Question about Electrolux EOD5310 Electric Double Oven
EOD43102X main oven door not fully closing
We have an EOD43102X double oven which is perfect except for the fact that the main oven door doesn't fully close letting a lot of heat escape. I can't see any obvious way of remedying the problem which seems to be related to the hinges
3 Suggested Answers
SOURCE: Eog 6330 oven door does not fully close ie small
I have a problem with my Electrolux EOG 6330 Oven door not closing fully so letting valuable heat loss to occur. I notice on here it seems like a common problem. How do I get it to close shut properly?
Posted on Feb 20, 2011
  • 1314 Answers
SOURCE: Electrolux EOC6690X Pyrolytic Door won't close properly
if the door lock engagement rod is sticking out then with the door open hold the switch down with your finger then hit start then cancel lock rod should go back letting door close if engagement hook is not sticking out may have to replace switch some are bad about breaking but have been impooved
Posted on Dec 29, 2007
My JenAir oven door doesn't close fully
most likely you have bad door hinges if the door doesn't close correctly,i don't know if you know this but alot of parts are no loner available for this model,it must be old,the only thing you can get for the door is the hinges and that's it,you'll need the rest of the model number to get the right hinges you're missing the last two letters,you can go here put your model number in to look up parts.
https://www.searspartsdirect.com/model-number/JMW8527CAB/1266/0125300.html
go to door and look at part 16 the hinge,hope this helps you out,when you open the door,if it sags down lower to the ground the hinges are bad,when open it should be at a 90 degree angle
Feb 01, 2018 | Jenn-Air JMW8527C Electric Double Oven
I have a JT955 GE Profile 30"double oven...when the food is cooked, and I press "clear/Off", the oven won't shut off...continues to maintain temperature? Tonight, I had to shut it off,...
Your wall oven has two main components that control the oven. The main control computer and the user interface. Your problem is probably in the user interface, although it could be the main control or both. I have had some success cleaning the ribbon that connects the user interface to the control with a little rubbing alcohol. That only works some of the time though. Due to the fact that the oven works except for the cancel button I would lean towards replacing the user interface if cleaning the ribbon dose not work.
Aug 29, 2011 | GE Profile JK955SFSS Electric Double Oven
My KitchenAid Double Oven Model KEMC308SS0 has a door problem (I think). Both Doors swing down past the horizontal level. Doesnt look right and they both do not close all the way. Opened one iin the...
I have spent $$$ on new hinges for my KitchenAid double oven doors over the past few years, but they always fail after 6 months or so. Recently I decided on an elegantly simple solution. K&J Magnetics (kjmagnetics.com) carries a line of 1/8" thick, countersunk Neodymium magnets that are perfect. I purchased a pair of their # RE22CS-N magnets (3/4" dia X 1/8" thick), attached them to the upper corners of the door just outside the gasket area with some #8 flathead screws, and viola! They do a great job of closing the door while still allowing a proper gasket seal. Lighter or heavier doors might require a different magnet, but K&J offers types with varying pull-in forces, so you should find one to match.
Sign up for our Monthly Newsletter kjmagnetics.com
Magnetics Incredibly strong...
Dec 10, 2010 | KitchenAid Architect Series KEMC308KSS...
Door does not shut completely
OVEN DOOR HINGES WILL NEED REPLACEMENT IF YOU PUT ADDITIONAL WEIGHT ON THE DOOR THEY WILL SOFTEN THE SPRINGS AND THE DOOR WONT FULLY CLOSE.
May 29, 2010 | Electrolux 30" Built-In Double Electric...
One of the oven doors does not close tight so heat escapes. It is a Jenn Aire electric double wall oven model number JJW9627DDS.
Sounds like the oven door hinges have worn. If door is not obstructed in any way and will fully close when pushed but open about half a inch when released then it will be the hinges. Not sure of cost of spairs. I believe this to be a John Lewis Model. If it has a Enr no inside the door or inbetween the door hinges then I could give you price on spares
Nov 15, 2009 | Jenn-Air JJW8230D Electric Double Oven
Oven door does not close fully
You need to replace the oven door hinges.
Please rate my solutrion.
Thanks.
May 15, 2009 | Neff B1421 Electric Single Oven
Trying to remove front doors from Frigidaire Double oven.
Open the door fully and with a small screw driver, look closely at the hinge area on the oven cavity. There you will see a small lever that will rotate down and lock the door in place. Once in the locked position, begin closing door, you will feel the door 'catch' then lift the door off of the oven.
The door can now be disassembled and cleaned.
Jun 22, 2008 | Frigidaire Ovens
Oven door does'nt close fully
Heavy doors wear out the rollers on the hinge and the hinge itself. Need to replace them in a pair but the are expensive.
Apr 25, 2008 | Bosch HBL 5052 Electric Double Oven
My oven doors wont close all the way
When the door came open you may have bent the hinges. Open the door fully and it should stop at 90 degrees. If lower than that, then the hinges are bent and will need replaced. Also you may look at the install directions and see if your model shows removing the door. If it is removable for install, you can try removing and reinstalling the door. It is possible with removable doors for them to slide up during install and then they are out of alignment for closing. Hope this helps.
Jan 04, 2008 | GE Profile JTP56 Electric Double Oven
Electrolux EOD5310 Electric Double Oven Logo
178 people viewed this question
Top Electrolux Ovens Experts
Mack Baxter
John Tripp
John Tripp
Are you an Electrolux Oven Expert? Answer questions, earn points and help others
