Question about RCA D61W20 61" Rear Projection Television
MY RCA D61W20 shut off and would not let me turn it back on for about 10 minutes. When it came on I could hear the sound and after about 10 seconds the screen come on in blue colors and streaks after about 10 more seconds the picture came up but it was a blue colored picture then it blinked a few times and went back off.
  • 2 more comments
  • martysguns Jul 15, 2010
    more info.
  • martysguns Jul 16, 2010
    Thanks for all the help.
    where would you recomend for parts?
    Attention eagle338
    On the crt boards I talked to you about at tv repair world.
  • 4,889 Answers
The problem is related to the CRT boards or the CRT itself. More often than not an oscilloscope is required to trouble shoot this problem. Hence this cannot be fixed by the end user. You can use our repair directory to find a tech in your area to help you fix this.
http://www.fixya.com/repair
Posted on Jul 14, 2010
  • 10 more comments
  • eagle338
    eagle338 Jul 15, 2010
    You could have merely requested what you wanted to know and I would have been happy to help. But now I have changed my mind. You don't deserve it.
  • eagle338
    Sorry I could not see your last post. Can you please post it again?
    once it comes on it blinks 2 times before shuting off.
    Is there an easy and cheap fix for this?
  • eagle338
    This is not an expensive fix at all. The CRT board costs about 25$ if used and slightly more if new. You can get the tube off ebay or something for as low as 100$.
    What all do I need to get? Can I put them in?
  • eagle338
    eagle338 Jul 16, 2010
    The first objective would be to determine whether both boards(red and green) are faulty. More often than not this will need an oscilloscope. Replacement is also pretty risky if you do not have prior experience in handling HV electronics. The CRT acts like giant capacitor and holds about 20000volts for several days after its turned off and unplugged. The risk of injury is too great and not recommended if you are not sure of what you are doing. As my guru at the institute used to say "Your life and limb is worth much more than this!
    I have a cousin that works for xerox as a repairman I could get him to put them in. I found them at tv repair world for $35 each I will just get both most likely both need changed.
  • eagle338
    Thats a pretty good deal! Go ahead and give it a shot.
  • eagle338
    You are welcome! Thanks for using Fixya!
  • eagle338
    Partstore.com or any of its affiliates(such as sears parts) should be good place to start. Even encompass parts and ebay would be good places to look for the part but you are gonna need the part number for that.
  • eagle338
    Oh yeah! Forgot about that. Sorry I have never tried buying parts from there before
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please post a comment with the no# of blinks it shows so that I can provide you assistance regarding your RCA projection TV.
Thanks
Rylee
Posted on Jul 15, 2010
    Once it comes on it blinks 2 times before shuting off.
Set is 7 years old - it turns off intermintently
Ours used to do that - and then we moved it to another state with us. Since the move it doesn't shut itself off anymore. I suspect that the problem was dirt and dust inside which got knocked loose in the move and the shutdown was due to thermal limits being exceeded. You may want to try vacuuming or blowing out the dust inside if you feel comfortable opening up the unit.
Feb 15, 2010 | RCA D52W135D 52 in. TV/DVD Combo
TV does not turn on model RCA D61W20B
first check all fuses they are small, square ,RED and can be confused with the square small caps. the sizzling is prob. the flyback transformer (what the h.v. wires from each tube plugs into) if you are only getting green then tv shuts down or is dead now. i would replace any bad fuses and replace the flyback transformer. also make sure you do a very good visual inspection of all the boards.
Jun 21, 2009 | RCA D61W20 61" Rear Projection Television
Rca d61w20 wont come on
CK capacitors on Deflection Board cp150 2200uf 16v if puffed up on top it is bad so replace cp114 and cp120 / 220uf 325v.
Feb 10, 2009 | RCA D61W20 61" Rear Projection Television
RCA will not turn on
replace the flyback. you can get a replacement at the following link with free tech support to expain step by step how to replace it. you need flyback 259296 Heres the link.
http://servicemanuals.vstore.ca/
Aug 11, 2008 | RCA D61W20 61" Rear Projection Television
D61W20 RCA, Red Screen and then shuts down
sounds like the Red CRT (tube) has shorted. You can test by removing the RED crt circuit from the end of the RED tube and making sure it isnt touching anything try powering up the set. If it comes on and doesnt shut down the red tube is the problem and will need to be replaced . expensive part to replace the Red XRT will be over 300 and at least 2-3 hundred to have it installed unless you know someone who can replace it for you.
Apr 06, 2008 | RCA D61W20 61" Rear Projection Television
Rca 61 inch projection tv model D61W20
Steve,
I have the exact same problem with my tv. same model. If you happen to find a solution, could you please forward it to me. I will be very appreciative. email me at jjkjjk13@hotmail.com . I'll do the same for you if I find a solution.
Jan 20, 2008 | RCA D61W20 61" Rear Projection Television
RCA D61W20 61" Rear Projection Television Logo
63 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
