Question about Panasonic KX-T7431 Corded Phone
Panasonic line 3 not ringing - Panasonic KX-T7431 Corded Phone
    President:
  • 2,047 Answers
Try to check the phone line in..if calls come on it and it does not ring out then check the ringer settings for that particular port of the phone.
Hope this is helpful?
Posted on Jul 14, 2010
2 LINES PICK UP ON PANASONIC KX-TG4500
Sounds like you have the cords into the back of the phone mixed up. If you have a cord with 1 and 2 plugged into 1/2, great. But then if you have another jack also with 1 and 2, but plug it into 3/4, now you answer line 3 on second phone and line 1 lights up on first phone. Or line rings line 1 here and line 3 over ther. Gotta keep that straight and the jacks have to have identical lines.
Apr 17, 2014 | Panasonic KX-TG4500 Phone
My panasonic home phone only rings once, it used to ring normally and would also say what number is calling. please help.
We recommend you unplug the Panasonic base unit and make a test call from another number. If the line disconnects after 1 ring then you have either a telephone line problem or another device connected to the telephone line is the problem.
Mar 03, 2014 | Panasonic (KX-TG1032S) Phone
How do i set ring on Flexible Buttons.....
Perhaps you are trying to set up speed dialing.
Right?
Jul 22, 2013 | Panasonic KX-DT343 White 24 Button 3-Line...
How can i pick up the call from my office phone when reception phone rings
Hello,Looks like you'll need to re-program your PBX unit. I would suggest looking up: 1.5.3.3 Outside (CO) Line Access 2.2.4 Operator/Manager Featuresin the Programming manual found here:
http://www.tongxun.com.cn/data/download/Feature_Guide.pdf
Hope this helps
Nov 27, 2012 | Panasonic KX-T7730 Corded Phone
How to switch on the ringer in Panasonic KX-T7730 ?
I have a 3 position switch on the left side of the phone. Since I doubt that's what you're really asking, the ring from outside lines is controlled by system programming. Consult the manual for your Panasonic system. In a TA series, it's program 408-409 for Day and Night ringing.
Carl
Jun 26, 2011 | Panasonic KX-T7730 Corded Phone
Wont display caller id
A Panasonic phone needs 3 things to display CID, CID service, programming, and a ringing phone.
When you are on an outside line, does the CID display? If it does, then you just need to program the phone to ring. If it doesn't, start looking for hardware and programming. The card required ends in 93.
Carl
Dec 19, 2010 | Panasonic KXDT346 Phone
I have two lines on my Panasonic KX-T7731 I would like the second line to be a completely different ring than the first line
Not possible. A Panasonic Analog PITS phone has only one ring sound and all CO rings match.
The TD series and 74xx phones were the first phones to have 8 ring tones. The TDA series has 30 different tones. Prices are fairly competitive for upgrading.
Dec 14, 2010 | Panasonic KX-T7731 Corded Phone
My panasonic phones do not ring when an incoming call is coming in. There is a dialling tone on all 3 handsets and they all appear to be working ok
Ringer turned on? quite common and I'm a phone repair man. Does the calling party hear multiple rings? If it rings only once and goes to silence on the calling party end, there is a high resistance short on the line and it must be repaired.
Oct 19, 2010 | Panasonic (KX-TG1032S) Phone
Two phonelines no longer accessible. Using Panasonic KX-T7730 with a Panasonic KX-TES824 system. Lines were working fine and have now disappeared. They don't ring in and I can't ring out on them. ...
This is most likely a service provider issue. If these are analog lines, take a regular phone, not a Panasonic system phone, and plug it into wherever the CO1 CO2 CO3 lines go into the cabinet. If they work there, you have a system fault (not likely). If they don't you have a line problem.
Make sure that you plug the phone into the lines coming in, not into the cabinet :-)
Carl
Oct 09, 2009 | Panasonic KX-T7730 Corded Phone
Panasonic Kx-T123230 extension to ring
hope this help...
with a handset on hook...press PROGRAM and press 3 (number 3 button) this should give you a choice of which extention you want the phone to ring.. ie 1or 2 or three... Then finally press STORE
Feb 06, 2008 | Panasonic KX-T7730 Corded Phone
Panasonic KX-T7431 Corded Phone Logo
102 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
