Question about Landice L9 Cario Trainer Commercial Treadmill
The belt hangs or slips. Makes noise.
The belt tends to hang or slip? I am told it needs oil on the roller. I have oil. How do I apply to the roller? Bottom and top don't offer acess.
Help!
    President:
  • Landice Master
  • 832 Answers
Lubrication may not be the issue, belt tension could cause the slipping at the end of the unit their is 2 tension bolts. 1/4 turn clock wise on these bolts will increase belt tension, start with 2 quarter turns on each bolt then start unit and proceed to walk on it, see if slipping has stopped. If not repeat procedure only turning the bolt 1 1/4 turn at a time until until proper tension is achieved. If the unit need lubrication then us a tube of clear silicone which you can purchase from Landice,
Call them @ 1-800-526-3423
Posted on Jul 19, 2010
Dryer makes excessive grinding noise
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your drum belt has slipped off of the idler arm pulley.
Check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear.
Be sure to note the route of the belt, this will come in handy when you go
to reinstall the belt.
Check your drum rollers for flat spots or wear, if they have flat spots
or wear on them replace them.
If the drum rollers don't have flat spots or wear on them then they probably
only need lubrication. Lubricate the shaft of the rollers with a good grade
of machine oil such as 3 in One oil.
Reassemble the dryer, plug back in. This should solve your noise problem.
Please rate me
Jan 23, 2011 | Bosch Axxis WTA 3500 Dryer
Runs but makes loud noise
If you have a front loading machine,
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer.
Be REAL CAREFUL not to knock any of the wires off of the timer switch.
Then remove the top of the dryer.
Remove the front of the dryer. This will expose the drum and belt.
Remove the drum and belt and this will expose the drum rollers, idler arm
pulley and motor.
Now is a good time to check the belt to see if it has slipped off of the
Please rate me
Jan 14, 2011 | Kenmore Dryers
THE DRYER MAKES A LOUD GRINDING TYPE NOISE AND THERE IS A BURNING SMELL WHEN IT STARTS
Sounds like you have two problems cause by one problem.
Your noise is coming from your drum rollers needing oil and the smell is cause by the drum belt slipping because of the added pressure to try to turn the dry drum rollers.
pulley and motor.
Please rate me
Dec 24, 2010 | Dryers
DRyer makes loud screaching noise
Please rate me
Dec 23, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Dryer makes very loud rumbling noise when running?
pulley and motor.
Please rate me
Dec 05, 2010 | LG Dryers
Dryer makes clunking noise and is very hot
pulley and motor.
Please rate me
Dec 04, 2010 | Frigidaire Dryers
How do you replace a drive belt. Dryer makes a noise. Sounds like belt is slipping or something wrong with clutch. Need to see a diagram.
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Sounds like your problem may be a broken belt, or the belt may have slipped off of the motor pulley, or idler arm pulley.
If you have to check/replace/repair your drum motor or belt and if you have a front loading machine:
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
For this FREE answer, Please rate me
Sep 22, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
The dryer makes a noise as if the belt on the drum is slipping
Sounds like your problem may be the belt may has slipped off of the motor pulley, or idler arm pulley.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn or make a squeeking noise.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
May 28, 2010 | Hotpoint Ariston NWXR483EGWW Electric...
Model # md7600 makes loud squeeking noise
Your problem sounds like drum rollers have flat spots on them or in need of lubrication, or maybe your belt has slipped off of the idler arm pulley.
If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt to see if it has slipped off of the idler arm pulley and also to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Dec 05, 2009 | Dryers
When the dryer is running it makes a loud noise like the belt is slipping?
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
You can also check the belt and the idler roller with the drum out to see the condition and if they need to be replaced.
Good Luck,
I hope this helps
Oct 11, 2009 | Hoover Dryers
Landice L9 Cario Trainer Commercial Treadmill Logo
177 people viewed this question
Top Landice Exercise & Fitness Experts
Howard
Howard
lloyd cole
Dave
Are you a Landice Exercise and Fitnes Expert? Answer questions, earn points and help others
