Hi Expert.. I have just inserted a new motherboard and as soon sas i put the power cable in the computer is fully running and i am not able to shutdown from the power button would it have something to do with the order of the front panel pin and which order should they be in?thank you angie
  • 4,737 Answers
If there's not problem with the Power Switch, then you must re-check the Front Panel connection. By the way, did you power it on using the power switch or was it switched on itself?
Well, this isn't a big issue, but you need to reconnect all the connectors, please refer to your motherboard manual (I can't give you better instructions on how to do it since you didn't mention the motherboard name and type) For your reference, you can take a look here; Hi Expert.. I have just inserted a new motherboard - 147079a.jpg
Let me assume, your motherboard is Atx (since almost all motherboards do) The Power switch connector should be connected to "Pwr" and "Gnd" and Reset switch connector on the Opposite side as "ground" and "Reset". If this is similar with your motherboard's front panel connector, then you are lucky..:-).
Ok.. try this and let me know if the problem persists.
Good luck.
Thanks for using FixYa.
Posted on Jul 14, 2010
  • 11,800 Answers
Most likely you have connected the speaker to the power button pins. Remove all the cables coming from the front panel and try again. If it happens again then remove the board from the case and try again If it happens even now then there's a fault in it, return it.
If the removal of the wires has fixed that then all you have to do is to plug them correctly - look at the board the connectors are color coded and their function is printed beside them.
Hard drive not recognized
If You are only one HDD connect then you make primary HDD jumper slot sat. And right direction data cable sat. And connect motherboard port proper.
Open Bios and check it HDD driver detect or not. If detect ok if problem then change data cable and power cable. Some diagnosis your problem solved.
Thanks..
Feb 17, 2014 | Intel Hp Proliant Se1101 Server 2x...
I HV PURCHASED P5BV-E/SAS EARLIER BUT TODAY I SWITCH ON THE SERVER BUT THEIR IS NO DISPLAY
Hello you can download the manual here:
http://support.asus.com/download.aspx?SLanguage=en&p=5&s=13&m=P5BV-E%2fSAS&os=23&hashedid=zuljCoD6sSH3WpYx
By selecting your windows system.
Open the manual folder and click on global for download.
You need adobe reader to read the content.
This is usually a hardware problem, Video card, power supply, memory sticks or mother
board. To nail down the problem, try the following workarrounds:
1. Does this computer work well before? If yes, what new hardware did you install recently? Remove it and try.
2. Insert one ram module, and turn on the
computer, if the computer POSTs or you hear beeps, try to add one memory
stick each time until you add all your memory sticks.
3. Clear your CMOS by removing the battery or short the jumper.
4.
Swap your hardware from the motherboard, for example, reseating your ram sticks, move video card from PCI slot 1 to PCI slot 2, etc.
5. Reseat your processor, check the CPU for damage.
6. Verify that you have all the power connectors connected properly.
7. Make sure the power supply is working, even test it on another pc.
Remember
to restart your computer after you try any of the above steps. If all
the above does not work, it is very possible that your motherboard is
bad.
Here is a fault finder guide:
http://www.tomshardware.co.uk/forum/261145-13-perform-steps-posting-boot-video-problems
Post back what is going on.
Good luck
Jan 08, 2013 | Asus P5BV-E SAS LGA775 Xeon FSB1333MHz...
My brother disassembled his Gateway w323 Ui1 laptop to put in more RAM and a dvd burner, but afterwards the laptop would not power on. When the power cord is plugged into it the light for the power supply...
Yes--take it apart again and check all the connections. As a general rule, if it worked and you "fixed it" and now it doesn't work, then you need to find out what you forgot to do when you put it back together.
Aug 02, 2010 | Computers & Internet
Just brought new memory for my acer aspire sa90 desktop,now my computer doesn't seem to turn on
i assume computer was starting correctly before? this is older computer and it is using sdram memory, locket on them sometime do not clip in correctly.
1. switch off computer
2. remove power cord
3. remove side wall
4. remove sdram
5. check sdram orientation and type, if they correctly align with registering notches
6. release lockets to max, (outward from slot)
7. re-insert correctly oriented sdram till lockets close into sdram stick (you may give them bit "help" to close in position)
8. re-connect power
9. start computer
if copmuter start normally, that meant tha tyou fixed the problem, if not, switch computer off and remove power cable, check motherboard power cable insertion, and repower again.
if computer start, lose cable was the problem.
if computer still do not start, remove new memory and re-nstall old one, if computer start, new memory will be a culprit.
if computer no fan "jig" and no light blink, remove all power supply cables from motherboard and connect in it's place new power supply, to exclude power supply problem.
if computer start with new power supply, old power supply will be the problem,
if computer do not start, and no joy with checking, but fan is running, including on the processor, this will indicate either, motherboard or processor died... if that is the case further testing will be required to determine which is exact cause. as in home situation there are usually no motherboard testing equipment, you need to go to more difficult path of changing the processor, checking video and haveing second computer on which you can test all of that...
replacement board for that processor on ebay cost from about $0.99 plus postage. if you need any further advice, please re-post adn if i am on line today, i will provide you with further procedure how to test your video, motherboard and processor.
if you find my advice useful, please do not hesitate to leave your comment and vote 4 for me, thanx!
Aug 01, 2010 | Acer Computers & Internet
Computer powers on and runs but it will not post hhd in BIOS. any help?
Shut down you're system. Open you're case and double check the power cable and data cable from hdd to motherboard. (Disconnect both cables and re-connect both). Make sure the cables are fully inserted. Power up the system and enter the bios. The hdd drive should be listed. If not replace the data cable with a new one and check the bios again.
If you have two hdd, ATA IDE drives connected, make sure that each hdd is jumpered correctly. One set to Master with a slave.
The second drive should be jumpered as a slave.
If you're running 1 hdd make sure the hdd is jumper as a Master without a slave. There is a sticker on the hdd to help you set the jumper correctly.
If the bios still does not see you're hdd than either the hdd is bad or the motherboard controller is bad.
To check if the hdd is faulty, check the sticker on the drive. Find the manufacture's name and model. Google the manufacture's name. Every manufacture provides free software that will test and repair the drive by allowing you to create either a bootable floppy disk or bootable CD disk that runs in a DOS like window. Example: For a Seagate drive you would download SeaTools for DOS. Instructions are listed on the site; http://www.seagate.com/www/en-us/support/downloads/seatools
Seagate also supports Maxtor drives using the same software.
Cheers'
Mike
Apr 08, 2010 | HP (D7580-60003) Motherboard
I recently bought a new hard drive to update the "tired out" model in my gateway model gt5674. i was told that i needed a SAS compatable motherboard to get this new hard drive installed. is there any...
Take the disk-drive back to the computer-store,
along with your computer, and exchange the new disk-drive for one that is compatible with your computer. Within 15 seconds of viewing the "inside" of your Gateway, they should be able to identify the correct model of disk-drive that will be compatible with your current motherboard.
Or, the more-expensive option: buy a PCI add-in card to add a 'SAS-compatible' interface (although I've never heard of such an interface!!!!) to your computer.
Jan 15, 2010 | Office Equipment & Supplies
System won't turn on but when i pushg down on one side of the power suply connectore the fan starts running but computer stioll won't turn on it used to boot up then opne day stopped
It sounds like you have a faulty connector - I would return the item under warranty. Otherwise, if it is out of warranty, you will have to source a new motherboard.
Nov 23, 2009 | ASUS COMPUTER INTL P5SD2-VM MBD MATX LGA...
Laptop won't staart up.
Yes, it should run off AC power even if the battery is removed. Sounds like either the motherboard or your AC adaptor might be failing. I would start by trying the AC adaptor with another dell to verify it it's not dead.
Good luck,
Raf
Nov 09, 2009 | Dell Inspiron 5160 Notebook
Cant boot my system
Check all your power cable if they are losened and the memory if is fully inserted
Aug 04, 2009 | ASUS P4SDX Motherboard
132 people viewed this question
k24674
jasbo
jasbo
