Question about Mitsubishi WS-55413 55" Rear Projection HDTV-Ready Television
Picture color is starting to go- what is this going to cost to fix and is it worth it?Can we do it ourselves? Where would we get the parts?
  • Mitsubishi Master
  • 8,457 Answers
The tv have problems mis alignment any colors R,G,B the tv have a problems known as a convergence problems,it dead.The tv convergence board the 2 STK covergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost $300-350 for parts and labors.
Posted on Jul 14, 2010
Do u fix tv
We don't repair them ourselves, but some of our requesters do repair their own. Truthfully, with the price of flat screen TVs in the $250-$350 range these days for sizes up to 40" or better, and with newer sets doing more, having better picture and sound, using less energy than their earlier counterparts, and with service labor costs so high, repairs of older TVs isn't cost effective unless you can repair it yourself with used or discount parts. And that is assuming you guess the right part the first time. Many do not and wind up spending more to repair their older set than it was worth.
Oct 23, 2015 | Televison & Video
I have a 42" Samsung HD Plasma 1080. Started going
Sounds like it may need to be serviced due to component failure which unchecked will get worse, it may be also worth try to reset it back to factory settings in its setup menu this should clear any software issues it may have, but I think its more possible a faulty part or parts which comes down to cost and is it worth it sadly?
Hope this helps.........
Aug 28, 2017 | Samsung PS42B450 42 in. HDTV-Ready Plasma...
Rolling horizontal (colored) lines instead of picture; audio OK
This problems it pretty easy to fix.Just require take the tv apart.Resolders all the holes in the video board that connected to a long CRT tube neck.Should cost $50 -$75 more than that u are being cheated.
Dec 04, 2009 | Philips Magnavox 20MT4405 20" TV
Sharp SF 2114 H-4 Error: Fusing Unit Not Heating
Replace fuser lamp and check the condition of thermistor and rectify.
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
22 year old 20" Mitsubishi TV
i think its time to get new one ,for 22 years it has served its useful life now its in the end life when it will start giving problem even if you fix this one another one may likely come up at times this is usually the case as most of the parts are worn out after many years of service even humans so i think your best bet should getting new one .
hope this helps
Sep 09, 2008 | Televison & Video
Hitachi projection 53" screen color off
Since this is a CRT based projection set, there is no "lamp" involved. Does the picture look like 3-D? If so, the problem is likely to be a convergence problem. There should be 1 or 2 convergence ICs marked STK392-110 inside attached to a heatsink. If you can solder, try resoldering the pins on those ICs. If that fails to resolve the problem, replace them.
Keep us posted.
Dan
Jul 14, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Toshiba theaterview lines don't line up
Convergence IC blown stk392-???
Dec 03, 2007 | Televison & Video
Picture Problem
Hello, I had a problem with mine. The colors separated a little, the picture got small and was worse on bright scenes. Got it fixed, the tech replaced an IC and I kept the part number.... Part# 483520988561. I don't know if the same IC controls the part of the picture that you have a problem with or not. I am happy that I got mine fixed, it was worth it. The tech knew the IC I needed from the description of the problem on the phone.
May 12, 2007 | Philips Magnavox 9P6034C 60" Rear...
Loss of colour
With the set being 12 years old, I'm sure the picture tube is near the end of its useful life. You probably have a defective semiconductor, either an IC or transistor that has gone up giving you no color, but with the green picture, it is not likely worth repair.
Jan 02, 2007 | Toshiba 36AF61 36" TV
Constant changes in picture colors.
It is a 20" TV set and will most likly, im afraid to tell you, cost more to fix then it is worth. The problem is a bad Picture tube, an intermittant CRT socket or the video jungle IC is intermittant. If you want to invest in an estimate, check out first if it will go towards the repair, as then maybe you can get it fixed at a good price, as long as the picture tube is not the problem Good Luck
Oct 07, 2006 | Toshiba 20AF46 20" TV
Mitsubishi WS-55413 55" Rear Projection HDTV-Ready Television Logo
77 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
