Question about Black & Decker String Trimmer Cordless 12" 18V
Rewinding spoolof my Black & Decker NST2036 trimmer
I recently received my trimmer & upon opening the box the spool came tumbling out with coiled wire everywhere. I have read the vague instructions that came with it & I can't seem to get it to automatically feed new wire. When the wire breaks off & I "bump" it nothing happens & the coil of wire inside the hub is loose & I need to rewind it again. After I rewind the wire what exactly do I do with the end of the wire? Does it go thru the little hole before I "park" the wire? I am a female & first time owner of a lawn & weeds, help.
Jean
  • 3 Answers
SOURCE: changing spool on weed trimmer
unscrew the knob on the bottom(turn cc wise) pull bobbin straight out . To restring pull start rope gently to see what direction it turns and wrap string in the opposite direction. Re insert the string into the corresponding hole(s) and screw up knob by hand until tight.
Posted on Nov 19, 2007
useless
Posted on May 10, 2008
  • 3 Answers
SOURCE: Black & Decker Grass Hog Electric Trimmer
How do you replace the white lever, and how do you know if it is broken?
Posted on Jul 14, 2008
  • 9 Answers
SOURCE: how do u rewind a
if it is going back onside or unwinding it proble is in upsidedown or wond backwords
Posted on Jul 30, 2008
pumpkinman
  • 1165 Answers
SOURCE: How do i replace a rewind spring in a stihl fs 45 weed eater
you have to kake sure u wind it the rite way there should be tension on the spring when it is wound and if let go should return if it does that u have it rite...the little plastic peice must be connected to the hooh on the spring
Posted on Jul 25, 2009
How to replace the string in grasshog xp electric trimmer
Ran into the same problem recently and discovered that one solution was to use a standard adjustable wrench and grasp the center, leveraging off the spool cover. If you look closely at the spool it is tapered so the very top of the hole in it is actually slightly smaller that the spool cover point it slides over letting it seal pretty tight over time.
May 21, 2013 | Black & Decker Black and Decker & Grass...
How do i rewind the spool on a Black & Decker 14" dual-string trimmer/edger. the manual isn't exactly clear
When you pull off the spool it will have arrows embedded,
on the spool to show you which direction to wind it.
good luck!
Jul 17, 2011 | Electrical Supplies
I have a black & decker gt701 strimmer. i recently replaced the line on the spool but now it wont feed, ??
Remove cup from bottom of unit by depressing 2 detent tabs and pulling away from unit.
Replace empty spool with new full one or wind on aftermarket string. Wind in direction of
arrow on spool. Make sure spool is seated on rachet firmly.
Apr 16, 2010 | Black & Decker Garden
Line will not advance line is not crossed in spool
Rewind the line and make sure you wind in the direction of the arrow on the spool. Not an unusual situation.
Mar 31, 2010 | Black & Decker Grasshog 12 Inch 18 Volt...
Describe your Black & Decker
You can order these thru black and decker at blackand decker.com
Sep 12, 2009 | Black & Decker 14" Grass Hog Xp...
B & D trimmer feeding too much line
Do you remember putting the spring back in when you filled it with new line. You mite check to see that it is in there.
Good luck
Aug 07, 2009 | Black & Decker 14" Grass Hog Xp...
I can't find the spool cover for the trimmer ST
Serious question??
Spools on almost all of the recently made trimmers do not have a separate cover. They're attached by pushing down and twisting them clock-wise. When you hear them snap into place, let up and its on. To take one off its just the opposite...push down it down and twist them counter-clockwise.
Hope this helps.
Jun 17, 2009 | Black & Decker Garden
Auto feed spool doesn't work
You may need to purchase a new spool housing, which may not be too hard to do, if you have one of the name brand trimmers. This replaces the whole mechanism that holds the line, the retaining ring, etc.
Sep 21, 2008 | Black & Decker Black and Decker & Grass...
Black & Decker String Trimmer Cordless 12" 18V Logo
182 people viewed this question
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
