Question about Baby Gear
Changing pushchair wheels - special tool needed ?
I want to replace the wheels on a basic pushchair. What tool do I need to remove the wheels - is it something special (if so, where can I get one) ?
  • 22,326 Answers
Last one i done was like a star shaped washer thing that clipped onto the end of the axle and two screwdrivers soon prised it back ,changed the plastic wheel and then just pushed the clip back over the axle and tapped it on a little more so that the ring part went back into the groove on the axle
Posted on Jul 16, 2010
WHAT IF ANY SPECIAL TOOLS ARE NEEDED TO REPLACE A REAR WHEEL BEARING ?
No.
The most you'll need is a big hammer or a air hammer to loosen the bearing from the spindle but just like changing a front bearing
Jul 14, 2014 | 2006 Chevrolet Impala
Still unsolved no tool i have can touch it,does it stay by friction?
If you are talking about removing the steering wheel, you need a special puller after you remove the nut on the shaft.
Jul 06, 2012 | 1983 Buick Century
Do i need any special tools to remove and replace the rear wheel bearings on a 1991 ae95r corolla? or can i manage with a pretty basic tool set? cheers.
the rear wheel bearings have to be pressed together, you have to remove the hole hub assembly and then have some one press the hub apart and back together, so what i am saying is that you can remove the hub assembly with just some basic hand tools but unless you have a press you can not replace the bearing.
Feb 04, 2011 | Toyota Corolla Cars & Trucks
How to replace rear wheel bearing on 1994 bmw 325i
3-Series (Except M3, M Roadster, M Coupe, 318ti & Z3)
1. Raise and support vehicle. Remove wheel(s).
2. Remove axle shaft. See appropriate AXLE SHAFTS article.
3. Remove brake disc. See BRAKE DISC .
4. Screw special tool (33 2 116) onto drive flange with wheel studs. Drive out drive flange with special tool (33 4 201/202/203). See Fig. 33.
5. If necessary, pull off bearing inner race using special tool (00 7 500) and a thrust piece. See Fig. 34.
6. It may be necessary to remove inner wheel bearing race with the following procedure:
  • Detach wheel bearing inner race with special tool (33 4 400) through groove in bearing inner race.
  • According to outside diameter of bearing inner race, use special tool 33 4 401 with: 33 4 405 for dia. 45-51 mm, 33 4 406 for dia. 50-55 mm and 33 4 407 for dia. 55-61 mm in groove. See Fig. 35.
  • Tension special tool 33 4 401 with wrenches 33 4 403 and 33 4 404 until it can still just be turned in groove. See Fig. 36 .
  • Screw in special tool 33 4 402. Detach inner bearing race.
7. Remove circlip. See Fig. 37 .
8. Remove wheel bearing with special tool 33 4 031/ 041/ 042/ 043/ 045. See Fig. 38 .
CAUTION: Do not reuse old wheel bearing.
9. Draw in new wheel bearing with special tool 33 4 041/ 042/ 043/ 047. For inner bearing race 42 mm use special tool 33 4 049 and for 39 mm use 33 4 046. See Fig. 39 .
10. Installation is reverse of removal.
11. Replace stretched or damaged circlip. Ensure correct seating.
12. Pull in drive flange using special tool 33 4 041/ 042/ 043/ 045/ 048. See Fig. 40 .
13. Install brake disc.
14. Install axle shaft.
Nov 12, 2010 | BMW 325 Cars & Trucks
How to replace a Jaguar X Type fron wheel bearing
Jaguar 2000-06
Wheel Bearings
Removal & Installation
  1. Remove the brake disc.
  2. Remove and discard the retaining clip. Detach the ABS sensor.
  3. Remove and discard the O-ring seal.
  4. Remove the wheel hub and bearing retaining bolts.
  5. Remove the wheel hub and bearing.
  6. Prior to applying sealer, clean the ABS sensor sealing surface and the ABS sensor aperture sealing surface.
  7. Install a new O-ring seal.
  8. Apply a 2.5mm bead of Loctite Ultra Blue 587 Silicone (RTV) sealer to the ABS sensor sealing surface.
  9. Install a new ABS sensor retaining clip.
  10. Install the hub/bearing assembly. Tighten to 90 Nm.
  1. Remove wheel knuckle.
NOTE When removing the wheel hub from the wheel knuckle the bearing will be destroyed and the bearing inner ring will remain on the wheel hub.
Fig. Using special tools, remove the wheel hub-X-Type
  1. Using special tools, remove the wheel hub.
  2. Using a suitable tool, remove the bearing inner ring.
  3. Using special tools, remove the wheel bearing.
    Fig. Using a suitable tool, remove the bearing inner ring-X-Type
    Fig. Using special tools, remove the wheel bearing-X-Type
To install:
Fig. Insert special tool 204-312 in to 204-309-X-Type
  1. Insert special tool 204-312 in to 204-309.
  2. Support the wheel knuckle on special tools.
NOTE Make sure wheel bearing is correctly orientated with the colored side facing inboard.
  1. Align the bearing over special tool.
  2. Using special tools, press bearing into wheel knuckle.
  3. Change special tool 204-312 to 204-313.
  4. Align the bearing and wheel knuckle over special tool.
  5. Slide wheel hub over the guide and align to the bearing.
  6. Using special tools install the wheel hub.
  7. Install the wheel knuckle.
    Fig. Using special tools, press bearing into wheel knuckle-X-Type
    Fig. Change special tool 204-312 to 204-313-X-Type
    Fig. Align the bearing and wheel knuckle over special tool-X-Type
    Fig. Slide wheel hub over the guide and align to the bearing-X-Type
  1. Raise front of vehicle and support on stands.
  2. Remove appropriate road wheel.
  3. Using wire or string, secure brake caliper to road spring to take weight off brake hose.
  4. Raise vehicle sufficient to provide access for special tool 204-111.
  5. Install special tool 204-111 in road spring.
  6. Slacken tool adjuster to suit spring length.
  7. Install adaptor and thrust collar.
  8. Position stem of tool in center of spring passing dowel through slot in suspension turret.
    Fig. Install special tool 204-111 in road spring-XJ Range and XK Range
    Fig. Position stem of tool in center of spring passing dowel through slot in suspension turret-XJ Range and XK Range
NOTE When turning tool adjuster, ensure that tool stem does not rotate and disturb position of dowel in suspension turret.
  1. Engage dowel of special tool 204-111 in suspension turret and rotate to position across slot.
  2. Lower vehicle onto stands.
  3. Rotate tool adjuster to tension spring.
  4. Remove wheel speed sensor securing screw and withdraw sensor from vertical link.
  5. Remove nut securing tie rod outer ball joint to steering arm.
  6. Release ball joint from vertical link.
  7. Install special tool 211-098 on tie rod outer ball joint.
  8. Tighten tool bolt to release taper pin from vertical link.
  9. Remove special tool from ball joint and position tie rod for access.
  10. Remove nut securing upper control arm ball joint to vertical link.
    Fig. Install special tool 211-098 on tie rod outer ball joint-XJ Range and XK Range
continue...
Aug 03, 2010 | 2002 Jaguar X-Type
Repair front wheel bearing assembly
no special tools in particular just the usual or necessary tools required.. 1stly u remove the Tyre and the caliper then u'll see something like a long rod dats the bearing
Aug 02, 2010 | 2004 Mercury Mountaineer
Do i need any special tools to change hub bearing on a 95 honda passport
No special tools needed, this Honda has the old type inner and outer wheel bearing's, remove cotter pin, spindle nut slide rotor out, remove wheel bearing, repack new bearing with grease and don't forget to replace grease seal's, install new part's adjust spindle nut and install cotter pin.Good luck,hope this was very helpful.
May 13, 2010 | 1995 Honda Passport
Changing the Spark Plugs. Do you need a special
There is a special Spark Plug socket for removing plugs. The engine does not have to be moved.
Oct 09, 2009 | Socket Communications OTC Tools &...
Need a Socket? Or special Wrench to take off my wheels!?
hi how are you if you dont have the wheel lock you can get the lug nut off by getting a nut and bolt remover kit some parts stors have them or from a specialty tool company (craftsman,snap-on) they both sell them and they will remove the lug nut.then just replace with a standard lugnut.
Feb 05, 2009 | 1999 Daewoo Lanos
Changing ignition switch. Having problems getting it out.
remove steer wheel with puller. u will see black cover remove 3 tork screws.remove. next u will need a special tool push dowd on plate . remove clip in center. lift turn arm . remove bolt for lock cly. turn key lock will slide out
Oct 20, 2008 | Chevrolet S 10 Cars & Trucks
Baby Gear Logo
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
