Question about Panasonic TH-42PX500U 42 in. Plasma Television
Panasonic plasma only showing green colors after power failure? tried to fix color and tint but nothing happens?
SOURCE: bad color
This is not a solution, sorry but we are having a similar problem, in that one day all the color just went wonky - too contrasty and red. We sort of fixed it by radically changing the color settings, but can't figure out why it happened...?
Posted on Oct 05, 2007
  • 1894 Answers
SOURCE: Panasonic TH-42PD50Uscreen colors all appear pink and green
the colour sensor on the picture display may have lost functioning....as in case of plasma tv`s the they use transistors for colour ......so better call a technician from the related company and do a check up.....no other solutions i hope.....
Posted on Jan 02, 2008
SOURCE: Panasonic TH-50PX60U Plasma TV no red color
We had the same problem with a different model plasma tv. My wife tried unplugging the tv for a minute or two, but we still had the same problem. I unplugged the tv and left it unplugged for over 8 hours, then plugged it back in and the problem was fixed.
Posted on Oct 17, 2008
  • 362 Answers
SOURCE: I have a Panasonic 37
Hi dennisreno,
You should be able to set the tv back to factory default settings from the menu.
I will see if I can find the user manual and give exact directions.
Let me know if you find the reset.
Lone99star
Posted on Jan 29, 2009
SOURCE: Color has strong green tint - can't adjust with set-up program
One color plug in the back was unplugged - Since the TV had not moved we didn't think to look for that. The cable bundle must have been bumped causing the problem - I feel a bit silly that I hadn't looked for that. Thanks for your follow-up.
Posted on Jun 12, 2009
Panasonic plasma tv Th50px75u. remote will not change tint or color
The receiver circuitry in the tv for the remote's signals has the problem
Jul 23, 2015 | Panasonic Televison & Video
PANASONIC VIERA TH-42PZ82BA 42" PLASMA TELEVISION 1080P Full HD
Your TV is showing symptoms of power supply failure. It needs to be repaired or replaced. The remote has nothing to do with the power supply problem
Mar 21, 2013 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Panasonic TC-P42U1 plasma. Lost it's vivid colors basic color is black and white and green and blue if tint color tone etc. Is turned up. However a blue ray video plays with full color. Could it be a lose...
I have an old Toshiba TV and was going to replace it with a new plasma because it has suddenly (the week of July 19, 2010) lost color. It has only green and blue tint. Changing the "tint" on the menu didn't help. The color comes and goes relative to nothing that I can measure, such as how long it is turned on, etc. Reading other complaints from owners of Plasmas, I am thinking it is cable related. I have Charter Cable. Playing a DVD, I have to readjust the tint back to normal. Hope this info gives clues.
Jun 27, 2010 | Panasonic TC-P42U1 42 in. Plasma HDTV
The color on my monitor has a green tint
If your monitor has just started showing an off color tint, try checking the video cable connection on the back of the monitor and the at the video connection on the PC. Make sure the connection is solidly connected and not loose. Wiggle the connection as you watch the monitor to see if the color changes... if so the connection is loose. Try rebooting the computer into safe mode and see if the color issue still shows... if not then you may have a video card issue, overheating can be a culprit
Apr 12, 2010 | Acer 22" X223w LCD Monitor
Green tint in the color on my big screen tv
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 12, 2017 | Samsung Televison & Video
I can't seem to correct a tint problem. The tv turns on and the tint doesn't change. A friend says it could be a vidoe card?
Go to menue on controller, then Picture, then adjust Color and Tint to you taste. The color ajusts Blue and Green move left more blue move the slider right more green. The Tint controlls red. More red move right less left. Also chech Color temp setting.
Nov 08, 2009 | Akai PDP4225M 42 in. Plasma Television
Green tint
It sounds like the color wheel has gone bad and needs to be replaced. This is located behind the back panel... replacing a new colour wheel will solve ur problem
thank u
rate me
May 29, 2009 | Sanyo DP42746 42 in. Plasma Television
My Rear Projection HDTV is not showing blue, only green and red
it is possible that you need a new tube but you need to make sure first.
check the controls in the focus block and try to adjust it, you may be able to get a little more juice from the tube
Feb 02, 2009 | Panasonic TH-37PX60U 37 in. Plasma HDTV
I had the exact same problem. Thought it was the tv, but it was the cable between my cable box and the tv. Try unplugging the cords and plugging them back in, color was restored.
Oct 12, 2008 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Bad color
Aug 15, 2007 | Panasonic TH-42PX500U 42 in. Plasma...
Panasonic TH-42PX500U 42 in. Plasma Television Logo
163 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
