Question about Canon MultiPASS MP390 All-In-One InkJet Printer
The alarm button is going off and blinking orange. The message says put in cartridge, but both cartridges are in.
  • christab2 Jul 14, 2010
    I did all of that and it stll doesn't work, so I guess I need to replace the printer head. ughhh! I need to print right now!!!! At any rate, thanks a bunch!
  • 10,515 Answers
Please remove all cartridges and print head. Using a moist cloth clean the golden contacts on Print head as well as printer. DO NOT touch nozzle of cartridge. Dont insert the cartridge yet.
Please do this :
1. Remove the power cable from printer. Remove the USB cable that connects printer to computer (remove it from printer as well as computer's usb port)
2. Press the printer power button and keep pressed for 3 minutes then release
3. Now plug in the power cable and usb cable (connect printer to computer) and power on the printer.
Then plug in the Print head and cartridges.
You could download the manual from :-
http://www.manualshark.org/m/canon-imageclass-mp390-set-up-guide-879/
It would have instructions to clean print head.
However, if that would not solve the problem, it confirms a damaged print head. You need to get it replaced. You could find a new one or a used ( in working condition ) on most of the auction sites like ebay.Unless, you need to send the unit for repair.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jul 14, 2010
Colour and black ink cartridge flashing orange
They call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Oct 05, 2014 | Canon PIXMA MP495 InkJet Printer
How to fix error code 5200 on canon printer MP258? what is 5200 mean?
Here's the procedure. This code is normally encountered after refilling an ink cartridge and replacing the cartridge. Turn off printer. Hold down Stop/Reset button with one hand and turn printer on with other hand. After green light comes on for the ON button, press the Stop/Reset button two times and you should see the green light blink off and the orange alarm light blink "on" with the first press and then the green light comes back on for the power button and the orange light goes off with the second press (if you did it correctly). Now, you need to hold down the ON button about five seconds, then let go to shut OFF the printer. When you turn it back on, the printer should be back to the factory original condition. Make sure you set all your printer properties the way you want them again from your printer properties dialog boxes because some of the settings may have been stored in the printer's EEPROM, which you just reset to get rid of the offending alarm code.
Feb 01, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
Alarm lights keep blinking after I changed my printer ink.
E5 means cartridges error - to fix press the "stop\reset" button for 5-7 seconds and then release it.
You can also try this:
1) With the printer power turned off but connected to a power source, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4 times----Green (Power)------Waste ink counter resetting
Apr 07, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Message says problem with tri color cartridge
I don't think the date on the cartridge is the problem. It might be the electronic on your color cartridge. If there is an orange light flashing and the printer won't pull the paper to print, in 99%, the problem is one of the cartridges. Try removing the color cartridge and gently wipe out the electronic with a dry cloth. Put it back in and try to print. If that doesn't help, try removing the color cartridge and print (I am not sure if that will work, because all in one printers usually need both cartridges in order to print, but you can try that too). You can also try scanning something and see what the message on the printers display tells you. If there is an E an the color button is blinking, I think you should replace your color cartridge.
Apr 04, 2010 | HP OfficeJet 7310 All-In-One InkJet...
Cant get the orange arrow button to stop blinking
TRy HOLDING the power button (green) down and pressing the resume button (orange arrow) 10 times. Release both buttons. You may get a self-test print out of the printer after which, the resume button should be off.
I just tried this on my printer and it worked. I do not know if fewer than 10 presses will work. I know 4 presses did not.
good luck
Mar 28, 2010 | HP Deskjet D4160 InkJet Photo Printer
Both lights are blinking and will not print
they call that flash codes or error codes. please count
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Canon Printer Blinking in Orange : 7 times, The
Install the ink cartridge(s), and close the access
cover.
Sep 05, 2009 | Canon PIXMA iP1300 Printer
In canon pixma ip1700 Alarm light orange flashes 15 times
Fifteen Flashes: The FINE Cartridge cannot be recognized.
Possible causes are as follows:
- The FINE Cartridge may not be installed properly.
- The FINE Cartridge may not be compatible with this printer.
Install the appropriate FINE Cartridge. If lines are misaligned or the resulting output is not satisfactory, carry out the Print Head Alignment.
Apr 06, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Arrow light and Power light keep blinking
take out all the cartridges and the papers..
unplugg the power cable from the printer..
manually slide the carriage from left to right and vice versa and roll the rollers in upward direction from the back after opening the back door..
if doesnt slide or roll..press & hold the power button for 60 seconds and then try again..
clean the inner area of the cartridge slot and the copper contacts of the cartridge with a soft lint-free cloth..
close the back door...
dont put the cartridges..
connect the power cable and power on the printer...
Lights will blink..
Insert one cartridge in the respective slot and close the cartridge door and check if any light blinks..
then remove the cartridge and insert another one and check the same thing..
If light blinks..it will mean the respective cartridge is not good and replace it--
Nov 07, 2008 | HP DeskJet 6540 InkJet Printer
Printer Problem
This was not the sollution for my pinter..
My Magneta is half full and my error led is also blinking 15 times
I found this service manual for the IP4200 but this methode also doen not solve my error led..
Is their someone who has the sollution for this strange error?
1) With the printer power turned off, while pressing
button. (DO NOT release the buttons. The Power LED
selectable.)
resume/Cancel button. (DO NOT release the Power
button.)
the Power and Resume/Cancel buttons. (Each time the
Power
in
time(s)
setting) (THEN HIT THE POWER BUTTON >AFTER THIS< TO SET).
Time(s) LED indication Function Remarks
0 times Green (Power) Power off When the print head is
not installed, the carriage returns and locks in the
home position capped.
1 time Orange (Alarm) Service test print .
2 times Green (Power) EEPROM information print
3 times Orange (Alarm) EEPROM initialization
>>>>>>>>THIS ONE
4 times Green (Power) Waste ink counter resetting<<<<<<<<<<<<
5 times Orange (Alarm) Destination settings After
entering the destination settings mode, press the
to select the destination. For detail, see
"Destination settings procedures" below.
6 times Green (Power) Print head deep cleaning
(Cleaning of both black and color)
7 times Orange (Alarm) Reserved
8 times Green (Power) CD / DVD check pattern
9 times Orange (Alarm) CD / DVD print position
correction (horizontal: X direction)
10 times Green (Power) CD / DVD print position
correction (vertical: Y direction)
11 to 13 times Orange, Green, Orange(Alarm,
Power,Alarm) Return to the menu selection
14 times Green (Power) Left margin correction Not used
in servicing.
15 times Orange (Alarm) Return to the menu selection
Time(s) LED indication Destination CD / DVD print
0 times Green (Power) No change of the destination
1 time Orange (Alarm) Japan Supported
2 times Green (Power) Korea Not supported
3 times Orange (Alarm) US Not supported
4 times Green (Power) Europe Supported
5 times Orange (Alarm) Australia Supported
Oct 30, 2007 | Canon PIXMA iP4300 InkJet Photo Printer
Canon MultiPASS MP390 All-In-One InkJet Printer Logo
old marine
old marine
