Question about Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k
We are experiencing an air leak from the oil cap, how do we resolve this issue. We are unable to get air pressure.
  • 4 Answers
The oil cap is a breather for the crankcase. It will blow air. It should have an "o" ring on the oil plug, but it may have rotted off. You can get a new one at Lowe's in the plumbing department.
Another thought: Check the head gasket. Mine just did the same thing. Mine was blown between the two chambers on top. It's very thin right there. I went to the auto parts store and bought some gasket and made my own for about $6. It's up a working great...finally. BTW the gasket kit is on back order right now at Sear's parts website. It appears we aren't the only ones with the problem!
Posted on Jul 19, 2010
Oil leaking
OIL pressure sender left front of engine on pass side (faceing pass side) left lower section of engine is where pressure switch is. could be other things. possible oil cap was left off. please keep oil checked until your problem is resolved.
Dec 12, 2012 | 1996 Buick Century
Where is oil pressure switch on 1995 oil pressure switch
For oil pump,oil pump pressure,oil warning light,oil low,oil ewplacing and other car engine oil problems,the help links are provided below.Click the link to go through the procedure :-----Oil light came on and the car died?http://schematicsdiagram.blogspot.in/2012/03/oil-light-came-on-and-car-died.html--------How to replace Oil filler cap or breather cap?http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-oil-filler-cap-or.html---------Oil pouring out from left front of engine?http://schematicsdiagram.blogspot.com/2012/01/oil-pouring-out-from-left-front-of.html------Common Causes of Car Oil Leaks?http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html--------Troubleshoot Car Oil leak?http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html--------Oil change details?http://repairhelpcenter.blogspot.com/2012/01/toyota-highlander-sport-oil-change.html---------Low oil pressure light?
http://howtobyme.blogspot.com/2011/11/low-oil-pressure-light-on-dodge-magnum.html
leaking oil from oil pan?
http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html ----------
Car Turns OFF due to low oil pressure warning light?
http://schematicsdiagram.blogspot.com/2011/12/car-turns-off-due-to-low-oil-pressure.html
leaking oil from timing cover?
http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
For more oil and oil pump details check out the direct links below: ---
How to Replace Oil Pan on car?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-oil-pan-on-audi-a4-and.html
How to Replace an Oil Pan Gasket?
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pan-gasket.html
HOW TO REPLACE AN OIL PUMP
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pump.html
HOW TO CHANGE ENGINE OIL AND FILTER
http://schematicsdiagram.blogspot.com/2011/07/how-to-change-engine-oil-and-filter.html
HOW TO REPLACE AN OIL PRESSURE SWITCH (SENSOR)
http://schematicsdiagram.blogspot.com/2011/07/how-to-replace-oil-pressure-switch.html
How to Check Differential Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
HOW TO PERFORM A BASIC ENGINE TUNE UP-OIL CHANGE
http://schematicsdiagram.blogspot.com/2011/08/how-to-perform-basic-engine-tune-up-oil.html
Oil pan Gasket on car?
http://howtobyme.blogspot.com/2011/11/oil-pan-gasket-on-1998-toyota-tercel.html
Oil pressure for car?
http://schematicsdiagram.blogspot.com/2011/12/oil-pressure-for-2001-gmc-jimmy-v6.html
How to replace Oil Pan on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pan-on-2008-honda.html
How to replace Oil Pressure Sensor on car?
http://schematicsdiagram.blogspot.com/2011/12/how-to-replace-oil-pressure-sensor-on.html
How to replace Oil Pump on car?
http://howtobyme.blogspot.com/2011/12/how-to-replace-oil-pump-on-2008-honda.html
Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Oil light blinks on dashboard?
http://schematicsdiagram.blogspot.com/2011/12/oil-light-blinks-on-dashboard.html
Oil pressure issues on car?
http://repairhelpcenter.blogspot.com/2012/01/oil-pressure-issuers-on-toyota-tundra.html
Oil leaks from air filter on ford?
http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
Wire running from oil pan to alternator?
http://technoanswers.blogspot.in/2012/02/wire-running-from-oil-pan-to-alternator.html
Why car leaks oil from oil filter?
http://schematicsdiagram.blogspot.in/2012/02/toyota-camry-leaks-oil-from-oil-filter.html
Why engine is consuming lots of oil?
http://schematicsdiagram.blogspot.in/2012/02/2008-scion-xb-24l-engine-is-consuming.html
Maint REQD message on car dash?
http://schematicsdiagram.blogspot.in/2012/02/maint-reqd-message-on-2008-lexus-rx350.html
Remove Sump oil pan?
http://repairhelpcenter.blogspot.in/2012/03/remove-volkswagen-sump-oil-pan.html
Sump not coming OFF?
http://repairhelpcenter.blogspot.in/2012/03/sump-not-coming-off.html
How to remove the sump on car?http://repairhelpcenter.blogspot.in/2012/03/how-to-remove-sump-on-vw-beetle.html----------Car oil sump removal diagram?
http://repairhelpcenter.blogspot.in/2012/03/volkswagen-beetle-oil-sump-removal.html
This will help.
Thanks.
Feb 26, 2012 | 1995 Isuzu Rodeo
1999 Bravada. Oil pressure is too high. Pressure is ruining filter at front of engine
Car oil leak?
This will help.
Thanks.
Feb 17, 2012 | 1999 Oldsmobile Bravada
Oil filler cap left off after oil change, 2010 Subaru Outback. Oil level is fine. Could this have caused any engine problems?
Car oil leak?
This will help.
Thanks.
Feb 14, 2012 | 2010 Subaru Outback 2.5i
Oil pressure light comes on at idle
Car oil leak?
This will help.
Thanks.
Feb 05, 2012 | 1997 Porsche Boxster
1995 dodge dakota truck has no oil pressure
Car oil leak?
This will help.
Thanks.
Feb 04, 2012 | 1995 Dodge Dakota
Timing chain broke and bent valves in my 202 pontiac grand am, all has been replaced and now cylinder #3 has no compression
Put #3 cylinder in firing position then put air pressure in that cylinder and remove the oil cap. If air comes out throttle body the intake valve is leaking. If air comes out the tail pipe the exhaust valve is leaking. If air comes out where the oil cap came off the piston is leaking.
Jul 28, 2011 | Pontiac Grand Am Cars & Trucks
Power steering leaks from the cap
could be overfull
remove excess to the full mark on the dipstick
could be a problem power steering pump bypassing excessive oil back to the reservoir under pressure and heating and expanding the oil
take it to an accredited power steering service center and have a pressure test done on the pump
the humming noise indicates a valve problem leaking under pressure
Apr 19, 2017 | 2005 Chevrolet Impala
How do you turn of the oil light in your infinity
The engine oil 'warnig' light being ON indicates that you have a BAD problem with your engine oil system: this indicates that your engine is not being lubricated properly (due to low pressure) and you should get it checked immediately!
Oil warning light ON can be caused by:
- Low Engine Oil level
- Blocked oil filter
- Leaking oil filter
- Leaking oil seals
- Faulty oil pressure sensor (pretty rare) or loose sensor connector
- Also heck the obvious like loose Oil Filler cap and dip stick seal.
Hope it heps and do not drive your car without resolving this issue first as you could easily blow the engine!
Dec 25, 2009 | 2004 Infiniti FX45
Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
267 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
