Question about Sony KDF-E55A20 55 in. LCD Television
Indicator power light shows six red blinks - Sony KDF-E55A20 55 in. LCD Television
Your lucky. 6 blinking lights. Change your thermal fuse. You can purchase it for under $7.00
Posted on Jul 24, 2010
  • Sony Master
  • 8,457 Answers
The power supply board is dead.That the board,where the power a/c cord plug into it.U know basic's electronic,have tools and know bsaic soldering? Searches the power supply board,look for those parts call capacitors dying soon to be dead.These capacitors are alway bulges up on it tops or puff up on it tops.replaced these dying and about to be dead capacitors,ur tv will power up again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Posted on Jul 14, 2010
4 Suggested Answers
SOURCE: KDF-E60A20 Red Light Flashing 6x
My TV KDF-E60A20 is now Fixed. My tv was overheated and Thermal Fuse Located bottom of the lamp burned. I replaced a different Thermal fuse part from 191000644 to 191002393
at www.partstore.com
search for part number. thank you for the review it's help me a lot
thank again
Posted on Nov 27, 2007
a 6x blinking error code is usually the thermal fuse located above the lamp housing on the light engine. probable cause of failure is clogged fan located in same area or poor ventilation because set is to close to wall [unit requires minimum of 4 inches of clearance]. part # is 1-910-023-93. another possibility but less likely is the gm board which drives the lamp voltage. part # is a1109407a.
Posted on Jul 09, 2009
  • 556 Answers
SOURCE: No power, but red light blinks six times
your thermal sensor has fail this is on the side of the lamp holder inside the tv the light engine has to be pulled back in order to access it. Something of a job.
Posted on Aug 10, 2009
Morning, it flashes red light six times
From the manual:
Press the (ON/STANDBY) switch to turn on the projector. If
the power is not turned on, disconnect the AC power cord, then
confirm the ON/STANDBY lamp is turned off. After about 10
seconds, reconnect the AC power cord and turn on the power
again. If the indicators still light up, the electrical system has a
problem. Consult with qualified Sony personnel.
Jul 08, 2016 | Sony VPL-VW95ES Full HD 3D Home Cinema...
My KDF-55WF655 power led blinking red six times.
It looks like your power module is on the blink. Do you get any picture?
Jun 13, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Why does it have six red blinking lights?
Hi Tim
In my opinion
No... the LED's are doing their job
Error reporting
Modern TV's are computers and try to indicate where a problem exists.
Does it need a Firmware upgrade?
Red green or orange lights are on or blinking on the TV
Sep 22, 2015 | Sony KDL-50R550A 50" LED TV 1920x1080, 240...
Red light blinks six times. When I hit power button green light stays on for a few seconds, turns off the on for a few more. Then goes back to pattern of red light blinking six times.
the kill switch is open ensure the lamp cover presses firmly on the kill switch when u close the lamp chamber door the red light will stop blinking and u can now turn the tv on
Jul 06, 2013 | Televison & Video
Sony kdl46ex500 red power light blinks six times
Most probably there is a problem in the power supply and it is going on standby protection mode. You may have to search for a service manual from open websites and look through for the error code indicated by the led blinking, to be very sure. Unfortunately I do not have one with me.
Jul 07, 2012 | Sony KDL46EX500 46 in. HD-Ready TV
TV quit working when watching it, power light flashes red six times when trying to power on?
6 times blinking red light shows problem of missing DD 6Volts in G1 (power supply) board.
Please replace G1 board in tv to solve this problem, part number of G1 board is as follows..
A1060177A
Thanks.
Feb 05, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
MY wega 42inch wont turn on...the little green light flashes like five time as if it where to turn on but never does...and then it turns red and flash six times pauses and then again the red light flashes...
Six blinks indicates a faulty power supply. often caused by open thermistor located at under lamp assembly or beside it. Or a defective regulator on power supply section.. Check the thermistor and replace if found defective.. Or contact the nearest Sony service center at your area.
Oct 01, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Six blinking red lights when trying to turn on.
The power supply board went dead. Have it repair or replaced. No other way around this. Thanks, mike H.
Nov 26, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
Lamp or Bulb
Yes that is the indicator telling you its time to replace the lamp in your unit.
Jun 15, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
No picture or sound - Error code with Six blinks
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206
Sep 24, 2006 | Sony KP-57WV600 57" Rear Projection...
Sony KDF-E55A20 55 in. LCD Television Logo
284 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
