Question about Zanussi WJS1265W Front Load Washer/Dryer
Tumble dry problem
When setting the machine to dry . It starts as normal and then I get an error message E10
  • 713 Answers
Error 10 is a low water pressure alarm.Check that the drain tube is clear and in the drain pipe correctly.Does it take a long time to fill.There could be a problematic pressure switch or hose to this switch,or faulty Inlet valve or even a faulty Circuit Board.
Posted on Jul 14, 2010
Hi, my Electrolux EWX12550w washing machine and dryer, working fine on was but when I'm drying it it starts at 13 minutes then keeps working but sticks on 10min also I get an err sign it's E10
Family error code E10 is visible to customers and (could be E11,E12 and E13 only visible in service mode) means problem
with filling water.
I suggest rapid reading alarm code when appliance is in normal operating mode (e.g. during the execution of the washing
programme).
Press and hold down START/PAUSE and the nearest option buttons for at least two seconds: the LEDs initially switch off, and then display the flashing sequence corresponding to the last alarm.
The alarm sequence continues as long as the two buttons are held down.
E11 - Problems with water fill for washing
E12 - Problems with water fill for drying
E13 - Water leakage
I believe there are difficulties in water fill for drying.
Water is necessary in the drying phase in order to cool down the steam entering in the drying condenser.
Possible causes: Tap closed or water pressure too low; Drain tube improperly positioned; Water fill solenoid valve is faulty; Leaks from water circuit on pressure switch; Pressure switch faulty; Wiring faulty; PCB faulty
Dado
Sep 07, 2015 | Electrolux Washing Machines
Error code e10 on zanussi zjd1219
E10 on the drying cycle normally indicates a failure to take in water during drying
this is usually a failure of the triple water valve unplug your unit take the top off you will see the valve at the rear of the appliance change out the water valve and you should be up and running again the service manual states that it could be the triple water valve , the wiring , or the main control board if you have any further questions message me back and please remember to rank how this opinion has helped in your appliance situation it allows me to help others in similar situations Thanks Rick
Mar 23, 2011 | Dryers
AEG Lavamat washer dryer, machine washes clothes fine but gives error code E10 every time dryer is put on. Any ideas how to fix this?
Yes you need to change the cold water valve you dont mention the model so it will either be a 2 coil or 3 coil water valve. one of the valves responsible for the tumble drying condensing is faulty.
Jul 30, 2010 | Dryers
What does E10 mean? is this an error
E10 means your machine has not filled to the correct water level (10 mins allowed) low water flow or blocked filter in the water valve . or faulty valve.check tap is turned on.
Jun 17, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
Kenmore front load washer error code E 10 - washer stops and beeps periodically and needs to have start button pushed again to complete cycle. Seems to happen one minute into cycle and then a coupleof...
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 11, 2010 | Kenmore HE2 Plus Front Load Washer
E10 code on a zanussi jet system washer
Is it a washer-dryer? E10 relates to a fault with the inlet valve.....usually the valve itself going open circuit.
Feb 26, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
DRYER NOT WORKING
E10 means theres no water going into the machine.Your machine has a triple water valve the 1 that feeds the dryer has proberly failed. Comes as a comp unit.
Dec 02, 2008 | Zanussi FJS1225W Front Load Washer
E20 error when starting tumble dry cycle
E20 on your machine means some sort of Drain problem. If it actually goes through the Spin cycle o.k. then there is most likely some water still not drained out at the time of the tumble dry. Check the drain to make sure it isn't clogged. also the drain hose.
Feb 29, 2008 | Washing Machines
E10 error code
I had this problem, the washer/dryer stopped working while in the drying cycle and displayed e10 message. It was caused by a faulty three-way inlet valve. The solenoid controlling flow to dryer condenser proved to be open circuit. Pulled washer out from under counter top, unplugged, removed top cover, tested solenoid circuits with ohm meter and found one solenoid was faulty. The filter going into the unit was clear. Replaced whole three way component with one ordered on Internet and all now works fine. Noticed that during drying cycle, water to condenser is constantly being switched on and off, explaining why the green condenser solenoid is the one that wears out first.
Mar 03, 2007 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi WJS1265W Front Load Washer/Dryer Logo
160 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
