Question about Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM
Flotec pump model FP 4112-08 will not pump over 35 psi
  • donsuebeale Jun 22, 2011
    I tried various solutions and in the end I decided to strip the pump down to invistigate the problem.
    The pump impeller was blocked with small stones and a whole pile of crapp. Cleaned everything out and ran the pump distcheageing through a garden hose and evem more crapp came out. Pump runs quiet and gives a distcharge of 50 psi and is the best pressure since we moved in.
  • 553 Answers
If it stops pumping at 35psi you need a new pressure switch. If it just continues to run but doesn't build more pressure the problem is more likely a plugged point or air getting in due to the water table dropping.
Posted on Jul 14, 2010
How do I increase the pressure on my Flotec FP711OT-08. It is low 40s psi, can I move it up to 50 psi or high 50 psi? Water pressure throughout the house is low.
There may be a pressure setting on your outfit but My feeling is -- your problem will be low pressure on your water line. Most pressure settings is to keep from having too much pressure on what your running. For instance our city water pressure is 70 lbs but in order to keep my furnace boiler system at 16 lbs I have to install a pressure reducer.
Nov 23, 2014 | Pentair Flotec Fp7110t-08 Water Tank...
My flotec 1/2 hp shallow well pump pumps to 45# of pressure rapidly, takes longer to get to 49# pressure and then takes 30 - 45 minutes to reach the 50 psi shut off pressure. The pump is hooked up to a...
Those pumps will reach 50# when brand new, but soon the parts wear and then they will not make that pressure anymore...
Instead of replaceing the pump, just back the pressure down a tick or two to get it to shut off and not waste your electric....
Well Pressure Switch Adjustment Water Well Problems
heatman101
Jan 03, 2011 | Flotec Corrosion Resistant Shallow Well...
My shallow well pump starts and stops way to often. How much pressure should I have on my pressure tank
I would like to know what size tank you have and how you use it? I have always set my pumps pressure switch at 30 psi. on and 50 psi. off. But you may have different settings. What I do is set pressure in tank at 2 psi below on pressure. In my pump it is set at 28 psi. Hope this helps. Thanks
Nov 14, 2010 | Flotec Plumbing
I have a flotec shallow well pump i can not get it to pump the water it stays at 20 pounds did i hook it up wromg
check your pressure tank. It sounds like it is water logged. This means there is no air pressure in it. If you're cut in pressure is set at 30 pounds you must have 30 psi of air pressure in the pressure tank.
Oct 01, 2010 | Flotec 3.4 Hp Floodmate Submersible Sump...
Removal of inlet outlet casing
they have plastic clips that hold it into place.
Apr 06, 2010 | Flotec Corrosion Resistant Shallow Well...
I have a broken sump pump, Flotec model # FPOF360AC
Same pump, same problem. H/D sells the pumps, but no parts. Here's a link to a vendor of Flotec parts. http://www.pumpvendor.com/Flotec_Parts_List.html
Apr 01, 2010 | Flotec Simer/Flotec/Omni 2105 Swimming...
Flotec Corrosion Resistant Shallow Well Jet Pump 1/2HP, 8GPM Logo
639 people viewed this question
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
john h
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
