Question about Targus PAWM001U Mouse
I have a Targus mini mouse model PAUM01 and I've been using it for about 4 or 5 months. Recently today when I plugged it into my usb port my computer says it does not recognize the device. I was told it was a driver issue but I don't know for sure?
lifebyguitar
  • 57 Answers
SOURCE: Targus usb optical mouse not recognized by windows
Hi there!
The Targus WIreless Mouse with Power management is supported by Windows and does not require additional drivers. To confirm that Windows has loaded the drivers:
Click Start>Right-click My Computer>Select Manage
Select Device Manager
Expand the Human Interface Devices section.
You should see an entry for USB Human Interface Device. If you don't see an entry, right-click on the Human Interface Devices entry and select Scan for hardware changes.
If you don't see any results, look for any yellow question marks or exclamation marks underneath the Unknown Devices category. You may find the mouse listed there. If so, right-click on it and select "Update Driver". Select "Yes, this time only", then click Next, leave the default selection as is and click Next. If the update fails, try again except this time, after the first "Next", select the advanced option, "Install from a list or a specific location", then click Next.
Select "Don't search. I will choose the driver to install".
If a default selection appears on the screen that follows, click Next and it should install. If successful, I recommend you restart your machine for any changes to take effect. If the installation isn't successful, you may need to submit a ticket on Targus' support site.
I hope this helps you! If you have any questions, feel free to reply.
Posted on Aug 21, 2009
IKnow
  • 68 Answers
SOURCE: My laptop does not recognize my mouse.
Try going to:
Start, Control Panel, Mouse and under Devices select:
Disable TouchPad/Stick when a USB pointing device is present
Posted on Jan 18, 2008
Jastababe
  • 117 Answers
SOURCE: Targus Wireless Laser Rechargeable Notebook Mouse problem
The mouse worked initially....have you tried doing a system restore back to a few weeks ago to see if that solves the problem..
With Vista and so many of it's incompatibility issue's...you maybe have downloaded something and it corrupted your software for that mouse...
Here is the url with vista drivers. Redownload the drivers and install...see if this helps
http://www.targus.com/us/support_downloads.asp
Posted on Feb 25, 2008
firesnake09
  • 2923 Answers
SOURCE: Targus mouse not recognized
What is the OS of your computer? This Targus mouse would work with Win 98, Win 2000 and Win XP. Vista was not mentioned. And if you are running Windows Vista for you laptop, then that could be the reason why it was not recognized by the computer.
Is this the wireless optical mouse? If yes, you need to follow the steps below to isolate the problem:
1. Connect the USB receiver into different USB ports of the computer.
2. Replace the batteries with the fresh ones.
3. Try connecting the mouse into different computer to see if you've got a defective mouse.
If you've tried everything and got the same problem, you may need to refer to the manufacturer, because I'm not sure if this mouse is a Plug-n-Play device or if it needs a driver.
Have a great day!
Posted on May 26, 2009
SOURCE: I have the Targus wireless mouse amw10us. It just
Mine did the same thing, so I took it apart. The flip hinge in the receiver wore through the wire running between the plug & the little board inside. I'm shopping for a new mouse.
Posted on Aug 01, 2009
My retractable targus optical mouse keeps turning on and off when I plug it in. How do I take it apart? Model: AMU75US
The problem may be in the actual connectors. Try using a different USB port. If the mouse is out of warranty, you could snip the usb plug off and splice it into another USB connector.
Sep 27, 2013 | Targus Corded Mice AMU75US Compact Optical...
My mouse is lock need help please
Good day there, glad to be of assistance to you today.
What kind of mouse is it? Is it a bluetooth mouse with batteries?
1.Is it a regular usb mouse with lights on it? If so, please check if you've got lights on the mouse,it means it's being detected by the notebook. 2.Please shut down your computer first, as soon as the the computer turns off, unplug and plug the mouse back in then power it back on. 3.If that doesn't work, try plugging it to a different usb port and restart the notebook. If it's the same issue, please check if the mouse will work on another notebook when plugged in.
I hope this has helped you resolve your concern. Have a wonderful day.
May 12, 2011 | Dell Inspiron Mini 10 Notebook
Targus Model PAWM002 optical mouse will not work. When I plug the stick in the red light comes on and I have replaced the batteries in the mouse. Turned the switch on the underside of the mouse on and the...
click start control panel administration tool computer managenent device manager scroll to mice and other pointing devices you might see a yellow question mark? right click to update drivers
make sure the lead from the mouse has a secure seating and the lead is not bad/faulty
(if applicable)
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps dont forget to vote
Feb 28, 2011 | Targus Wireless Mini Optical Mouse
I barrowed my daughters lap-top while mine is being repaired. I plugged in the mouse and it seemed to load ok but I still cant use it. I went to the control panel and the mouse does not show up there. what...
Is it a wireless mouse?
First refresh the batteries.
Second:
refresh the USB ports:
1. Right click MY COMPUTER
2. Select PROPERTIES
3. Select HARDWARE
4. Select DEVICE MANAGER
5. Select UNIVERSAL SERIAL BUS CONTROLLERS
6. Right click on each USB CONTROLLER and select Uninstall
7. Uninstall all entries
8. Reboot your computer
9. As your computer re-boots it will reinstall all USB connections it detects
THEN, when all other USB items have been configured and connected by the system, you then should try connecting your mouse.
Third:
download the driver from Targus:
http://www.targus.com/uk/support_downloads.asp
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy New Year!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jan 07, 2011 | Targus PAWM001U Mouse
I need a wiring diagram for a Targus PAUMO1
Not worth it!
One wrong wire could burn out multiple USB ports on your computer (or any computer the device is plugged into).
It would be best to get a new or used mouse.
Apr 24, 2010 | Targus Ultra Mini Optical Mouse With...
Power supply for Targus 4 hub usb 2
Most USB hubs do not need an external power supply, except when a connected USB device draws more power than the computer/laptop USB port can supply. In this case an external power supply will need to be connected to the USB hub.
Normally this would be a 5 volt power supply, but make sure the polarity on the connector matches the power connector on the hub, check the label on the hub, sometimes it states to power requirements of the hub as well as the polarity on the connector. Normally the pin on the hub's power connector is positive (ie. +5V)
Nov 13, 2008 | Targus PAUH217U 4-Port USB Hub
How to set up and use targus wireless computer mouse model#amw26
Under the mouse there should be a usb stick attached to the mouse which most likely should slide out from the mouse. It also appears that the plastic cover behind the two buttons (this cover has targus written on it) Should come off. After you remove the usb stick there might be a button somewhere on the bottom of the mouse that you should be able to press to get the battery cover to pop up. Then you should be able to pull up on the battery cover and remove it from the mouse. This mouse takes two AA batteries. Once the batteries are installed then plug the usb stick into any of the usb ports on the computer. The computer should recognize the drivers for this mouse (if you are using Windows 2000, XP, Vista, or Mac OS X [or higher]). If the drivers are not immediately recognized then restart your computer and the computer should then recognize the mouse. If this still does not happen then let me know. Also there is software that can be downloaded from the Targus website for the tilt wheel as it has some added capabilities that can be set using this software. The link for that software is here ------> http://www.targus.com/us/product_details.asp?sku=AMW26US
I hope this helps, and enjoy that mouse, it looks pretty nice!
Sep 20, 2008 | Computers & Internet
Targus PAWM001U Mouse Logo
496 people viewed this question
Top Targus Computers & Internet Experts
J John
Dudeman321
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
