Question about Home
We have a oasis whirlpool bath tub model s2283-6j3wht that stoped working, there is power to the plug in, but no lights will light or pump wont run
  • 33 Answers
Possibly an internal fuse has blown..
Posted on Aug 02, 2010
New replacement in-line heater (C3B54P0-3002AU0) inop.
Bath tub heaters will only maintain the water temperature in the bath. They will only heat the water approximately 1-2 degrees an hour.
Whatever water temperature you start with is what you will be able to maintain.
There is a red indicator light on the front of each heater indicating whether or not there is power to the unit when the tub is full of water and the water pump is turned on.
If there is a red light on then it has power to it and is working.
This heater will never feel warm to the touch.
There are three different styles of Bath Heaters available.
  • Tee Heater - installs on the discharge fitting on the pump
  • In-line Pressure - installs anywhere in the plumbing line before any jet.
  • In-line Vacuum Heater - installs before the suction of the pump
If the heater you purchased is installed in the wrong place it will not operate.
Rod
US Parts Center
Dec 04, 2013 | Maax Calla 6042 Bathtub - 101058-000
Push button on my jacuzzi won't start it despite power going to unit
The air button on your tub may be bad and not sending enough air to the air switch located on the bath pump.
The way to check this is to remove the bath pump and see if you can turn the bath pump on by taking a large straw and blowing into the air switch on the bath pump to see if you can get the bath pump to turn on.
If the bath pump comes on then you know you have a bad air button.
If you cannot get the bath pump to turn on then remove the air switch and plug the two wires going to the air switch together and then plugging the pump into a power outlet you know has power.
If the bath pump comes on then you know you need a new air switch in the motor.
If the motor does not come on then you need a new bath pump.
Rod
US Parts Center
888-521-6183
Mar 10, 2013 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
I need a replacement pump and motor for an older Bath Tub Whirlpool The motor is an Emerson 1/2 HP 115 vac (Model # SA55NXKHC-5590) and the wet end Part # is 91040810.
that is an Aqua Flo bath pump model TMCP 1 hp model. that has been replaced by the NEW Mfg with a pump called the WhirlMaster.
You may find that pump at www.uspartscenter.com
Feb 12, 2011 | Home
I have an air tub with and aquaflo tub master pump
probably already solved this but yes, you can put a heater on any bathtub that has water jets.
Feb 02, 2010 | Aqua Flo Aquaflo Tub - Master Tmcp 3/4 Hp...
Jacuzzi outdoor bath tub i have there is power but the bubbles thing isnt working
Find the plug for the pump and plug it in ( tub full of water), if the pump works,the problem is in the contol box or switch. if the pump/motor has a plastic tube coming out of a black box, and the pump still does not work when plugged in, it is most likely the air switch connected to that plastic tube on the pump. the switch is avaliable online and not to hard to replace if you are mechanically inclined.
Sep 26, 2009 | Whirlpool 5"x36" White Bathroom Drop-in ...
I know I can take a bath without turning on the jets. However; does the bath water with soap flow back into the jets? I like bubble baths, If I leave the jets off can I use the bubble bath without having...
The soapy water will fill all of the jets, tubes and the pump assembly. Will it hurt the tub if the jets are not running? The soap film will build up in the jets, tubes and pump assembly and can possibly cause damage if the tub is run at a later date. Contact the tub manufacture and see if there is a safe bubble bath you can use.
Aug 23, 2009 | Jacuzzi - Bathtub - Alcove - Navona -...
"Jacuzzi j-400 series" hot tub- F1 code flashes on control panel
Your circulation pump isn't working you should see the flow awitch closing if you have the visible model and hear the pump running.. If its the smaller circulation pump model it needs replacing
May 18, 2009 | Jacuzzi Bath Nova H530 917 Black Soaking...
2748.328 Town Square 5' x 42" Air Bath Tub Won't Work
Air bath tubs have a preset time limit. it could be that it reached that limit. Especially if the lights are still lit up on the control.
Dec 29, 2008 | American Standard 2748.328 Town Square 5'...
Kenmore oasis he, ld flashing at 8min.
Sounds like a bad lid switch. Many times you can test these by using a small jumper wire to connect the two wires on the switch it's self.
Jul 18, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Home Logo
241 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
