Question about Garmin nuvi 260 Car GPS Receiver
1. After last map update, my Garmin nuvi 260 no longer says street names. When I "returned to factory settings" it said names again, but the maps were no updated. Is there a way I can do both? 2. I just moved to washington DC. My garmin has not stopped "searching for satellites" or "acquiring satellites" since I got here. Tried restarting it, didn't work. Is there a special DC add on or am I just gonna have to get out one of those paper maps?
    Top Expert:
  • Garmin Master
  • 83,843 Answers
If it has stopped picking up the satellite signal then the GPS is defective, this is the most common failure other the battery failing, which is about every 2 years, due to the cost of this model ($139 in recent Best Buy add) it is no worth it to have Garmin repair it (average cost $125) unless it is under warranty, the new GPS will come with all the latest maps and one free up date.
Posted on Jul 14, 2010
Why garmin nuvi 54lm does not speak out name of street in turning
Go to settings and make sure the mute button is unchecked and the volume is turned up!
Dec 09, 2014 | Garmin nuvi 54LM 5" GPS with Lifetime Map...
Can't unlock maps on garmin nuvi 255w after update
You can try to power down for hard reset(disconnect battery) and after connect again or reset to factory setting.
Mar 19, 2013 | Garmin nuvi 255W GPS Receiver
Garmin Street Pilot. No upgrades available from Garmin. Can it be updated some other way?
Hi Steve,
The Street Pilot line was one of the first automotive GPS devices from Garmin, and has got to be 8+ years old. Garmin contracts with Navteq for map software. At one point, Garmin needed to have Navteq compress their new maps so that they wouldn't need to increase the amount of memory in the GPS units and still be able to include all the way points, and new features such as junction view, traffic receivers, text to speech voices, etc. These new maps have an "NT" descriptor in the title. "NT "stands for "New Technology". Non-NT maps are no longer produced.
The new Garmin GPS hardware had to included the ability to decompress maps "on the fly" for display on the screen. As a result, the NT maps will not work in the older Garmin devices.
Your best bet is to either use the Street Pilot - knowing that the routes may no longer provide accurate information, or purchase a New, Refurbished or Used GPS. Garmin offers "Lifetime Maps" as an option for nearly all NT capable GPS units either as a subscription after GPS purchase, or "in the box" when buying a Garmin GPS. You'll get FREE map updates for that GPS up to 4 times per year. This assures you of always having the most recent maps available in your GPS. Look for a model that has "LM" in it (ie: nuvi 1490LM). If it has a "T" in the model name (ie: nuvi 1490T), it has Lifetime Traffic. If it is listed as "LMT" (nuvi 1490LMT) it has both Lifetime Maps and Lifetime Traffic.
I hope helps!
Mar 20, 2012 | GPS
Hi, I have a Nuvi 255 (205 series) gps, three years old. Last week the screen went blank, came back grey with 'crosshairs' and a black dot in the middle indicating 'press here'. I did so and the dot moved...
Graham - what your describing sounds like you somehow managed to erase the street level maps and POIs in your Nuvi.
If you connect the GPS to the computer with your USB cable, you should at the contents of the Nuvi directories and find a file called GMAPPROM.IMG or GMAPSUPP.IMG. These are the street level map files. Generally, these are found in the root directory of the Nuvi - or if yours has / and you use a memory card slot for maps - find it in the /GARMIN directory. GMAPPROM.IMG is the name of the first map set and GMAPSUPP.IMG is the name of the supplementary or second map set (if you purchased & installed one). You will likely have only one of these files - and may be named either. The size of this file depends on the area and age of the map. Current maps of the entire US run over 1 GB in size. If you do not have any maps named GMAPPROM or GMAPSUPP, you will not see any street level maps.
Something happened to delete the maps. Garmin will probably NOT provide free replacement maps for you, unless under warranty. If the devices is trashing maps and other files, you probably want to replace the unit under warranty or not. Garmin will, upon return of your old Nuvi - replace it with a factory refurbished unit with the latest maps installed, for $79. You can take advantage of this service by following this link to Garmin Service.
I hope this helps and good luck! Please rate my reply. Thank you.
Mar 23, 2011 | Garmin nuvi 205 GPS Receiver
Tech support
Here is a hint to check the map in your unit to see if they are the newer version.
Click on the Tools icon, then "Settings", next "Map", and last click on the Map Info button. Your map version is listed here. If it is not the same as the version of the update try running the update again.
Jul 13, 2010 | Garmin nuvi 260 Car GPS Receiver
Have usa garmin nuvi 260 ,want to load austalia maps how?
well you need to update the firmware of your gps also call garmin customer support they are great tell them about the map, also the poor satelite cover might be because of your location or weather conditions
May 26, 2009 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 260 maps loading
http://www.garmin.com/garmin/cms/site/us/support/
Hope this helps
Apr 05, 2009 | Garmin nuvi 260W GPS Receiver
Nuvi 260 question
Yes it does.
You would have to pay for the Map
Yes, it can give directions in Spanish
You'll have to download that language (free) from Garmin.
But before you do anything you must download the free Garmin UPDATER
Do that here:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To download the latest unit software visit Garmin website: www.garmin.com/webupdater
After installing WebUpdater once from the Garmin website, perform all future software updates from your computer. Simply connect your compatible Garmin device to your computer, then run WebUpdater from your computer's "Start Menu" by selecting "Start", "Programs", "Garmin", and finally "WebUpdater"
Normal 0 false false false MicrosoftInternetExplorer4 REMEMBER: It takes hours to do a complete a map update.
Unless you bought the Lifetime maps you may have to pay for current maps.
Does this help? Let us know. Thanks.
Dec 26, 2008 | Garmin nuvi 260W GPS Receiver
Garmin nuvi 260
Re: Not sayinstreet names.
After you turn on your unit touch the wrench icon in the bottom right of the screen, this will take you to a menu which features "Settings" in the upper left of the screen. Touch "settings" and scroll down to "language" by using the up and down buttons in the lower right of the screen (down 1 should do it). Touch "Language" and in the voice category find and select "American English - Jill (TTS)". This is the voice that will give you Text To Speech (TTS) speaking the street names in English. If you prefer Spanish or French, find the appropriate catergories with "(TTS)" beside them - "Espanol Americas - Paulina (TTS)" and "Francais Canadien - Julie (TTS)" respectively. Any other selection will only give directional instructions such as "turn left in XXX".
After you have selected your voice press "OK" and back out to your main menu showing "Where to?" and View Map".
Now, when you navigate, you should hear an American female voice giving you directions by street name - assuming your volume is high enough to hear it.
RE: The computer icon displaying when you try to use your unit in the car with the 12 VDC cord.
You probably have a problem with the cord. The pin length in the USB style connector is critical and if it doesn't match up just right the GPS thinks it is hooked up to a computer. If you know someone who has a Garmin NUVI try using their cord and see if you have the same problem. Either way, call Garmin and see if they will send you a replacement cord or otherwise help fix the problem.
Jan 11, 2008 | Garmin nuvi 350 GPS Receiver
Garmin nuvi 260 Car GPS Receiver Logo
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
