Question about Boating
1987 Evinrude 30 HP, Model CE30CRUB stalled and won't start again
I have a 1987 30 HP Evinrude which was running fine until she just stalled when I was at about 3/4 full throttle. I noticed a bit of water dripping from the upper case where the motor is located and saw about a 1/4 inch of water inside. Everything looked dry except the bottom part. I am not sure if that was because the motor stopped so suddenly...this is what happened. I could not get it going again. I checked the spark plugs, the carb, and fuel pump/filter. It is getting gas and compression from what I can tell. I let it dry out all day in the sun, just in case water got inside somewhere. When I pull the starter cord, it doesn't seem to spark or do anything like normal.
My question is..could it be or is it likely the power pack? Remember it was running when this happened, she just won't turn over at all. I am trying to keep my costs down.
Thanks in advance for any help you may be able to offer!
Jeff
  • 677 Answers
Hi,it might be?.power packs are not friendly with water.
You can troubleshoot the plugs, might also be the coil that is sucked too.
Do a general troubleshooting for the engine.
Take care.
Posted on Jul 14, 2010
What is the idle timing for 1993 90hp evinrude
90 hp 1993 evinrude idle speed - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 3, 2008 - 2 posts - ‎2 authors
"How many rpm should the engine idle at,and where and how do you adjust it Thanks" 50 hp evinrude no idle and no top speed need assistance ...
Jul 6, 2013
1993 50 HP 2 cyl Evinrude stalls, runs at idle when ...
May 7, 2012
adjust carburators and idle speed 1993 48hp
Jul 29, 2010
90 hp stalls when going in gear
May 21, 2010
More results from www.marineengine.com
1993 Johnson 90-HP Runs Only At Idle Speed On Spring Start-Up
Johnson 1993 115 xflow Link and Sync - YouTube? 4:55https://www.youtube.com/watch?v=ReeuaVh8uZQNov 25, 2012 - Uploaded by Brian O'DellJohnson 1993 115 xflow Link and Sync. Brian O' ... Also if you can give me some details on how you got the ...DOWNLOAD Evinrude 90HP (90 HP) Repair Manual
Dec 14, 2015 | Boating
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Dec 09, 2015 | Cars & Trucks
Kawasaki 17 hp stalls when hot
you need valve job done and new valves put in and i said new valves do not use old valves again 150.00 per cylinder
Sep 07, 2014 | John Deere Garden
My 1987 Nissan Stanza stalls out after warming up
hi john
I have a doubt that the ignition coil if faulty, it stop to send spark
when it warm-up
good luck
Jan 24, 2014 | 1987 Nissan Stanza
1987 300 zx starts the quits after 2 minutes and won't start again
probally crank sensor. starts then stalls after driving a few min. then won't start for awhile. u can actually check it on the ecu. 4 green lights then 4 red lights. if you can't run the comp check on ecu let me know i'll look it up its been awhile had same prob years ago all my sensors are new
Oct 28, 2011 | 1987 Nissan 300ZX
Suburban stalls while driving after running for 15-30 minutes. After letting it sit for 5-10 min it runs fine for another 5-10 minutes, then starts doing it all over again.
a bad crank sensor can cause this. shuts off while going down road, and will start about 10 min, later with no problems runs fine until it quits again. hope this helps,
Oct 07, 2009 | Chevrolet Suburban 1500 Cars & Trucks
40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Apr 27, 2009 | Boating
1987 dodge omni will not start when it is cold
Adjust choke assembly. Good mechanic, 5-10 min.
Dec 15, 2008 | 1987 Dodge Omni
Boating Logo
151 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
