
3. Select the files you want to delete.
HINT: You can press and hold the Ctrl button on the keyboard to select more than one file.
4. Right click the highlighted files and select Delete.
5. Select Yes to confirm.
Sep 01, 2011 | Philips GoGear ViBE Digital Media Player
How do I download music to the gogear from my computer I have a Go Gear Vibe MP3 player
Hi bwhitel,
There are several methods for transferring music onto your Philips GoGear Vibe, including Drag and Drop, using "Sync" in Windows Media Player, using Rhapsody, or using Philips Songbird.
Below please find step by step instructions for the "Drag and Drop" method, but you can also download and use Philips Songbird (see after Drag and Drop instructions for more information).
Hope this helps - if so, let me know by rating this solution!
DRAG AND DROP:
(Attached pictures are examples only)
1. Connect your player to your PC. It will load automatically as shown in step 2.
2. Select Open device to view files.
(If the folder of your player does not appear, double click My Computer at the desktop and you will find an icon for your player. Double click that icon)
3. Select the music or picture files you want to transfer in your local directory.
(You can press and hold the Ctrl button on the keyboard to select more than one file)
4. Drag the selected files to the particular folder of your player (E.g. Music file on your player) by holding the left button of the mouse and releasing it.
Along with using the above method, you can also use the one of the following. Please refer to the link for more details.
1. Window Media Player 11
www.microsoft.com/windows/windowsmedia/knowledgecenter/howto/mp11/sync.aspx
2. Rhapsody
www.rhapsody.com/mac_faq
You can find valuable information like FAQ's, user manuals, software and more by visiting www.philips.com/support and enter your model number to find specific product information.
Consumer Care can be reached at 1-888-744-5477.
If you are interested in learning more about and downloading Philips Songbird, visit:
http://ow.ly/5XOaE
Aug 08, 2011 | Philips GoGear ViBE Digital Media Player
Dear Sir, My philips gogear sa2rga04k/97, do not play when i coonect to my car stereo, which was fine before. when I coonect to pc it tells me that my device installer is corrupted because of...
Im not a techy, but i know enough bout music to know what 2 do. If your car stereo has a AUX imput 3.5mm jack, (headphone-like-cord) you need to connect your Vibe to the cord and the cord to the AUX imput. then make sure that ur car stereo is set to AUX. when it does, the vibe most likely will be on pause or wat ever setting you left it on prior to connecting it. Now all u need to do is.....Selec the song or playlist, and press PLAY.
May 13, 2011 | Philips GOGEAR SA6045 MP3 Player
I have a Phillips Vibe, the music already on the MP3 works fine, but I cant download a CD onto it, or should I say I can, but when I try to play it my MP3 says DRM license required!
Use a different program to download cd's with like itunes, or winamp. they just pull the music from those folders to where you want them.
www.itunes.com
www.winamp.com make sure to get the free version
Feb 16, 2011 | Philips GOGEAR SA6045 MP3 Player
I have Phillips GoGear Vibe 8GB SA2VBE08K It is
Use a pen tip or other sharp object to insert the RESET hole on the side of the player.
Here is a page which shows you how to transfer music over to your new Phillips Media Player. Windows Media Player sync is specific to Windows products. Do NOT use this to transfer music to your Phillips media player. Use the software supplied by the manufacturer.
If this solves your problem, please come back and rate our solution. Thank you.
Dec 27, 2010 | Philips GoGear ViBE Digital Media Player
How do I download songs into my Philips GoGear Vibe Digital Mieadi Player
I opened my music window, highlighted everthing, right-clicked, pushed copy. Went to my computer/philipsgogear/internalstorage/music folder, right-clicked, paste. FINISH!:)
Dec 03, 2010 | Philips GoGear ViBE Digital Media Player
Philips gogear vibe your player is not connected.
How do I clear data (music, photos, etc.) that have been downloaded to my Phillips Go Gear Vibe MP3 ?
Oct 07, 2009 | Philips Audio Players & Recorders
Electronics - Others Logo
239 people viewed this question
Top Philips Electronics - Others Experts
Bill Boyd
Tom Chichester
Are you a Philips Electronics - Other Expert? Answer questions, earn points and help others
