Question about Golden Technologies Health & Beauty
Golden Technologies Companion I scooter
Light works, horn works, can hear relay click but no power to the motor. Steady green light. Is it the circuit board or ??
  • jdhamm10 Jul 15, 2010
    Golden Technologies Companion I scooter.
    Have 24 volts from the batteries going into the printed circuit control module but no voltage coming out to the motor. The horn works as well as the light. I can hear the relay click to reverse direction.
    Is it the controller board?
    Thanks
    John
  • 6,826 Answers
Http://www.goldentech.com/pdf/support/ride/ScooterParts.pdf
The above is a parts list for various scooters made by Golden Technologies, and a lot of circuit boards are listed for other models such as the Eagle Standard, for instance.
http://www.goldentech.com/ride/companion/original.php
The above shows information for the companion series of scooter, which you have.
Finally, if you have a relay click and no power to the motor, then I think it might be a relay that is internally having a burnt contact problem.
Also, check the charge on the battery, although, I think that if the circuit board has enough voltage for the circuit board to 'click' the relay, that it's likely this is not the problem, unless the battery is old or the charger is not charging up the battery fully.
Here is a detailed list of possible codes that the circuit board can display through self diagnosis.
http://www.goldentech.com/pdf/products/companion_manual.pdf
The above tells me the flashing light codes, You'll need to download Acrobat Reader from Adobe.com (it's a free download), if you don't have that program on your computer system to view the .pdf file for this scooter.
FIGURE 45. MAIN CIRCUIT BREAKER RESET
Possible causes for the main circuit breaker to trip:
• Low tire pressure can cause the motor to overload and trip the main circuit breaker.
(see “ Wheels and Tires” in this section of this manual and see section X. “Diagnostics”)
• Run-down batteries.
As you operate your Companion, battery voltages go down and battery current must
rise to satisfy the demands of the motor and of other electrical devices operating on your
scooter. This can cause a heavy current draw that will trip the main circuit breaker.
Remedy:
• Recharge your Companion’s batteries. See “Charger and Batteries” in this section of
this manual.
• If the problem continues, have your authorized Golden Technologies, Inc. dealer load
test the batteries.
• If the batteries are good, the charger may be the problem. Consult your authorized
Golden Technologies, Inc. dealer.
Resetting the Main Circuit Breaker
If the main circuit breaker trips as a result of run-down batteries or because of a temporary
overload, reset the circuit breaker:
1. Wait a minute or so for the motor control board to return to the normal operating
temperature range.
2. Make certain that the key switch is set to the “Off” position.
3. Press in on the main circuit breaker reset button. See figure 45.
NOTE: If the main circuit breaker continues to trip, there is probably an underlying
electrical fault that needs attention.
Good luck on fixing this problem and contact me if you need anything else!
Posted on Jul 15, 2010
  • Duane Wong
    Duane Wong Jul 15, 2010
    I read some more and it says that if the green light is constant, it has enough charge.
    So, I think the relay may be burnt, and that this is serviceable through the dealer, if you cannot do it yourself.
    I wish you luck in this repair.
    Good day.
  • Duane Wong
    If the unit's trouble codes are flashed and the green light is on and you hear clicking at the relay, I would think that the circuit board is alright, but the relay is burnt somehow.
    Try to replace the relay which shouldn't cost too much if still available from the manufacturer.
    If this doesn't work I would be surprised.
    You see, the relay has a contact inside that if burnt, you'll hear it clicking, but no voltage will go to the motor.
    OK?
    I wish you luck in repairing this problem and thanks for submitting your questions to Fixya.com.
  • 1,284 Answers
Hi, if the starter motor will turn over when you jump a wire to the brown wire on the starter solenoid then you know that the starter motor is fine. Similarly if the starter relay clicks then you know that the ignition switch and the park/neutral safety switch is OK. So that leaves the relay's internal contacts not conducting due to oxidation or the brown wire from the in-board most pin of the relay socket (30) to the starter motor solenoid is 'open'. Try jumping from the battery to that in-board pin and if the starter motor fires up then the relay's internal contacts have to be bad. Try swapping that relay with another one to verify that is the case. If the jump to the relay pin doesn't cause the motor to energize, then the wire is open.
If your starter relay clicks, then the ignition switch for that part of the circuit is OK.
Take care
Posted on Jul 14, 2010
    The motor is ok - checked by resistance and power.
    There is 24 volts going into the printed circuit controller but no voltage coming out to the motor. Can hear the reversing relay click.
    Has to be that board unless there is a control circuit going in on one other other connectors.
    Thanks.
    John
    P.S. We are talking about a Golden Technologies Companion I scooter right?
  • Shehu Pro
    Shehu Pro Jul 15, 2010
    Same here too
GOLDEN COMPANION SCOOTER HAS NO POWER TO MOTOR UP EVEN VERY SLIGHT GRADES OR HILLS
If batteries are ok. I would check motor brushed. Make sure they are long enough. Clean and make sure they don't stick. Check colour of comm in motor. Check all connections are tight.
Oct 05, 2014 | Golden Technologies Companion II 3 Wheel...
I have a Golden GC321 When the battery charger is on there is a green light and next to it is a red light Does the red light ever go off when charging.
the gc 321 has a diagonistic sender built in, go to golden companion.com
and down load the owners manuel for it, its free and very helpful, when you 1st turn on the key , you count the times the red lite blinks an it will diagnose your problem, then you look it up in the manuel!
also go to monster.com and type in make and model, a set of keys is about $10
Mar 04, 2013 | Golden Technologies Golden CompanioN II -...
Golden companion II full charge turn key on press lever to go forward it dont move hear clicking sound green light on dash blinks
John count the number of flashes by the green light and it will be the fault code indicating the problem Your owners manual should list the fault codes to be able to determine what the problem is. Ie 4 blinks pause 4 blinks pause. The clicking you hear is the electric brakes being engaged. Hope this helps
Mar 01, 2011 | Golden Technologies Companion II Travel...
No forward or reverse. lights and horn work micro switch on brake has continuity with brake off batteries charged and all connectors reseated. Motor spins forward and reverse when voltage appled...
Joe with a scooter there can be a number of things wrong to cause your problem Since the motor turns and you have power at the console. It could be the throttle pot or the speed pot or both or it could be the cable that runs from the console to the rear of the scooter and finally a problem with the controller. But that would also give some sort of error to the console light if it is equiped with a power light. If Medicare paid for your scooter then they will pay most of the cost of repair. Your provider can work on it for you or they can contact a repair service that will fix it for you Hope this helps
Sep 27, 2010 | Golden Technologies Companion II Travel...
Green light flashes 9 times will not go
Hi. Different brands of controllers give different fault codes.If this is a dynamic controller, 9 flashes is the code for a faulty controller. This does not always mean that the controller is actually at fault.
It could be a burn't out brake solenoid, that now has a different resistance through the solenoid coil.
You mention the middle speed green light is flashing, normally on dynamic controllers, it is the most left battery level LED that flashes. You might have a different controller.
Have a look under the panels and let us know what controller your machine has.
You could try the agents, and see if they can tell you what the problem is.
Good luck. Neil.
Jun 06, 2010 | Golden Technologies Companion II Travel...
Golden Companion Scooter not moving - diagnosed via owner manual
Hi. Many scooters will display this fault code if the potentiometer is not exactlly centred when you turn on the key. The pot is not always faulty. Some scooters also have a smaller additional pot to controll the speed. If this pot is faulty it will cause the same fault code. Any other switches such as indoor/ outdoor switches. I have had a few machines fitted with curtis controllers where the fault is in the controller.
Check the wiring and plugs and connectors.
Good luck. Neil.
May 09, 2010 | Golden Technologies Companion II Travel...
Fix mobilty scooter
This scooter should NOT work with the charger plugged in
Unplug and try
Apr 21, 2010 | Golden Technologies Golden CompanioN II -...
Not moving and green light is flashing
this is batteries
if slowed down first then stopped
mobility centre penge
Apr 14, 2010 | Golden Technologies Companion II Travel...
Golden Tech Companion II: Doesn't go, batteries
Accessibility Specialists Inc
1815 Corporate Sq Blvd
Ste 200
Jacksonville, FL 32216
(904) 725-0601
Nov 21, 2009 | Golden Technologies Companion II Travel...
Scooter will not move
make sure you have put it back in gear, sometimes the freewheel lever is not fully engaged. the light should not blink when the lever is in the drive position.
Sep 11, 2009 | Golden Technologies Companion II
Health & Beauty Logo
124 people viewed this question
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
