Question about LG 42LC2D 42 in. LCD HDTV
Cannot turn TV On or Off with the remote. - LG 42LC2D 42 in. LCD HDTV
  • 10,594 Answers
Please confirm that your tv is LG 42LC20 lcd tv or it is some other model to diagnose its problem.
Question tiltle shows it is LG 42LC20 lcd tv.
Thanks.
Posted on Jul 14, 2010
  • LG Master
  • 6,993 Answers
if the TV does not turn on/off with the remote, does other functions on the remote works?
The problem is most likely from the remoter control. The remote control's power on/off button is defective. Replacing the remote will be the best option.
Also, before you get another remote, it would be better if you borrow a remote and test with TV to be more sure.
Take care.
Posted on Jul 15, 2010
  • donmetz Jul 15, 2010
    None of the other functions work. I have three remotes and none of the functions work with either one.
    Thanks for your help.
  • Walesarumi
    Walesarumi Jul 15, 2010
    if none of the functions work, then it means the fault is from the TV remote sensor/infrared. The sensor/infrared is defective and needs to be replaced for it to for the TV to be able to be controlled by remote again. This is why the remote control cannot communicate with the TV.
    To confirm this, test those remotes with another TV and you will see that the remote will function.
    Good luck.
Tip
DirecTV Remote Control Code Search Tosearch for a control code for your TV...
Tosearch for a control code for your TV using your DirecTV Remote Control, follow these steps:
  1. Turn on the TV.
  2. Slide the MODE switch to the TV position.
  3. Press and hold the MUTE and SELECT keys at the same time until the green light under the TV position flashes twice, then release both keys.
  4. Enter 9-9-1 followed by 1:
  5. Aim the remote at your TV and press the PWR key once.
  6. Point the remote at the TV or component and press
    CHAN ^. Repeatedly press CHAN ^ until the TV turns off.
  7. When the TV turns off, press and release the SELECT key.
You have programmed your DirecTV remote control for your LCD TV.
_________________________________________
DirecTV Remote Control Code List Download
DirecTV Remote Control Manual Download
DirecTV Remote Control Code Entry
on Jun 10, 2010 | Universal Remote Control DIRECTV Universal...
I have an RCA tv model # f27159wn, we had a universal remote to turn it on because the power button is missing. Our son lost the remote, when we found the remote it doesnt turn the tv on now. How do I...
RCA tv codes from the original RCA 3-in-1 universal remote.000,181,100,233,203,212,098,005,003 004,006.One of these codes program for the RCA universal remote will work.Sorry but to find the tv wright codes for the tv to work.The tv must be power on and working to find the tv wright codes to program in to turn the tv off to get the tv wright codes.Try website like Rmotes.com to buy the tv original remote,will not require tv on to used the tv original remote.
May 03, 2011 | RCA 4-in-1 Universal Remote Control
Remote not active with the tv
unessr
I have provided instructions on how you can program your remote to your TV. Without knowing the brand TV you have, I have provided a link with the codes you can try.
Program to TV:
  • Remotes: Basic (Television Only)
    1. Turn the Television On.
    2. Press and hold the TV Power button for three seconds until the LED flashes.
    3. Enter the three-digit code using the buttons on the number pad.
    4. Press OK. Note: The LED will flash three times.
    5. Test functionality with the TV.
    6. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
Power Scan:
  • Remote: Basic Remote (Television Only)
    3. Press and release the TV Power button.
    4. Press and release the Up or Down Arrow on the remote until the television turns off.
    5. After the television turns off, press and release the OK button.
    6. Test functionality with the TV.
    7. Return to Step 2 if the remote is not able to turn the TV On/Off, change the volume and mute the television.
The link for the remote codes are at the bottom of the page. Select your receiver type and then your TV brand to get the codes.
http://www.dishnetwork.com/SupportSection/remote-setup
I hope this helps.
Ray Calo
DISH Network
Apr 16, 2011 | DISH Network IR Remote Control
I need step by step instructions to program the codes into my One For All universal remote URC-4220 to my JVC tv.
The code for a JVC TV is 0053 (non-combination TV). To program the remote, turn on the tv manually. Then press the TV button once. Then press and hold Set until the LED blinks twice. Then release Set. Aim the remote at the TV and enter the four digit code. The LED should blink twice again. Press the power button on the remote. The TV should turn off. Turn it back on and check if the remote does the other functions that it should for the TV.
There is a manual code search option. Press TV once, then press and hold Set until the LED blinks twice. Release Set and enter 9 - 9 - 1 . Then aim the remote at the TV and alternate between pressing Power and TV. When the TV turns off, press Set to save the code. Turn the TV back on and check if the remote performs other functions. If not, repeat the above steps until another code turns off the TV.
The manuals for All-for-One Remotes are available here: http://www.oneforall.com/support/manual . Choose universal remote control in the top drop down and then the URC-4220 in the second.
Please note that universal remotes only have codes for devices released 6 months of more before the remote was programmed. If your TV is newer than your TV, then you may need a newer remote.
I hope this helps.
Feb 12, 2011 | One For All URC4220 Remote Control
Tv doesn't turn on with remote or the switch?
tv won't turn on manually nor with the remote
Jan 23, 2010 | LG Televison & Video
What is thecode for rca tv
Try this method as it is a bit easier than keying in different codes. One thing to consider is that not all TV's are compatible with the remote so if you have changed the TV out you may experience this issue. In order to program the remote to the TV turn the TV on and put the remote in SAT mode by pressing the SAT button in the upper left hand corner of the remote.Now press and hold the TV button Next to the SAT button until all buttons light up across the top of the remote and release. Now press the small red TV button and release. This should result in the top clear TV being lit constantly. Now press the arrow up key slowly until the TV turns off. Once it does press the arrow down key once and then the arrow up key. The TV should turn on. Now press the pound symbol at the botttom right of the remote. The TV button on the top should flash three times. Now you can use the remote to control the TV. If you are unable to get the TV to turn off then the TV is not compatible with the remote. Thanks for using Fix Ya.
Mar 15, 2009 | DISH Network IR Remote Control
The volume control won't work on my sky remote
for a toshiba tv,
press tv
press and hold select and red until the led blinks twice
type in 0 1 5 6
press the power button on the remote
If the tv turns off press select and hey presto you're done, if the tv doesn't turn off, press tv then press the power button and keep doing this until the tv turns off. When the tv turns off press select.
Nov 17, 2008 | Universal Remote Control Remote Control
Remote Control
From GUEST: I found this solution in the manual and will perform this task again to see if I can get the tv will be re-recognized again. Give this a try, too.
Remote will not turn on or shut off the TV.
• You must program the converter box remote in order to control your TV power button.
• To program the remote control:
    1. Determine if the TV is a model that can be controlled by the remote control. See "Controllable TV brands" on page 17 in the manual.
    2. Turn on the TV.
    3. While you press and hold TV POWER on the remote control, press CH ^ or CH v one or more times until the TV turns off. Each time you press one of these buttons, the remote control sends a manufacturer code (between 1 and 45) to the TV.
Sep 01, 2008 | Insignia Digital-to-Analog Converter for...
LG 42LC2D 42 in. LCD HDTV Logo
Computer Repairing
Computer Repairing
