Question about Maytag Neptune MCE8000AY Electric Dryer
Inherited a maytag neptune dryer. Do not have the owner's manual. The temperature light does not show up so I don't know how to tell what the setting is. When I set to sensor and then change the temp setting the time changes but not sure how time relates to temp in order to tell what the temp setting is. Any suggestions on knowing what the setting is or how to fix?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Maytag Master
  • 102,366 Answers
Http://www.kitchenaid.ca/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%202206670.pdf
Posted on Apr 28, 2011
Hello, my dryer MDE5500AYW won't dry on a cool temperature. It is an electric dryer
You buy no parts
You diagnose the problem
to find something wrong
How about looking in the owners manual
& follow the trouble chart
I do not know about Maytag Dryers, but the washers
have a diagnostic manual in a bag under the cabinet,
they don't want you to find,your dryer may also.
Nov 20, 2014 | Maytag MDE5500AYW Electric Dryer
Put detergent
MLG2000A - Maytag Neptune Super Stack SL-3
1 - Select Wash/Rinse Water Temperature
2 - Select Options (Max Extract, Extra Rinse, Signa)
3 - Select Cycle
4 - Load the Clothes Washer (add detergent on top of the load in the tub, and additives [fabric softener, bleach] in their dispensers).
5 - Start the washer.
This is according to the owner's manual I have. Has worked for 14 years for me.
Jan 14, 2014 | Maytag Neptune MLG2000A Front Load Stacked...
Maytag neptune Dryer won't start. Get an error
reset the dryer .disconnect the power cord by 30 -40seconds, and try again, if the problem persist with the error, read you owner manual in troubleshootign section. or dwonload the owner manual for identify the error problem, can be problem a temperature.
go to www.retrevo.com
God bless you
Jul 28, 2013 | Dryers
I just "inherited" a maytag neptune front load
http://www.kitchenaid.ca/assets/pdfs/literature/2206687.PDF
http://www.kitchenaid.ca/assets/pdfs/literature/6_2727060.PDF
Oct 27, 2010 | Maytag Neptune MAH5500B Front Load Washer
My maytag neptune dryer is not heating up. we
You should have your owner's manual on hand to locate specific parts and understand how to disassemble the dryer. Also make sure that the power is disconnected from the appliance before making any repairs.
1)Check the fuses near the heating element. Inspect them for breaks inside the fuse. Replace them if necessary.
2)Test the temperature switch with a volt-ohm meter. Set the meter to RX1 and zero it out. Touch the meter probes to each terminal on the switch. The reading should be zero. Next turn the switch on and test it again. Now the reading should show infinity. If the switch fails either test replace it with a new one.
3)Check the heating coil to see if it is bad. Use the volt-ohm meter and touch the probes to each of the heating coil terminals. If it reads zero, the heating coil needs to be replaced.
May 07, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Maytag Neptune Gas Dryer "do" code
sonds as if you have abad door switch assy, uint not reconozing the door closed
Oct 29, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MCE8000AY Electric Dryer Logo
32 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
